Chart options: mixed charts and bars and multi axes
You cant do it with regular chart node, but it is possible with ui_template. Quick example.
[{"id":"13e0b8f1.dfe687","type":"ui_template","z":"b633308d.4a91a","group":"4552fe72.fdfa5","name":"Line Chart","order":4,"width":"15","height":"10","format":"","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":690,"y":700,"wires":[[]]},{"id":"33be001d.f6af3","type":"inject","z":"b633308d.4a91a","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"0.62","x":250,"y":700,"wires":[["167e0e6d.2acf32"]]},{"id":"167e0e6d.2acf32","type":"function","z":"b633308d.4a91a","name":"","func":"\nvar m_first = []\nvar m_second = []\nvar m_labels = []\nvar a\nvar startTime = 1577836800000\nfor(x=1;x<=25;x++){\n    a = {x: new Date(startTime), y: Math.random() * 300}\n    m_first.push(a)\n    startTime += 86400000\n}\nstartTime = 1577836800000\nfor(x=1;x<=25;x++){\n    a = -2.5 + Math.random() * 5\n    m_second.push(a)\n    startTime += 86400000\n    m_labels.push(\"label_\"+x)\n}\n\nmsg.payload = {}\nmsg.payload.first = JSON.stringify(m_first)\nmsg.payload.second = JSON.stringify(m_second)\nmsg.payload.labels = JSON.stringify(m_labels)\nreturn msg;\n","outputs":1,"noerr":0,"x":390,"y":700,"wires":[["7f227cac.38d054"]]},{"id":"807a85c.8761e78","type":"debug","z":"b633308d.4a91a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":670,"y":740,"wires":[]},{"id":"7f227cac.38d054","type":"template","z":"b633308d.4a91a","name":"","field":"template","fieldType":"msg","format":"html","syntax":"mustache","template":"<canvas id=\"myChart\" width=600 height =300></canvas>\n<script>\nvar textcolor = getComputedStyle(document.documentElement).getPropertyValue('--nr-dashboard-widgetTextColor');\nvar gridcolor = getComputedStyle(document.documentElement).getPropertyValue('--nr-dashboard-groupBorderColor');\nvar linecolors = ['#009900','#889900']\n\nvar ctx = document.getElementById('myChart').getContext('2d');\nvar chart = new Chart(ctx, {\n    // The type of chart we want to create\n    type: 'bar',\n\n    // The data for our dataset\n    data: {\n        labels: {{{payload.labels}}},\n        datasets: [\n            {\n                type:'line',\n                label: 'First',\n                backgroundColor: linecolors[0],\n                borderColor: linecolors[0],\n                data: {{{payload.first}}},\n                yAxisID: 'left-y-axis',\n                steppedLine: false,\n                fill: false,\n                borderWidth: 1\n            },\n            {\n                type:'bar',\n                label: 'Second',\n                \n                backgroundColor: linecolors[1],\n                borderColor: linecolors[1],\n                data: {{{payload.second}}},\n                yAxisID: 'right-y-axis',\n                barPercentage: 0.5,\n                barThickness: 6,\n                maxBarThickness: 8,\n                minBarLength: 2,\n            }\n        ]\n    },\n\n    // Configuration options go here\n    options: {\n        scales: {\n            yAxes: [\n                {\n                    gridLines :{display:false},\n                    id: 'left-y-axis',\n                    type: 'linear',\n                    position: 'left',\n                    ticks: {\n                        fontColor: linecolors[0]\n                    }\n                },\n                {\n                    gridLines :{zeroLineColor:gridcolor,color:gridcolor,lineWidth:0.5},\n                    id: 'right-y-axis',\n                    type: 'linear',\n                    position: 'right',\n                    ticks: {\n                        fontColor:linecolors[1]\n                    }\n                }\n            ],\n            xAxes: [\n                {\n                    gridLines :{zeroLineColor:gridcolor,color:gridcolor,lineWidth:0.5},\n                    \n                    ticks: {\n                        fontColor:textcolor\n                    }\n                }\n            ]\n        }\n    }\n});\n</script>\n","output":"str","x":520,"y":700,"wires":[["13e0b8f1.dfe687","807a85c.8761e78"]]},{"id":"4552fe72.fdfa5","type":"ui_group","z":"","name":"Chart","tab":"2ecb90e3.af7a5","order":3,"disp":true,"width":"15","collapse":false},{"id":"2ecb90e3.af7a5","type":"ui_tab","z":"","name":"Ovens","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
