The inject node cannot be programmatically set, but you can do what you want in another way - check out Colin's neat solution or the sophisticated node-red-contrib-msg-resend node.
stew
2
Related topics
| Inject node - repeat. Stuck if it can be set externally | 7 | 5617 | 9 February 2020 | |
| Trigger node help - please | 10 | 1136 | 1 June 2019 | |
| Design pattern for restarting a message loop (which should contain only one message at the time) with multiple dynamic delays | 18 | 1505 | 26 August 2021 | |
| Simple pulse generator | 7 | 1830 | 15 February 2022 | |
| Basics,Faster LED Blink,Set/Get function: mosquito into an elephant | 15 | 1471 | 14 June 2019 |
