i have noting find in the search.
is it possible to change the Payload Value 1 and 0 in a text for sending?
in attachment a picture from my test, but the sending is only 0 or 1 i don`t can change the value.
Thank you
Stefan
Welcome.
sorry could not understand the requirement, but see if this is what you expected.
[{"id":"59d9020ac04ecaba","type":"inject","z":"53edcbb0228e136a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"This is a payload containing 0 and 1","payloadType":"str","x":590,"y":3540,"wires":[["689cb6fcabaa3307","d18685ac97441002"]]},{"id":"1ca1175f85b08435","type":"debug","z":"53edcbb0228e136a","name":"debug 2507","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":940,"y":3540,"wires":[]},{"id":"689cb6fcabaa3307","type":"change","z":"53edcbb0228e136a","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"str","to":"(this was zero)","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"str","to":"(this was one)","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":3540,"wires":[["1ca1175f85b08435"]]},{"id":"d18685ac97441002","type":"debug","z":"53edcbb0228e136a","name":"debug 2508","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":920,"y":3470,"wires":[]}]
I'll try again. In the said payload, the open state 0 closed and 1 open of a door sensor is delivered. But I want to convert the value 0 or 1 into a string and then send it as a message
0 should be changed to "door closed"
1 should be changed to “Door opened”
I hope the description is now clearer?
Thanks for your help.
[{"id":"8a510de3a49fa2b4","type":"inject","z":"53edcbb0228e136a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"str","x":510,"y":3640,"wires":[["a2bdf0700c85f27a"]]},{"id":"a2bdf0700c85f27a","type":"switch","z":"53edcbb0228e136a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":650,"y":3660,"wires":[["30f5ea8ca1724766"],["519a67a4268810d1"]]},{"id":"63eed357b8ebfdc5","type":"inject","z":"53edcbb0228e136a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"str","x":510,"y":3690,"wires":[["a2bdf0700c85f27a"]]},{"id":"30f5ea8ca1724766","type":"change","z":"53edcbb0228e136a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"The Door is Closed","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":3630,"wires":[["5cb68d24453f2a05"]]},{"id":"519a67a4268810d1","type":"change","z":"53edcbb0228e136a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"The Door is Open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":3680,"wires":[["5cb68d24453f2a05"]]},{"id":"5cb68d24453f2a05","type":"debug","z":"53edcbb0228e136a","name":"debug 2509","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1070,"y":3660,"wires":[]}]
assuming the payload is equal to 0 or 1
If it contains 0 and 1 , then @cymplecy solution should work.
unfortunately this doesn't work:
v3/doorsens@ttn/devices/chicken-out/up : msg.payload : number 1
is the payload result.
and if I change that to open door
it will still be passed as 1
thanks i will check with a switch befor
perfect, it works, thank you.
I had two mistakes.
The payload was queried once not as a payload but again as a payload status.
and then didn't use the switch.
Both combinations work together and the text is transmitted.
Many thanks
