Change DMX dimmer output by a pushbutton
Hi There, I'm trying to create a dimmer value into a JSON line. This dimmer value needs to be controlled by a pushbutton. When you press once, the light goes on. When you keep the button pressed, the dimmer value goes down , and when it's zero it goes up until you release the button. This is what I got at the moment, but that's without that variable value.
[{"id":"06afa4f2be886b2e","type":"tab","label":"Flow 7","disabled":false,"info":"","env":},{"id":"c220c40b2dc0a40b","type":"group","z":"06afa4f2be886b2e","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["28fd8aaed4e403c8","c5304477870a5d1c","70afc3b684eac84e","1c60f127b5c56e99","110f56d66c768df9"],"x":134,"y":219,"w":772,"h":142},{"id":"c5304477870a5d1c","type":"inject","z":"06afa4f2be886b2e","g":"c220c40b2dc0a40b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":230,"y":260,"wires":[["70afc3b684eac84e"]]},{"id":"70afc3b684eac84e","type":"change","z":"06afa4f2be886b2e","g":"c220c40b2dc0a40b","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"switch_toggle","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"$$.payload = 1 ? 0 : 1","tot":"jsonata"},{"t":"set","p":"switch_toggle","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":260,"wires":[["1c60f127b5c56e99"]]},{"id":"1c60f127b5c56e99","type":"function","z":"06afa4f2be886b2e","g":"c220c40b2dc0a40b","name":"","func":"var x = context.get("counter") || 0;\nif (msg.payload == 0)\n{\n context.set("counter",0);\n msg.payload = {"channel":5, "value":0};\n return msg;\n}\nif (msg.payload == 1)\n{\n context.set("counter",1);\n msg.payload = {"channel":5, "value":100};\n return msg;\n}\n\nif (x === 0)\n{\n msg.payload = {"channel":5, "value":100};\n} else\nif (x === 1)\n{\n msg.payload = {"channel":5, "value":0};\n}\n\nx = (x + 1) % 2;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":600,"y":260,"wires":[["110f56d66c768df9","28fd8aaed4e403c8"]]},{"id":"110f56d66c768df9","type":"debug","z":"06afa4f2be886b2e","g":"c220c40b2dc0a40b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":260,"wires":},{"id":"28fd8aaed4e403c8","type":"artnet-command","z":"06afa4f2be886b2e","g":"c220c40b2dc0a40b","name":"DMX Controller","artnetnode":"d4e9c1034ff581f7","x":800,"y":320,"wires":,"inputLabels":["switch"]},{"id":"d4e9c1034ff581f7","type":"artnet-node","host":"192.168.2.37","port":"6454","universe":"0"}]
Your flow is corrupt due to not following posting guidelines
All code needs to be posted between tripple backticks on newlines e.g.
code
Any way here is an example the flow is set to send the payload every second, the value increments by 1 and when it hits 10 it reduces by 1 till it hit 0, and then increments again.
The routine starts when it receives 1 and stops when it receives 0.
[{"id":"c5304477870a5d1c","type":"inject","z":"06afa4f2be886b2e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":230,"y":180,"wires":[["b5f5886ea2f2d6fc"]]},{"id":"b5f5886ea2f2d6fc","type":"trigger","z":"06afa4f2be886b2e","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-1","extend":false,"overrideDelay":false,"units":"s","reset":"0","bytopic":"all","topic":"topic","outputs":1,"x":420,"y":180,"wires":[["70afc3b684eac84e"]]},{"id":"2e4e413c3d3dbcca","type":"inject","z":"06afa4f2be886b2e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":230,"y":220,"wires":[["b5f5886ea2f2d6fc"]]},{"id":"70afc3b684eac84e","type":"change","z":"06afa4f2be886b2e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum([$flowContext(\"dimmer_level\")])","tot":"jsonata"},{"t":"set","p":"plus","pt":"flow","to":"$$.payload >= 10 ? -1 : ($$.payload <= 0 ? 1 : $flowContext(\"plus\"))","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$$.payload+$flowContext(\"plus\")","tot":"jsonata"},{"t":"set","p":"dimmer_level","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":180,"wires":[["110f56d66c768df9"]]},{"id":"110f56d66c768df9","type":"debug","z":"06afa4f2be886b2e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":240,"wires":[]}]
Edit trigger to change timing and change not to set to levels and increments you require.
Great super, that works.
Thanks :slight_smile:
