Hello i need some help , how to check casenamemax inside any array [0][1][2]........
example if case == 01 send to mqtt ........ with all index data status,imei,casenamemax
or case == 02,03 ...... send
Thank you for reply
Thank you for reply
Use the function node and do it in javascript
yeah i use it in javascript and i dont know how to write it thx sir
var l = msg.payload[0].length;
for (var i = 0; i < l; i++) {
node.send({
payload: msg.payload[0][i].casenamemax
I try this code can output same as i send before
The msg.payload[0][i] bit is wrong and the length calculation, and also you are returning the original message at the end. Something like this may be better.
var l = msg.payload.length;
node.send({
payload: msg.payload[i].casenamemax
return null;
For the future you can debug your code using node.warn(). So after the var l = .. line you could have put
node.warn("l is " + l);
and it would have displayed the value of l in the debug pane. By adding warn statements through the code you can find which bit is not working.
