I am setting up a flow for automating my greenhouse using a pi 3.
I have some prior experience coding in Qt c++ but it has been a few years...
I want to return 'true' or 'false' to operate a switch but due to my lack of coding skills 'result' ends up 'undefined' and msg.payload returns 'undefined'.
I hope someone can set me straight here on setting the variables in functions...
Best regards,
Jon
//gets the temp and humidity reading from the DHT11
var hum = msg.humidity;
var tmp = msg.payload;
var result;
setInterval(function(){
var hour = new Date().getHours();
if (hour >= 8 && hour < 18) {
controlMister();
} , 1000*60);
function controlMister(){
if(hum < 60 && tmp > 10)
result = "false";
else
result = "true";
//node.warn(result);
node.warn(result);
msg.payload = result;
How do you use code tags on this forum?
Jon
Try:
var result;
controlMister();
}, 1000*60);
if(hum < 60 && tmp > 10) {
result = "false";
} else {
result = "true";
msg.payload=result;
node.send(msg);
//msg.payload = result;
return null;
to test it now you should change this line
if (hour >= 8 && hour < 20) {
Thank you!
Works as intended!
Cheers,
Jon
Why is 'result' (which I assumed was a global since I added it outside the function) data not maintained/exposed outside of the function?
result is a node local var, if you need a global, you have to use global.get() and global.set().
https://nodered.org/docs/writing-functions#storing-data
... and in your case here when leaving the function node, result isn't set.
AHA!
Thank you very much.
Cheers,
Jon
