hi
I'm new in nodered and nodeJS
I need to know how to check if message in array like python
var my_array = ["a", "b", "c", "d", "e"]
msg.payload = "c"
if msg.payload in my_array {do something}
how to coding
Thank you
hi
msg.payload = "c"
how to coding
Thank you
If you are new to node-red, I would suggest to learn this "the node-red way", feed the payload (containing the array) into a split node (it splits the array into separate messages) and then use a switch node after that to "route" the message a certain direction. The switch node acts like an "if".
This scenario depends on what you actually want to achieve.
You could use includes() method
let my_array = ["a", "b", "c", "d", "e"]
msg.payload = "c"
if (my_array.includes(msg.payload){
do something.......
wow.. that work perfectly thank you now I have learned new thing ![]()
