Hi @all out there!
I am nearly new on red-node. Or it seems to me as if...
I am using node-red : file to write data in a file. Fine and it works.
But (There will allways be a but..).
The file seems not to be updated in my file system (RP4). After waiting, maybe after the flows has ended or started again, the file updates. I also tried to send the filename via msg.filename, same effect.
Question: Can I force close file? Or where is my fault? Only a slow raspberry?
(See the flow for testing below...)
Thanks f reading and any hint!
Dirk
        "id": "3b49d206.22100e",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": ""
        "id": "63d0071f.d1f498",
        "type": "inject",
        "z": "3b49d206.22100e",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 80,
                "e3b88583.644ca8"
        "id": "cecce8d5.6464d8",
        "type": "file",
        "filename": "//etc/openhab2/html/nr_message_001.html",
        "appendNewline": false,
        "createDir": false,
        "overwriteFile": "true",
        "encoding": "none",
        "x": 570,
        "y": 220,
                "e76365a3.a55b28",
                "783926c.f311ed8"
        "id": "3ee8c328.aa0bdc",
        "type": "function",
        "name": "set Text in iFrame",
        "func": "let textValue = \"\"\ntextValue=\"<!doctype html>\"\ntextValue+=\"<html>\"\ntextValue+=\"<head>\"\ntextValue+=\"<meta charset='utf-8'>\"\ntextValue+=\"<meta name='viewport# content='width=device-width, initial-scale=1.0'>\"\ntextValue+=\"<title>Beschreibung der Seite (erscheint in der Titelzeile des Browsers)</title>\"\ntextValue+=\"</head>\"\ntextValue+=\"<body>\"\ntextValue+=\"<p>\"\n\nif (global.get('timerTime') >= 0)\n{\n    textValue+=\"Timer: \" + global.get('timerTime');\n    global.set('timerTime', global.get('timerTime')-1);\n}\nelse\n    textValue+=\"Timer ist abgelaufen!\" + global.get('timerTime');\n\ntextValue+=\"</p>\"\ntextValue+=\"</body>\"\ntextValue+=\"</html>\";\nlet msg1 = {payload: textValue};\n//msg1 = {filename: \"//etc/openhab2/html/nr_message_001.html\"};\nlet msg2 = {payload: null};\nif (global.get('timerTime') > 0)\n    msg2 = {payload: global.get('timerTime')};\nreturn [msg1,msg2];",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 210,
        "y": 220,
                "cecce8d5.6464d8",
                "103ccd57.3e4593"
                "32205b50.ad7bc4",
                "d51da409.3506b8"
        "id": "85f312ec.288ef",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "6",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "minute",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "x": 600,
        "y": 140,
                "3ee8c328.aa0bdc"
        "id": "103ccd57.3e4593",
        "type": "debug",
        "name": "m_01",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 310,
        "y": 300,
        "id": "32205b50.ad7bc4",
        "type": "function",
        "name": "Trigger delay if needed again",
        "func": "if (msg.payload != null)\n    return msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 240,
        "y": 140,
                "85f312ec.288ef"
        "id": "e3b88583.644ca8",
        "type": "function",
        "name": "set delay for test to 15 ",
        "func": "global.set('timerTime', 15);\nmsg.payload = 15;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 360,
        "y": 80,
                "85f312ec.288ef"
        "id": "d51da409.3506b8",
        "type": "debug",
        "name": "m_02",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 310,
        "y": 340,
        "id": "e76365a3.a55b28",
        "type": "debug",
        "name": "m_03",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 770,
        "y": 300,
        "id": "783926c.f311ed8",
        "type": "function",
        "func": "\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 540,
        "y": 320,
