Change in flows OTA
I was wondering if there is a way to change in flows or update it remotely (OTA updates)
i have a device running Linux with node-red installed, connected to the internet
how to be able to do this updates with my personal computer (windows with nodered installed).
What is "it"?
*them "the flows"
So you want to log in remotely to your Linux box and play around with NR? https://www.putty.org/
Just to add, I assume you have read the following ... https://nodered.org/docs/tutorials/first-flow
Or are you actually asking "how do you access your NR on Linux from the WAN (internet)?" In that case you would need to look at something like a VPN from your PC to your Linux box.
