Trigger node help - please
Forgive me if I've asked this before, but from what I remember it was the DELAY node, not the TRIGGER node.
Here's the part of the flow.....
[{"id":"178ae8cd.12b0d7","type":"trigger","z":"15af81c5.64999e","op1":"","op2":"2","op1type":"nul","op2type":"num","duration":"60","extend":false,"units":"min","reset":"reset","bytopic":"all","name":"Dusk/Night 2","x":420,"y":2830,"wires":[["aaab7a55.a5b48"]]},{"id":"a7e53875.6f5cd8","type":"trigger","z":"15af81c5.64999e","op1":"","op2":"3","op1type":"nul","op2type":"num","duration":"90","extend":false,"units":"min","reset":"reset","bytopic":"all","name":"Dusk/Night  3","x":420,"y":2870,"wires":[["aaab7a55.a5b48"]]},{"id":"b9cb98a8.35ed48","type":"trigger","z":"15af81c5.64999e","op1":"","op2":"OFF","op1type":"nul","op2type":"str","duration":"120","extend":false,"units":"min","reset":"reset","bytopic":"all","name":"Dusk/Night  OFF","x":429,"y":2909,"wires":[["aaab7a55.a5b48"]]},{"id":"4ebde882.899c88","type":"trigger","z":"15af81c5.64999e","op1":"","op2":"1","op1type":"nul","op2type":"num","duration":"30","extend":false,"units":"min","reset":"reset","bytopic":"all","name":"Dusk/Night 1","x":420,"y":2790,"wires":[["aaab7a55.a5b48"]]},{"id":"1ebea0cd.4ef777","type":"inject","z":"15af81c5.64999e","name":"","topic":"","payload":"trigger","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":2850,"wires":[["4ebde882.899c88","178ae8cd.12b0d7","a7e53875.6f5cd8","b9cb98a8.35ed48"]]},{"id":"aaab7a55.a5b48","type":"function","z":"15af81c5.64999e","name":"Do what ever","func":"\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":2850,"wires":[[]]}]
Understand this is not the flow, but a cut down part.
Something happens.
After 30 minutes, a message is sent.
After 60 minutes, another message is sent.
After 90 minutes, (you get it)
What I am wanting to do is be able to adjust the step size between the messages.
Say change it from 30 to 40, 50 or 60 minutes.
I've read the info and I don't think it is possible.
Fair enough if so. But I am open to how I could do what I want.
Much appreciated.
I found your previous inquire. At that point in time you asked how to change the interval if using the inject node. Colin proposed a flow using the delay node. I found it a smart solution and save the flow in my favorites folder.
Yes, but that sends an output at a given interval.
This more sends one output (per node) when it is triggered/"stimulated".
When an event happens I want a sequence of things happening (once) after then at given times.
As is, it is 30 minutes.
If I want to change it to 45, I have to edit all the nodes and add 45 to the time.
If I could send them that value I could send 45 and a function node would do all the maths and send the resulting values to the respective nodes.
So the first one would get 45.
The second would get 90
The next would get..... 135.
And so on.
Then, when the trigger event happens: after 45 minutes, node 1 would send its message (once)
Then another 45 minutes later: node 2 would send its message (once)
Another 45 minutes: node 3 would do it's thing.
In the previous one, these times would repeat.
In this case they are one off events all triggered by an initial input.
I see. Perhaps something like posted in the below post from the old forum ?
https://groups.google.com/forum/#!topic/node-red/vtvuXaLY0Zk
The first function node is where you define the timing.
It is easy to modify the amount of "triggers" (virtual triggers) and what data to send for each one.
In which case the modified version to suit your needs would be:
and you are free to change any delay for each step (in a single place):
// Define runtime1 (4 seconds)
msg.runtime1 = 4*1000;
// Define runtime2 (2 seconds)
msg.runtime2 = 2*1000;
// Define runtime3 (7 seconds)
msg.runtime3 = 7*1000;
// Next  to be activated is number 1
msg.next = 1;
//Stop criteria is false
global.set("StopFan",false);
[{"id":"df15b4d6.262448","type":"tab","label":"Flow 51","disabled":false,"info":""},{"id":"2109e1c9.fad29e","type":"function","z":"df15b4d6.262448","name":"Cycle next fan","func":"switch (msg.next) {\n    \n    case 1:\n        msg.delay = msg.runtime1;\n        msg.payload = 1; \n        msg.next = 2;\n        break;\n    case 2:\n        msg.delay = msg.runtime2;\n        msg.payload = 2;\n        msg.next = 3;\n        break;  \n    case 3:\n        msg.delay = msg.runtime3;\n        msg.payload = 3;\n        msg.next = 1;\n        break; \n        \n}\n\n    return msg;","outputs":1,"noerr":0,"x":500,"y":120,"wires":[["2941900c.9c37","d5fbd731.0bf9d8"]]},{"id":"512bcdf6.2aead4","type":"inject","z":"df15b4d6.262448","name":"Start Flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":140,"y":120,"wires":[["39c4fbe2.055824"]]},{"id":"d5fbd731.0bf9d8","type":"function","z":"df15b4d6.262448","name":"Test Stop","func":"//  user commanded stopping fans\nif (global.get(\"StopFan\")) msg.next = 4;\nreturn msg;","outputs":1,"noerr":0,"x":423.33331298828125,"y":259.555552482605,"wires":[["1567c1f3.9bce9e"]]},{"id":"39c4fbe2.055824","type":"function","z":"df15b4d6.262448","name":"Initialize","func":"\n// Define runtime1 (3 seconds)\nmsg.runtime1 = 3*1000;\n\n// Define runtime2 (6 seconds)\nmsg.runtime2 = 6*1000;\n\n// Define runtime3 (9 seconds)\nmsg.runtime3 = 9*1000;\n\n// Next  to be activated is number 1\nmsg.next = 1;\n\n//Stop criteria is false\nglobal.set(\"StopFan\",false);\n\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":120,"wires":[["2109e1c9.fad29e"]]},{"id":"1567c1f3.9bce9e","type":"delay","z":"df15b4d6.262448","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":603.3333129882812,"y":259.555552482605,"wires":[["2109e1c9.fad29e"]]},{"id":"2941900c.9c37","type":"debug","z":"df15b4d6.262448","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":680,"y":120,"wires":[]}]
Thanks.
It loops back and keeps going, but I think I can work out how to make it stop itself after 1 loop.
--via edit--
Ok, I am dumb.
In the initialize function node I see:
So, reading that I set "StopFan" to true to stop it.
But then when I look at the Test Stop node I see:
if (global.get("StopFan")) msg.next = 4;
4, not true/false/
I've obviously missed something.
I'll keep looking though.
--progress--
Ok, this is what I got to do the one time loop.
[{"id":"c5192ec4.39a838","type":"function","z":"6c223db0.773914","name":"Cycle next fan","func":"switch (msg.next) {\n    \n    case 1:\n        msg.delay = msg.runtime1;\n        msg.payload = 1; \n        msg.next = 2;\n        break;\n    case 2:\n        msg.delay = msg.runtime2;\n        msg.payload = 2;\n        msg.next = 3;\n        break;  \n    case 3:\n        msg.delay = msg.runtime3;\n        msg.payload = 3;\n        msg.next = 1;\n        break; \n        \n}\n\n    return msg;","outputs":1,"noerr":0,"x":500,"y":120,"wires":[["b40c043.9cbd778","344786ea.b93c02","3846424f.31e166"]]},{"id":"57d90848.942d68","type":"inject","z":"6c223db0.773914","name":"Start Flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":140,"y":120,"wires":[["7fea713a.2a3aa"]]},{"id":"344786ea.b93c02","type":"function","z":"6c223db0.773914","name":"Test Stop","func":"//  user commanded stopping fans\nif (global.get(\"StopFan\")) msg.next = 4;\nreturn msg;","outputs":1,"noerr":0,"x":423.33331298828125,"y":259.555552482605,"wires":[["d64d6ce1.b96f8"]]},{"id":"7fea713a.2a3aa","type":"function","z":"6c223db0.773914","name":"Initialize","func":"\n// Define runtime1 (3 seconds)\nmsg.runtime1 = 3*1000;\n\n// Define runtime2 (6 seconds)\nmsg.runtime2 = 6*1000;\n\n// Define runtime3 (9 seconds)\nmsg.runtime3 = 9*1000;\n\n// Next  to be activated is number 1\nmsg.next = 1;\n\n//Stop criteria is false\nglobal.set(\"StopFan\",false);\n\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":120,"wires":[["c5192ec4.39a838"]]},{"id":"d64d6ce1.b96f8","type":"delay","z":"6c223db0.773914","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":603.3333129882812,"y":259.555552482605,"wires":[["c5192ec4.39a838"]]},{"id":"b40c043.9cbd778","type":"debug","z":"6c223db0.773914","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","x":680,"y":120,"wires":[]},{"id":"7ce8975b.74c168","type":"change","z":"6c223db0.773914","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":310,"wires":[["d64d6ce1.b96f8"]]},{"id":"3846424f.31e166","type":"switch","z":"6c223db0.773914","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"3","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":240,"y":310,"wires":[["7ce8975b.74c168"]]}]
I misread your OP. Only now I realised that you don´t need the flow to keep looping until it receives some command to stop. It is just one loop. In such case the flow could be much simpler. All you need is to make the loop to read the pre set values and then send a msg.reset to the delay node.
I've nearly got it.
This is (now) what I have:
[{"id":"c5192ec4.39a838","type":"function","z":"6c223db0.773914","name":"Cycle next fan","func":"switch (msg.next) {\n    \n    case 1:\n        msg.delay = msg.runtime1;\n        msg.payload = 1; \n        msg.next = 2;\n        break;\n    case 2:\n        msg.delay = msg.runtime2;\n        msg.payload = 2;\n        msg.next = 3;\n        break;  \n    case 3:\n        msg.delay = msg.runtime3;\n        msg.payload = 3;\n        msg.next = 4;\n        break; \n        \n    case 4:\n        msg.delay = msg.runtime4;\n        msg.payload = 4;\n        msg.next = 5;\n        break; \n    case 5:\n        msg.delay = msg.runtime4;\n        msg.payload = 5;\n        msg.next = 1;\n        break; \n\n}\n\n    return msg;","outputs":1,"noerr":0,"x":500,"y":120,"wires":[["b40c043.9cbd778","3846424f.31e166","6aa67fb0.e1aca"]]},{"id":"57d90848.942d68","type":"inject","z":"6c223db0.773914","name":"Start Flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":140,"y":120,"wires":[["7fea713a.2a3aa"]]},{"id":"7fea713a.2a3aa","type":"function","z":"6c223db0.773914","name":"Initialize","func":"\n// Define runtime1 (3 seconds)\nmsg.runtime1 = 3*1000;\n\n// Define runtime2 (6 seconds)\nmsg.runtime2 = 3*1000;\n\n// Define runtime3 (9 seconds)\nmsg.runtime3 = 3*1000;\n\n//  Define runtime4\nmsg.runtime4 = 3*1000;\n\n//  Define runtime5\nmsg.runtime5 = 3*1000;\n\n// Next  to be activated is number 1\nmsg.next = 1;\n\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":120,"wires":[["c5192ec4.39a838"]]},{"id":"d64d6ce1.b96f8","type":"delay","z":"6c223db0.773914","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":600,"y":280,"wires":[["c5192ec4.39a838"]]},{"id":"b40c043.9cbd778","type":"debug","z":"6c223db0.773914","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":720,"y":140,"wires":[]},{"id":"7ce8975b.74c168","type":"change","z":"6c223db0.773914","name":"stop","rules":[{"t":"set","p":"reset","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":260,"wires":[["d64d6ce1.b96f8"]]},{"id":"3846424f.31e166","type":"switch","z":"6c223db0.773914","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"4","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":230,"y":280,"wires":[["7ce8975b.74c168","a20bf21d.c17ac8"],["d64d6ce1.b96f8"]]},{"id":"6aa67fb0.e1aca","type":"debug","z":"6c223db0.773914","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","x":700,"y":100,"wires":[]},{"id":"a20bf21d.c17ac8","type":"change","z":"6c223db0.773914","name":"off","rules":[{"t":"set","p":"payload","pt":"msg","to":"OFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":220,"wires":[["6aa67fb0.e1aca","b40c043.9cbd778"]]}]
But it isn't quite perfect.
If I want to "exit on 4" and I make the switch select the 4, I still see the next digit before I get the "OFF" message.
luckily that isn't a problem and the code can deal with that.
I have applied it to the real flow and will have to wait for tonight to see if it works.
(Though I may give it a poke before then if I feel lucky.)
Indeed, you got the idea
I had a look in your very first flow, the one that uses the trigger nodes. The behavior of that flow is to first wait for a delay and only then send the first message. The one i suggested behaves differently: it first sends the message and then wait for a delay.
