Chart style fixing
I use Amcharts heat map chart and need to change one property.
I find from dev tool right place
this is original
fixed in dev tools
I cant get right colors chart, if I try to write this overriding in template?
.nr-dashboard-theme .nr-dashboard-template path {
1. /* fill: #1286f3; */
I try none and opacity in properties
flow
        "id": "551810e024fd25e4",
        "type": "tab",
        "label": "Chart",
        "disabled": false,
        "info": "",
        "env": []
        "id": "4fb7c6f9c4b6301a",
        "type": "template",
        "z": "551810e024fd25e4",
        "field": "template",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "<style>\n    #chartdiv {\n        width: 100%;\n        height: 250px;\n        background-color: antiquewhite;\n    }\n</style>\n<script src=\"https://cdn.amcharts.com/lib/4/core.js\"></script>\n<script src=\"https://cdn.amcharts.com/lib/4/charts.js\"></script>\n<script src=\"https://cdn.amcharts.com/lib/4/themes/animated.js\"></script>\n<div id=\"chartdiv\"></div>\n<script>\nam4core.ready(function() {\nam4core.disposeAllCharts();\nam4core.useTheme(am4themes_animated);\nchart = am4core.create(\"chartdiv\", am4charts.XYChart);\nchart.responsive.enabled = true;\n//chart.data ={{{data}}};\n chart.data = [{\n        \"category\": \"Research\",\n        \"value\": 450\n    }, {\n        \"category\": \"Marketing\",\n        \"value\": 1200\n    }, {\n        \"category\": \"Distribution\",\n        \"value\": 1850\n    }, {\n        \"category\": \"HR\",\n        \"value\": 850\n    }, {\n        \"category\": \"Sales\",\n        \"value\": 499\n    }, {\n        \"category\": \"Support\",\n        \"value\": 871\n    }, {\n        \"category\": \"Other\",\n        \"value\": 512\n    }];    \n\nvar categoryAxis = chart.xAxes.push(new am4charts.CategoryAxis());\ncategoryAxis.dataFields.category = \"category\";\ncategoryAxis.renderer.grid.template.location = 0;\ncategoryAxis.renderer.minGridDistance = 30;\n\nvar valueAxis = chart.yAxes.push(new am4charts.ValueAxis());\n\nvar series = chart.series.push(new am4charts.ColumnSeries());\nseries.dataFields.value = \"value\";\nseries.dataFields.valueY = \"value\";\nseries.dataFields.categoryX = \"category\";\nseries.columns.template.strokeWidth = 0;\n\nseries.heatRules.push({\n    \"target\": series.columns.template,\n    \"property\": \"fill\",\n    \"min\": am4core.color(\"#0000FF\"),\n    \"max\": am4core.color(\"#FF0000\")\n    });\n\nvar heatLegend = chart.createChild(am4charts.HeatLegend);\nheatLegend.series = series;\nheatLegend.width = am4core.percent(100);\nheatLegend.valueAxis.renderer.labels.template.fontSize = 20;\n   heatLegend.valueAxis.renderer.minGridDistance = 30;\nheatLegend.markerCount = 10;\n});\n</script>",
        "output": "str",
        "x": 580,
        "y": 300,
                "cb3a935d55a72860"
        "id": "cb3a935d55a72860",
        "type": "ui_template",
        "group": "6d809819c563b590",
        "order": 1,
        "width": 24,
        "height": 12,
        "format": "<div ng-bind-html=\"msg.payload\"></div>\n",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 780,
        "y": 300,
        "id": "9c23377abb5a099e",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 320,
        "y": 300,
                "4fb7c6f9c4b6301a"
        "id": "6d809819c563b590",
        "type": "ui_group",
        "name": "Test",
        "tab": "7b1488e71786be30",
        "order": 1,
        "disp": true,
        "width": 24,
        "collapse": false,
        "className": ""
        "id": "7b1488e71786be30",
        "type": "ui_tab",
        "name": "Chart",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
find solution!
https://github.com/node-red/node-red-dashboard/issues/447
