Code adds key:property to global varible
Please help me here why does obj.keys. --- item --- get created ?
const obj = global.get("glue." + msg.name + "." + msg.action); // msg.action toggle has run
for (var keys in obj) {
    msg = obj[keys];
    msg.item = keys;
    // obj.item is created in Glue
    delete obj[keys].item  // I now have to delete it
    node.send(msg);
return null;
below part of the global variable glue.pushButton
    "toggle": {
        "BellButton": {
            "toggle": {
                "Buzzer": {
                    "handler": "buzzer",
                    "item": "Buzzer"
                "BellRinger": {
                    "enabled": false,
                    "handler": "delay",
                    "timeOff": 200,
                    "item": "BellRinger"
        "tester": {
            "pulse": {
                "Bell": {
                    "hendler": "delay",
                    "timeOff": 200
routine toggle has bin called hence toggle.BellButton.toggle.buzzer ---> item:Buzzer is added to it
i am wondering why this happens?
EDIT; Thanks to Steve-Mcl
    msg = RED.util.cloneMessage(obj[keys]);
    msg.item = keys;
    node.send(msg);
This is due to objects being copied by reference.
    msg = obj[keys]; // This line says "point msg to the SAME memory location as obj[keys]
    msg.item = keys; // this line is essentially the same as   obj[keys].item = keys
try instead...
    msg.item = RED.util.cloneMessage(obj[keys]);
    node.send(msg);
