One can read states with global.get ('homeassistant').homeAssistant.states['input_number.xyz'].state;
but it doesn't seem to have any effect if I use global.set.
Is it at all possible to change these values from a function Node ?
are you doing global.set correctly?
global.set("key", value)
so in your case...
var ha = global.get('homeassistant');
var oldValue = ha.homeAssistant.states['input_number.xyz'].state;
ha.homeAssistant.states['input_number.xyz'].state = 77; //change something
ha.homeAssistant.states.something_else = "a new string value"; //change something_else
global.set('homeassistant', ha);//store it
NOTE:
homeassistant is an object, calls to global.set('homeassistant', ha) are not strictly necessary - but are definitely good practice (as homeassistant is an object it will be modified by reference, you actually modify the global instance - but if you persist context to file, these wont happen unless you call global.set()) In a nutshell, always call global.set after modifying the value.homeAssistant.homeAssistant.states['input_number.xyz'].state is a valid path (as per your post) - though i suspect there are one too many homeAssistants - but you would need to show us the actual content of the global context object to be sure.Well I have tried using it like this:
global.set ('homeassistant').homeAssistant.states['input_number.xyz'].state, 1234);
and it looked like nothing happened to the value. The old value is still the same if read afterwards.
And yes, ('homeassistant').homeAssistant.states['input_number.xyz'].state is a valid path and the state can be read without any problems.
That definitely wont work.
The equivelant is this...
global.get('homeassistant').homeAssistant.states['input_number.xyz'].state = 1234;
This works because get gets the object & as it as a by reference affair, the sub properties are accessible & settable.
It works, great !
I think I have to dig into this a little deeper, I would probably never have solved this problem without you help.
I saw you comment on side affects and have to make sure I really understand what effects is has.
Thanks Steve-Mcl, you have really made my day.
You're welcome.
Please note, the "correct node-red way" to do this is...
ha.homeAssistant.states['input_number.xyz'].state = 1234;
Noted.
Doing it this way is also much more inline with what I intend to do (setting many states).
