Changing a Group Name Dynamically
In dashboard 1 I used to use a template node containing some 'magic' code from this forum that allowed me to dynamically change the name of a group by passing msg.payload to this script:
<script>
(function($scope) {
$scope.oldGroupName = 'THP-X'; // initial group placeholder name
$scope.$watch('msg', function() {
    if ($scope.msg){
        $("p.nr-dashboard-cardtitle").each(function(){
            if($(this).text().trim() == $scope.oldGroupName.trim()){
                p = $(this);
                p.text($scope.msg.payload);
                 $scope.oldGroupName = $scope.msg.payload
})(scope);
</script>
This doesn't work in dashboard-2. Is there a piece of code available that does the same for dashboard-2? Or perhaps another way of doing it?
Gary
Do not show the group name.
Add a text widget with blank label at the top of the group.
Works perfectly, funny how the best solutions are often the simplest!
You could always do it the complicated way. This goes in a ui-template node with either page or group scope. :grin:
<script>
    export default {
        data() {
            // define variables available component-wide
            // (in <template> and component functions)
            return {
                groupTitle: 'Group Title'               // Default Group Title for first search (whatever you
                                                        // called the group when setting it up)
        methods: {
            // Update the Group Title and Save
            updateHeader: function (newGroupName) {
                const header = Array.from(document.getElementsByClassName("v-card-title"))
                    .find(el => el.textContent === this.groupTitle)
                this.groupTitle = newGroupName
                header.textContent = this.groupTitle
        mounted() {
            this.$socket.on('msg-input:' + this.id, (msg) => {
                this.updateHeader(msg.payload)
        unmounted() {
            // code here when the component is removed from the Dashboard
            // i.e. when the user navigates away from the page
</script>
