I am trying to create a chart with chart-image node. However, when I tried to use plugins field in the options context , chart-image node does not react. Not only create the image but also does not show any error. Actually, I upgrade chart-image today to 1.2.0 version , It worked a few times with some different errors and then stops working without any changes.
In this case, I need help for below;
1- Is there any bug or change on the chart-image node about adding plugins field. Because, this was working before with current configs.
2- How can I debug what is the issue, because the node does not reflect and does not show any error or output even I tied msg.debug nodes.
