Chart input object not working
I tried to build input object for the chart using official documentation. I read CSV file as one playload and using this function for creating data object from payload:
var dataval = [];
var i;
for (i = 0; i < msg.payload.length;i++){
// Convert to date
var s = msg.payload[i].Datum;
var sa = s.trim().replace(/\s/g,'').replace(" ","").split(".");
var fordat = sa[2] + "-" + sa[1] + "-" + sa[0];
var dat = new Date(fordat).getTime();                   // Final date
// Create X,Y object
var one = {"X": dat, "Y": parseFloat(msg.payload[i].Hodnota)};
dataval.push(one);
var chart = [{"data": dataval,"labels": ["XXX"],"series": ["X"]}];
return chart;
Final object looks like this:
But there still aren't any visible data in chart. What is wrong?
EDIT:
  1. I am using NR v0.20.8
  2. I am using basic chart node for official Dashboard to create a line chart
    3)Here is my flow:
[{"id":"d47a8733.87bbc","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"dd032bb.dcde4d8","type":"csv","z":"d47a8733.87bbc","name":"","sep":";","hdrin":true,"hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","x":459,"y":80,"wires":[["ac1074c7.b17b28"]]},{"id":"9ec7fb30.54dd3","type":"http request","z":"d47a8733.87bbc","name":"","method":"GET","ret":"txt","paytoqs":false,"url":"https://www.csob.cz/portal/lide/investicni-produkty/podilove-fondy/vsechny-fondy/detail-fondu?p_p_id=etnpwfundsdetail_WAR_etnpwfunds&p_p_lifecycle=2&p_p_state=normal&p_p_mode=view&p_p_resource_id=exportData&p_p_cacheability=cacheLevelPage&p_p_col_id=column-main&p_p_col_pos=1&p_p_col_count=10&_etnpwfundsdetail_WAR_etnpwfunds_dateToMillis=1568844000000&_etnpwfundsdetail_WAR_etnpwfunds_dateFromMillis=1253311200000&_etnpwfundsdetail_WAR_etnpwfunds_resources=1&_etnpwfundsdetail_WAR_etnpwfunds_isin=BE0174398892&_etnpwfundsdetail_WAR_etnpwfunds_groupId=4","tls":"","proxy":"","authType":"","x":294,"y":80,"wires":[["dd032bb.dcde4d8"]]},{"id":"7f236b29.fb8f44","type":"inject","z":"d47a8733.87bbc","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":123,"y":80,"wires":[["9ec7fb30.54dd3"]]},{"id":"fffe42b4.aeb9f","type":"ui_button","z":"d47a8733.87bbc","name":"","group":"46f66c9e.fd4ffc","order":0,"width":0,"height":0,"passthru":false,"label":"Start","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":134,"y":126,"wires":[["9ec7fb30.54dd3"]]},{"id":"ac1074c7.b17b28","type":"function","z":"d47a8733.87bbc","name":"","func":"\nvar dataval = [];\nvar i;\n\nfor (i = 0; i < msg.payload.length;i++){\n    \n    // Convert to date\n    var s = msg.payload[i].Datum;\n    var sa = s.trim().replace(/\\s/g,'').replace(\" \",\"\").split(\".\");\n    var fordat = sa[2] + \"-\" + sa[1] + \"-\" + sa[0];\n    var dat = new Date(fordat).getTime();                   // Final date\n    \n    // Create X,Y object\n    var one = {\"X\": dat, \"Y\": parseFloat(msg.payload[i].Hodnota)};\n    dataval.push(one);\n    \n}\n\nvar chart = [{\"data\": dataval,\"labels\": [\"XXX\"],\"series\": [\"X\"]}];\nreturn chart;","outputs":1,"noerr":0,"x":620,"y":79,"wires":[["a1525685.afb1a8","91e8ca0c.333eb8"]]},{"id":"a1525685.afb1a8","type":"debug","z":"d47a8733.87bbc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":792,"y":196,"wires":[]},{"id":"91e8ca0c.333eb8","type":"ui_chart","z":"d47a8733.87bbc","name":"","group":"46f66c9e.fd4ffc","order":1,"width":0,"height":0,"label":"Růstový","chartType":"line","legend":"true","xformat":"auto","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":809,"y":81,"wires":[[]]},{"id":"46f66c9e.fd4ffc","type":"ui_group","z":"","name":"ČSOB","tab":"aa5ace90.58f6d8","disp":true,"width":"6","collapse":false},{"id":"aa5ace90.58f6d8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
  1. what version of NR and node.js? (see startup log)
  2. what chart are you trying to use?
  3. can you provide your flow? (see How to share code or flow json)
See edit please.
You have an array as msg.data whereas the examples show the data as msg.payload.data
I am sorry but I don't see any examples with msg.payload.data. Can you show me some?
Go to the link that you gave in the first post.
Scroll to the bottom, import the flow...
Ok so I have change it so it the the same as examples, but it is still not working:
Ok I got it:
Your data is not sitting in an array.
try this:
var chart = [{"data": [dataval],"labels": ["XXX"],"series": ["X"]}];
Ah you found it :wink:
