Change my button background color
Hi, I like to change my background color of my button on a dashboard, depending of the state of a global variable.
It has to look like => {{global.get("speelOverhevel" ) == true? 'green' : 'red'}} But that is not working.
If I put something like this => {{msg.payload.state >0? 'green' : 'red'}} this is working. But I like to use my global variable.
Is there somebody who can point me in the right direction?
Thanks.
Guessing as you have not supplied a example flow.
You are trying to use angular {{ }}
But global is server side and angular is client side, so is not available in the button, which is running in your browser (client side)
Use a change node prior to the button to set a property of msg to the value of the global var.
If this is not correct please supply an simple example flow of issue.
Thanks this is working.
