Combine 2 arrays to feed one graph
Hey Guys
I need some of your expertise as I have very little with coding, trying to merge 2 arrarys so they can be shown on a graph. Have attach flow with sample data, i have managed to merge them but not in a way that will show both at the same time so i can compare the two on the same graph, i have searched through google and the forum and found lots of methods, but could find none to merge the series and setup the arrays. The flow i created at present will merge them but no graph, can show one at a time connecting the chart to the temple bypassing the join.
node
        "id": "40490139.b2586",
        "type": "inject",
        "z": "955d7c60a74b88fb",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "pac",
        "payload": "[{\"x\":1691958309,\"y\":11},{\"x\":1691958609,\"y\":18},{\"x\":1691958909,\"y\":30},{\"x\":1691959209,\"y\":40},{\"x\":1691959509,\"y\":51},{\"x\":1691959809,\"y\":63},{\"x\":1691960109,\"y\":72},{\"x\":1691960409,\"y\":81},{\"x\":1691960709,\"y\":96},{\"x\":1691961009,\"y\":129},{\"x\":1691961309,\"y\":169},{\"x\":1691961609,\"y\":202},{\"x\":1691961909,\"y\":275},{\"x\":1691962209,\"y\":359},{\"x\":1691962509,\"y\":415},{\"x\":1691962809,\"y\":464},{\"x\":1691963109,\"y\":548},{\"x\":1691963409,\"y\":607},{\"x\":1691963709,\"y\":648},{\"x\":1691964009,\"y\":646},{\"x\":1691964309,\"y\":673},{\"x\":1691964609,\"y\":701},{\"x\":1691964909,\"y\":805},{\"x\":1691965209,\"y\":861},{\"x\":1691965509,\"y\":895},{\"x\":1691965809,\"y\":918},{\"x\":1691966109,\"y\":945},{\"x\":1691966409,\"y\":967},{\"x\":1691966709,\"y\":991},{\"x\":1691967009,\"y\":1016},{\"x\":1691967309,\"y\":1037},{\"x\":1691967609,\"y\":1054},{\"x\":1691967909,\"y\":1076},{\"x\":1691968209,\"y\":1092},{\"x\":1691968509,\"y\":1111},{\"x\":1691968809,\"y\":1133},{\"x\":1691969109,\"y\":1150},{\"x\":1691969409,\"y\":1163},{\"x\":1691969709,\"y\":1180},{\"x\":1691970009,\"y\":1191},{\"x\":1691970309,\"y\":1203},{\"x\":1691970609,\"y\":1211},{\"x\":1691970909,\"y\":1229},{\"x\":1691971209,\"y\":1245},{\"x\":1691971509,\"y\":1255},{\"x\":1691971809,\"y\":1272},{\"x\":1691972109,\"y\":1282},{\"x\":1691972409,\"y\":1290},{\"x\":1691972709,\"y\":1303},{\"x\":1691973009,\"y\":1324},{\"x\":1691973309,\"y\":1340},{\"x\":1691973609,\"y\":1344},{\"x\":1691973909,\"y\":1351},{\"x\":1691974209,\"y\":1355},{\"x\":1691974509,\"y\":1351},{\"x\":1691974809,\"y\":1355},{\"x\":1691975109,\"y\":1365},{\"x\":1691975409,\"y\":1371},{\"x\":1691975709,\"y\":1447},{\"x\":1691976009,\"y\":1602},{\"x\":1691976309,\"y\":1766},{\"x\":1691976609,\"y\":1913},{\"x\":1691976910,\"y\":1916},{\"x\":1691977209,\"y\":1990},{\"x\":1691977509,\"y\":2063},{\"x\":1691977809,\"y\":1988},{\"x\":1691978109,\"y\":1984},{\"x\":1691978409,\"y\":1980},{\"x\":1691978709,\"y\":1984},{\"x\":1691979009,\"y\":2169},{\"x\":1691979309,\"y\":2164},{\"x\":1691979609,\"y\":1985},{\"x\":1691979909,\"y\":1991},{\"x\":1691980209,\"y\":1987},{\"x\":1691980509,\"y\":1990},{\"x\":1691980810,\"y\":2162},{\"x\":1691981109,\"y\":2157},{\"x\":1691981409,\"y\":1989},{\"x\":1691