Hi there. Please I need help with convert incoming message from my ORNO WE 516 to readable domoticz values.
On input from MQTT i get this message in string form:
tele/tasmota_147B98/SENSOR : msg.payload : string[316]
{"Time":"2022-09-14T09:05:10","ENERGY":{"TotalStartTime":"2022-09-11T22:36:00","Total":7.050,"Yesterday":3.770,"Today":2.430,"Period":[ 0, 0, 0],"Power":[ 6,20,267],"ApparentPower":[71,42,689],"ReactivePower":[ 0, 0, 1],"Factor":[0.09,0.63,0.40],"Frequency":50,"Voltage":[238,236,237],"Current":[0.300,0.180,2.910]}}
I need choose one of this values like "Voltage" and send it back to MQTT with message something like this:
msg1 = {};
msg1.payload = {"command":"udevice","idx":300,"nvalue":0,"svalue":238;236;237};
return [[msg1]];
For correct read device in Domoticz. Can you help me please how to modifi this MQTT message?
- set the MQTT node to parse JSON into an object
- click the copy path button on the item of interest
- use a change node to copy into
msg.payload from the msg.path_you_copied
- send to an MQTT out node with an appropriate topic
Thereās a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
NOTE what you are doing here:
is not valid.
At a guess you want a string from the voltage array e.g. "238;236;237"
In a function node...
msg.payload = {
"idx":300,
"nvalue":0,
"svalue": msg.payload.Voltage.join(';')};
Steve Huge THANKYOU
Its works.
Tasmota log:
2022-09-14 11:33:10.621 MQTT: Topic: domoticz/in, Message: {"command":"udevice","idx":148,"nvalue":0,"svalue":"238,238,239"}