Here a modified flow that I think is better (but still uses an uggly loop):
[{"id":"7b4467ef.fde5a8","type":"tab","label":"Variable timer","disabled":false,"info":""},{"id":"d1640e93.e60bc","type":"function","z":"7b4467ef.fde5a8","name":"Cycle next ","func":"switch (msg.next) {\n    \n    case 1:\n        msg.delay = msg.runtime1;\n        msg.payload = 1; \n        msg.next = 2;\n        break;\n    case 2:\n        msg.delay = msg.runtime2;\n        msg.payload = 2;\n        msg.next = 3;\n        break;  \n    case 3:\n        msg.delay = msg.runtime3;\n        msg.payload = 3;\n        global.set(\"StopFan\",true);\n        msg.next = 4;\n        break; \n    case 4:\n        msg.delay = msg.runtime4;\n        msg.payload = \"off\";\n        msg.next = 5;\n        break;\n    case 5:\n        msg.reset = true;\n        break;    \n}\n\n    return msg;","outputs":1,"noerr":0,"x":530,"y":200,"wires":[["6c8a9344.dc08ec"]]},{"id":"fcb494c.c71ed68","type":"inject","z":"7b4467ef.fde5a8","name":"Start Flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":180,"y":200,"wires":[["3d655d83.8daff2"]]},{"id":"3d655d83.8daff2","type":"function","z":"7b4467ef.fde5a8","name":"Initialize","func":"\n// Define runtime1 (4 seconds)\nmsg.runtime1 = 4*1000;\n\n// Define runtime2 (2 seconds)\nmsg.runtime2 = 2*1000;\n\n// Define runtime3 (10 seconds)\nmsg.runtime3 = 10*1000;\n\n// Define runtime4 (6 seconds)\nmsg.runtime4 = 6*1000;\n\n\n// Next  to be activated is number 1\nmsg.next = 1;\n\n\nreturn msg;","outputs":1,"noerr":0,"x":340,"y":200,"wires":[["d1640e93.e60bc"]]},{"id":"6c8a9344.dc08ec","type":"delay","z":"7b4467ef.fde5a8","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":520,"y":280,"wires":[["d1640e93.e60bc","8f5d3dbd.d659e"]]},{"id":"8f5d3dbd.d659e","type":"debug","z":"7b4467ef.fde5a8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":750,"y":280,"wires":[]}]
I'll look soon.
The idea is that an event happens. Say: Sunset.
The flow sends a message.
Then after a given time, a new message is sent.
After that time again, another message is sent.
That goes on until I am done.
When done, an "OFF" message is sent.
The times between the messages is what I want to adjust. It will usually be the same between all the messages.
So having one point where I can edit it is handy and makes it easier if/when I want to change it.
Thanks again for the replies.
I'll get back to you on the latest bit.
This is my latest effort:
[{"id":"57d90848.942d68","type":"inject","z":"6c223db0.773914","name":"Start Flow","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":140,"y":120,"wires":[["7fea713a.2a3aa"]]},{"id":"7fea713a.2a3aa","type":"function","z":"6c223db0.773914","name":"Initialize","func":"var interval = 3 * 1000;\n// Define runtime1\nmsg.runtime1 = interval;\n\n// Define runtime2\nmsg.runtime2 = interval;\n\n// Define runtime3\nmsg.runtime3 = interval;\n\n//  Define runtime4\nmsg.runtime4 = interval;\n\n//  Define runtime5\nmsg.runtime5 = interval;\n\n// Next  to be activated is number 1\nmsg.next = 1;\n\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":120,"wires":[["c5192ec4.39a838"]]},{"id":"c5192ec4.39a838","type":"function","z":"6c223db0.773914","name":"Cycle next fan","func":"switch (msg.next) {\n    \n    case 1:\n        msg.delay = msg.runtime1;\n        msg.payload = 1; \n        msg.next = 2;\n        break;\n    case 2:\n        msg.delay = msg.runtime2;\n        msg.payload = 2;\n        msg.next = 3;\n        break;  \n    case 3:\n        msg.delay = msg.runtime3;\n        msg.payload = 3;\n        msg.next = 4;\n        break; \n        \n    case 4:\n        msg.delay = msg.runtime4;\n        msg.payload = 4;\n        msg.next = 5;\n        break; \n    case 5:\n        msg.delay = msg.runtime4;\n        msg.payload = 5;\n        msg.next = 1;\n        break; \n\n}\n\n    return msg;","outputs":1,"noerr":0,"x":500,"y":120,"wires":[["b40c043.9cbd778","3846424f.31e166","6aa67fb0.e1aca"]]},{"id":"a20bf21d.c17ac8","type":"change","z":"6c223db0.773914","name":"off","rules":[{"t":"set","p":"payload","pt":"msg","to":"OFF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":220,"wires":[["6aa67fb0.e1aca","b40c043.9cbd778"]]},{"id":"3846424f.31e166","type":"switch","z":"6c223db0.773914","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"4","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":230,"y":280,"wires":[["7ce8975b.74c168","a20bf21d.c17ac8"],["d64d6ce1.b96f8"]]},{"id":"7ce8975b.74c168","type":"change","z":"6c223db0.773914","name":"stop","rules":[{"t":"set","p":"reset","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":260,"wires":[["d64d6ce1.b96f8"]]},{"id":"d64d6ce1.b96f8","type":"delay","z":"6c223db0.773914","name":"","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":600,"y":280,"wires":[["c5192ec4.39a838"]]},{"id":"6aa67fb0.e1aca","type":"debug","z":"6c223db0.773914","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","x":700,"y":100,"wires":[]}]
Thanks for that idea! I didn't think of doing it that way with the reset function/command.
    case 5:
        msg.reset = true;
        break;
But.....
Don't worry. I'll nut it out.