981709,\"y\":1985},{\"x\":1691982009,\"y\":1990},{\"x\":1691982309,\"y\":1995},{\"x\":1691982609,\"y\":2092},{\"x\":1691982909,\"y\":2062},{\"x\":1691983209,\"y\":1988},{\"x\":1691983509,\"y\":1992},{\"x\":1691983809,\"y\":1994},{\"x\":1691984109,\"y\":1988},{\"x\":1691984409,\"y\":1975},{\"x\":1691984710,\"y\":1946},{\"x\":1691985009,\"y\":1897},{\"x\":1691985309,\"y\":1561},{\"x\":1691985609,\"y\":1359},{\"x\":1691985909,\"y\":1158},{\"x\":1691986209,\"y\":1115},{\"x\":1691986509,\"y\":1058},{\"x\":1691986809,\"y\":954},{\"x\":1691987109,\"y\":924},{\"x\":1691987409,\"y\":889},{\"x\":1691987709,\"y\":795},{\"x\":1691988009,\"y\":1134},{\"x\":1691988309,\"y\":1059},{\"x\":1691988609,\"y\":744},{\"x\":1691988909,\"y\":699},{\"x\":1691989210,\"y\":586},{\"x\":1691989509,\"y\":702},{\"x\":1691989809,\"y\":714},{\"x\":1691990109,\"y\":724},{\"x\":1691990409,\"y\":576},{\"x\":1691990709,\"y\":497},{\"x\":1691991008,\"y\":498},{\"x\":1691991309,\"y\":582},{\"x\":1691991610,\"y\":560},{\"x\":1691991909,\"y\":571},{\"x\":1691992209,\"y\":480},{\"x\":1691992509,\"y\":348},{\"x\":1691992809,\"y\":356},{\"x\":1691993109,\"y\":328},{\"x\":1691993409,\"y\":303},{\"x\":1691993709,\"y\":279},{\"x\":1691994009,\"y\":219},{\"x\":1691994309,\"y\":202},{\"x\":1691994609,\"y\":186},{\"x\":1691994909,\"y\":142},{\"x\":1691995209,\"y\":111},{\"x\":1691995510,\"y\":56},{\"x\":1691995809,\"y\":63},{\"x\":1691996109,\"y\":64},{\"x\":1691996409,\"y\":49},{\"x\":1691996709,\"y\":38},{\"x\":1691997009,\"y\":27},{\"x\":1691997309,\"y\":20},{\"x\":1691997609,\"y\":14},{\"x\":1691997909,\"y\":10}]",
        "payloadType": "json",
        "x": 170,
        "y": 100,
                "c386cfe7a7db81c8"
        "id": "55644378.d2d494",
        "type": "join",
        "mode": "custom",
        "build": "object",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "num",
        "reduceFixup": "",
        "x": 470,
        "y": 160,
                "19d1f9f7.86f8ce",
                "a33ca4bba1eb8be4"
        "id": "24e8532e.fd99bc",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "pac1",
        "payload": "[{\"x\":1691785570,\"y\":0},{\"x\":1691785576,\"y\":0},{\"x\":1691785809,\"y\":15},{\"x\":1691786109,\"y\":18},{\"x\":1691786409,\"y\":31},{\"x\":1691786709,\"y\":40},{\"x\":1691787009,\"y\":49},{\"x\":1691787309,\"y\":58},{\"x\":1691787609,\"y\":64},{\"x\":1691787909,\"y\":76},{\"x\":1691788209,\"y\":106},{\"x\":1691788509,\"y\":147},{\"x\":1691788809,\"y\":184},{\"x\":1691789109,\"y\":197},{\"x\":1691789409,\"y\":270},{\"x\":1691789709,\"y\":376},{\"x\":1691790009,\"y\":429},{\"x\":1691790309,\"y\":526},{\"x\":1691790609,\"y\":573},{\"x\":1691790909,\"y\":612},{\"x\":1691791209,\"y\":645},{\"x\":1691791509,\"y\":664},{\"x\":1691791809,\"y\":689},{\"x\":1691792109,\"y\":715},{\"x\":1691792409,\"y\":810},{\"x\":1691792709,\"y\":851},{\"x\":1691793009,\"y\":886},{\"x\":1691793309,\"y\":910},{\"x\":1691793609,\"y\":941},{\"x\":1691793909,\"y\":976},{\"x\":1691794209,\"y\":1006},{\"x\":1691794509,\"y\":1028},{\"x\":1691794809,\"y\":1056},{\"x\":1691795109,\"y\":1079},{\"x\":1691795409,\"y\":1102},{\"x\":1691795709,\"y\":1113},{\"x\":1691796009,\"y\":1133},{\"x\":1691796309,\"y\":1149},{\"x\":1691796609,\"y\":1165},{\"x\":1691796909,\"y\":1176},{\"x\":1691797209,\"y\":1192},{\"x\":1691797509,\"y\":1211},{\"x\":1691797809,\"y\":1221},{\"x\":1691798109,\"y\":1236},{\"x\":1691798409,\"y\":1249},{\"x\":1691798709,\"y\":1265},{\"x\":1691799009,\"y\":1275},{\"x\":1691799309,\"y\":1288},{\"x\":1691799609,\"y\":1293},{\"x\":1691799909,\"y\":1309},{\"x\":1691800208,\"y\":1316},{\"x\":1691800509,\"y\":1330},{\"x\":1691800809,\"y\":1339},{\"x\":1691801109,\"y\":1330},{\"x\":1691801409,\"y\":1347},{\"x\":1691801709,\"y\":1350},{\"x\":1691802009,\"y\":1366},{\"x\":1691802309,\"y\":1363},{\"x\":1691802609,\"y\":1368},{\"x\":1691802909,\"y\":1599},{\"x\":1691803209,\"y\":1754},{\"x\":1691803509,\"y\":1750},{\"x\":1691803809,\"y\":1736},{\"x\":1691804109,\"y\":1779},{\"x\":1691804409,\"y\":1789},{\"x\":1691804709,\"y\":1866},{\"x\":1691805009,\"y\":1997},{\"x\":1691805309,\"y\":1986},{\"x\":1691805609,\"y\":1987},{\"x\":1691805909,\"y\":1981},{\"x\":1691806209,\"y\":1988},{\"x\":1691806509,\"y\":1972},{\"x\":1691806809,\"y\":1986},{\"x\":1691807109,\"y\":1979},{\"x\":1691807409,\"y\":1956},{\"x\":1691807709,\"y\":1958},{\"x\":1691808009,\"y\":1958},{\"x\":1691808309,\"y\":1945},{\"x\":1691808609,\"y\":1945},{\"x\":1691808909,\"y\":1920},{\"x\":1691809209,\"y\":1898},{\"x\":1691809509,\"y\":1900},{\"x\":1691809809,\"y\":1888},{\"x\":1691810109,\"y\":1857},{\"x\":1691810409,\"y\":1847},{\"x\":1691810709,\"y\":1832},{\"x\":1691811009,\"y\":1787},{\"x\":1691811309,\"y\":1782},{\"x\":1691811609,\"y\":1746},{\"x\":1691811909,\"y\":1707},{\"x\":1691812209,\"y\":1673},{\"x\":1691812509,\"y\":1441},{\"x\":1691812810,\"y\":1147},{\"x\":1691813109,\"y\":1009},{\"x\":1691813409,\"y\":1108},{\"x\":1691813709,\"y\":1049},{\"x\":1691814009,\"y\":963},{\"x\":1691814309,\"y\":941},{\"x\":1691814609,\"y\":522},{\"x\":1691814909,\"y\":229},{\"x\":1691815209,\"y\":1214},{\"x\":1691815509,\"y\":1064},{\"x\":1691815809,\"y\":776},{\"x\":1691816109,\"y\":678},{\"x\":1691816409,\"y\":562},{\"x\":1691816708,\"y\":681},{\"x\":1691817009,\"y\":738},{\"x\":1691817309,\"y\":773},{\"x\":1691817609,\"y\":683},{\"x\":1691817909,\"y\":553},{\"x\":1691818209,\"y\":596},{\"x\":1691818510,\"y\":673},{\"x\":1691818809,\"y\":381},{\"x\":1691819109,\"y\":593},{\"x\":1691819409,\"y\":508},{\"x\":1691819709,\"y\":279},{\"x\":1691820009,\"y\":211},{\"x\":1691820309,\"y\":133},{\"x\":1691820609,\"y\":201},{\"x\":1691820909,\"y\":267},{\"x\":1691821209,\"y\":214},{\"x\":1691821509,\"y\":179},{\"x\":1691821809,\"y\":200},{\"x\":1691822109,\"y\":149},{\"x\":1691822409,\"y\":94},{\"x\":1691822709,\"y\":89},{\"x\":1691823009,\"y\":69},{\"x\":1691823309,\"y\":46},{\"x\":1691823609,\"y\":44},{\"x\":1691823909,\"y\":41},{\"x\":1691824209,\"y\":29},{\"x\":1691824509,\"y\":17},{\"x\":1691824809,\"y\":9},{\"x\":1691825109,\"y\":0}]",
        "x": 170,
        "y": 220,
                "eb47eedbbb19b611"
        "id": "a33ca4bba1eb8be4",
        "type": "ui_chart",
