After a query in Mysql, I display the data on regular UI_textbox and I would like to use ui_switch do display by boolean fields data.
So far, no success, the ui_switch never change according to received field value (true or false). IF I use a timestamp and sending true or false manually, the switch status change on the site dynamically.
Any idea what wrong I do?
Thanks a lot for your help
Yves
Here the switch config:
