hi, I doubt 2b509 is the full value as it is an odd number of bytes, starting at offset of 7.5th byte in the data 0251fc289a000002b509cef8
It is more likely to be the 7th + 8th bytes (16 bit) e.g. 02b5 (as is circled in your picture)
Anyhow, that's the finer details - for starters, I will show you how you can pick & select any value you want using the buffer parser node...
Now i realise that ^ value is potentially not what you expect, but without a specification / manual for your HVAC (e.g. byte swapping?, int?, uint? etc) - I randomly chose 16 bit UINT (big endian)
example flow...
[{"id":"58bdc980.c562e8","type":"inject","z":"c9ca6ac7.25b568","name":"0251fc209a000002b5095d55","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0251fc289a000002b509cef8","payloadType":"str","x":1220,"y":100,"wires":[["7544a660.fcb0e8"]]},{"id":"816105c6.6e6208","type":"inject","z":"c9ca6ac7.25b568","name":"0251fc289a000002b509cef8","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0251fc289a000002b509cef8","payloadType":"str","x":1220,"y":140,"wires":[["7544a660.fcb0e8"]]},{"id":"7544a660.fcb0e8","type":"buffer-parser","z":"c9ca6ac7.25b568","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"address","offset":0,"length":1,"offsetbit":0,"scale":1,"mask":""},{"type":"uint16be","name":"data","offset":7,"length":1,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":1450,"y":120,"wires":[["309f9087.49213"]]},{"id":"309f9087.49213","type":"debug","z":"c9ca6ac7.25b568","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1470,"y":160,"wires":[]}]
