Clear Dynamically Form UI
I Want To Clear Form Manually.
My Form Contain 2Textinput ,UserName And Password.
I Want Clear UserName and Password In The Form Manually When Accept Password.
From the output of the form node, wire in a change node which sends msg.UserName = '' and msg.Password = ''. Might need a switch node after the form as well to ignore any blanks that get passed through depending on how it works.
Hi
Thanks For Reply
I'll test and give you the answer.
The Result Display In Debug Node == Undefined
I think you want it the other way round.. Set msg.user to msg.payload. As that button will only send a payload (and maybe a topic)
I Want Clear The Form ui Manually
payload Button is == ""
But Not Working and Form Not Clear
My From Contain 2textInput User And Pass
I Want Clear User And Pass Textinput On Form
It doesn't seem to work on the form node.
I prefer using the text input ones, then using my own buttons etc.
The flow below shows how to do this with a text input form.
[{"id":"4b1c894e.d283b8","type":"tab","label":"Flow 5","disabled":false,"info":""},{"id":"b2971630.6e5108","type":"ui_button","z":"4b1c894e.d283b8","name":"","group":"b98a1e99.eaab7","order":5,"width":"6","height":"1","passthru":true,"label":"Clear","tooltip":"","color":"","bgcolor":"","icon":"close","payload":"' '","payloadType":"str","topic":"","x":290,"y":100,"wires":[["612b7dcd.8bc004"]]},{"id":"98626d19.9b811","type":"ui_text_input","z":"4b1c894e.d283b8","name":"","label":"Scan ID Card Barcode","tooltip":"","group":"b98a1e99.eaab7","order":3,"width":"6","height":"1","passthru":true,"mode":"text","delay":"1","topic":"","x":680,"y":100,"wires":[[]]},{"id":"612b7dcd.8bc004","type":"change","z":"4b1c894e.d283b8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":100,"wires":[["98626d19.9b811"]]},{"id":"b98a1e99.eaab7","type":"ui_group","z":"","name":"Default","tab":"d1f0aded.08bff","disp":true,"width":"6","collapse":false},{"id":"d1f0aded.08bff","type":"ui_tab","z":"","name":"test","icon":"dashboard","disabled":false,"hidden":false}]
Thanks for your Reply I found the answer...
What was the solution?
This is the solution:
You can do this to explicitly clear the form by using this in a function node:
msg={};
msg.payload={};
msg.payload.propertyNameInForm='';
