Who know about code function for change format data from Kepware like picture below
to API of Power BI format as
"RANDOM_NUM" :98.6
Thank you.
??? You just write some javascript code, pick the value you are interested in from the incoming message, then you just insert it and format it in a new message that you send
Where do you find/see 98.6 ??
v = RANDOM_NUM
In a change node you can
set msg. payload[0].RANDOM_NUM
to value of msg. payload.values[0].v
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value to any data item.
There are many ways, however, in the interest of speed, a function node containing ...
msg.payload = [ { RANDOM_NUM: msg.payload.values[0].v } ]
return msg
... will work.
Also possible with a change node, a template node and others.
In future, please post sample data instead of a screenshot (we can use sample data in a working example without having to type stuff out)
msg.payload.values[0].v) and copying usable dataThere’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Thank you very much. It very clear.
