Change date format
I have this function
let day = new Date("2005-03-01"); //YYYY-MM-DD
var end = new Date("2005-03-03");
while(day <= end){
    startDay = day.setDate(day.getDate() - 1);
    endDay = day.setDate(day.getDate() + 1);
    msg.payload= {
                    "startDay": startDay,
                    "endDay": endDay
    node.send(msg);
    day = new Date( day.setDate(day.getDate() + 1) )
It outputs the following
Screenshot 2023-03-07 112843
how would it be possible to get the dates in DD-MM-YYYY format?
Where is it that you want to display the date in that format?
The startDay and endDay will need to go to a post request to a URL
    "userId": 6412,
    "startDay": "01-01-2023",
    "endDay": "02-01-2023"
OK, I believe you can use node-red-contrib-moment to do such things. Or you could do it in javascript using the Date functions to get the individual parts and build the string.
This will work
let date = new Date(startDay).toISOString().split('T')[0]
startDay = date.split('-')[2] + '-' + date.split('-')[1] + '-' + date.split('-')[0]
date = new Date(endDay).toISOString().split('T')[0]
endDay = date.split('-')[2] + '-' + date.split('-')[1] + '-' + date.split('-')[0]
gives
"28-02-2005"
or probably better
let end = new Date("2005-03-03");
while(day <= end){
    let startDay = day.setDate(day.getDate() - 1);
    let endDay = day.setDate(day.getDate() + 1);
    msg.payload= {
                    "startDay": timeStampToDate(startDay),
                    "endDay": timeStampToDate(endDay)
    node.send(msg);
function timeStampToDate(timeStamp) {
   let date = new Date(timeStamp).toISOString().split('T')[0]
   return date.split('-')[2] + '-' + date.split('-')[1] + '-' + date.split('-')[0]
Wow. Perfect.
Thanks,
