Change widget colour for specific page
Hello
I have a default colour set for my node red dashboard widgets. On a particular tab however where I have a slider widget, I need to override this colour so I can change the colour of the red dot on the slider.
I have a style node setup, but not sure of the code. I tried something like this, but it didn't work:
#nr-dashboard .masonry-container ui-card-panel#MasterDimmer_MasterDimmer {{
background-color: #FFFFFF;
Where MasterDimmer is the tab.
See below circled in red for the colour I am trying to change:
Since your picture shows non-standard colours, I presume that you are already overruling the default styling and don't need step by step instructions.
To give different styling to just this slider, in it's config give it a custom class, let's say "special".
Use a template node with style tags to style the element within class .special
<style>
.special <more css selectors needed here> {
   background-color: #ffffff
</style>
Use your browser tools to pin down the precise CSS selectors needed.
Note that the slider widget uses a pseudoclass ::after and you need to style this pseudoclass.
And when you get it working:
Example:
For tab named "Colors" all slider thumbs (+active state) will be orange.
See that the selector starts with #Tab_Colors
Tab name can have spaces. In that case you'll need to join words with underscore.
My Page will be then #Tab_My_Page
<style>
    #Tab_Colors .nr-dashboard-slider .md-thumb:after{
        background-color: orange;
        border-color: orange;
    #Tab_Colors .nr-dashboard-slider .md-focus-ring {
</style>
