Change of variable name
I got stucked!
I use a TopicJson payload:
{"220":"0","XXX":"255","SOC":"98.8","SOH":"82","B-T":"18.14","M-T":"23","Tun":"","kWh":"4.9","Amp":"-0","RPM":"470","Nm ":"-1","FW ":"","C01":"4.11","C02":"4.11","C03":"4.11","C04":"4.11","C05":"4.11","C06":"4.11","C07":"4.12","C08":"4.11","C09":"4.11","C10":"4.11","C11":"4.11","C12":"4.11","C13":"4.11","C14":"4.11","Pac":"57.6","T01":"19","T02":"18","T03":"18","T04":"18","T05":"18","T06":"18","T07":"18","Reg":"","ECO":"","Nor":"","CSt":"0","tAY":"0.00","B12":"13.88","PN1":"1","PN2":"0","KmT":"410666","KmR":"57","KmH":"5.1","SeT":"14","tKT":"282","tKR":"51","tTM":"3298","tKW":"2.7","t10":"9.5","t01":"0.09","tMN":"0.05","tKH":"30.7","kW ":"-0.02","CEt":"","CdK":"","C-T":"40","CKw":"","Min":" 30","T-T":"19.86","Acc":"0.63","AnX":"-2.53","AnY":"-3.78","AnZ":"-36.44"}
where I easily can extract values, like: T07
Node 'Function':
var Inhalt = msg.payload
node.log(typeof Inhalt)
msg.payload = Inhalt.T07
msg.payload = Number(msg.payload)
msg.topic = "BattT07"
Result = 18
but if the varialbe name is: C-T , I'm in trouble:
grafik
In line 3 a red tile is below T, thus the functions "thinks" T must be deducted from "Inhalt.C" <- which is wrong !
The varaible name is "T-C".
Does someone has an "easy" solution / fix ?
Thanks in advance
Try Inhalt["T-C"]
An easy way to find this is send the msg.payload to a debug node. Then you can look at the data and see to the side how you can copy the path to it. In this case it would show payload["C-T"] so you would want to call it Inhalt["C-T"]
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
In addition it is nice to provide the actual code instead of an image of it.
Thanks and thanks to jbudd, too.
Change done, w/o red triangle :ok_hand:
I'll check out for functioning next time Twizy is connected for charging. :+1:
@zenofmud: I pasted the picture to see easily the "red tile".
