Change of switch rules / parameters via the dashboard
Hi Folk
yesterday I managed to get my first NR program running and visualized on the dashboard.
Now I want to change some of my switch rules / parameters via the dashboard.
Example: The swich is deciding wether the Input is higher than 50 or lower/even than 49.
I want to be able to change these margins via an dashboard input.
Do you can give any hint, how I can manage this or where somebody got an answer on an comparable question?
Shure, I searched via the net, but found no answer...
Thanks a lot!
You can set the switch property or rule to a context var (flow/global), you can then update this property via the dashboard.
Thank you very much..Will try it