        "group": "e0023fff.6f3a4",
        "order": 30,
        "width": 0,
        "height": 0,
        "label": "chart",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "86400",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": true,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 490,
        "y": 200,
                "19d1f9f7.86f8ce"
        "id": "c386cfe7a7db81c8",
        "type": "json",
        "action": "str",
        "pretty": false,
        "x": 210,
        "y": 140,
                "65ccea3b5925d0fa"
        "id": "eb47eedbbb19b611",
        "type": "json",
        "action": "str",
        "pretty": false,
        "x": 210,
        "y": 180,
                "fcf70a1bcbc6911e"
        "id": "65ccea3b5925d0fa",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "syntax": "mustache",
        "template": "[{\n        \"series\": [\n            \"PAC\"\n        ],\n        \"data\": [\n            {{{payload}}}\n        \n        ],\n        \"labels\": [\n            \"\"\n        ]\n    }\n]",
        "output": "json",
        "x": 340,
        "y": 140,
                "55644378.d2d494"
        "id": "fcf70a1bcbc6911e",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "template": "[{\n        \"series\": [\n            \"PAC1\"\n        ],\n        \"data\": [\n            {{{payload}}}\n        \n        ],\n        \"labels\": [\n            \"\"\n        ]\n    }\n]",
        "output": "json",
        "x": 340,
        "y": 180,
                "55644378.d2d494"
        "id": "e0023fff.6f3a4",
        "type": "ui_group",
        "name": "Web",
        "tab": "3a6d7b89.06bd5c",
        "order": 1,
        "disp": false,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "3a6d7b89.06bd5c",
        "type": "ui_tab",
        "name": "PV",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Below is a mock up of what I assume the output should look like
node1
Thanks Dan
HI
You need to join the messages first then you can use them in the template.
Your timestamps are unix seconds, the chart takes unix milliseconds.
Here are two examples. The first is how to do it using a template, but uncorrected timestamps.
The second uses a change node and JSONata with correction for timestamps
[{"id":"40490139.b2586","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac","payload":"[{\"x\":1691958309,\"y\":11},{\"x\":1691958609,\"y\":18},{\"x\":1691958909,\"y\":30},{\"x\":1691959209,\"y\":40},{\"x\":1691959509,\"y\":51},{\"x\":1691959809,\"y\":63},{\"x\":1691960109,\"y\":72},{\"x\":1691960409,\"y\":81},{\"x\":1691960709,\"y\":96},{\"x\":1691961009,\"y\":129},{\"x\":1691961309,\"y\":169},{\"x\":1691961609,\"y\":202},{\"x\":1691961909,\"y\":275},{\"x\":1691962209,\"y\":359},{\"x\":1691962509,\"y\":415},{\"x\":1691962809,\"y\":464},{\"x\":1691963109,\"y\":548},{\"x\":1691963409,\"y\":607},{\"x\":1691963709,\"y\":648},{\"x\":1691964009,\"y\":646},{\"x\":1691964309,\"y\":673},{\"x\":1691964609,\"y\":701},{\"x\":1691964909,\"y\":805},{\"x\":1691965209,\"y\":861},{\"x\":1691965509,\"y\":895},{\"x\":1691965809,\"y\":918},{\"x\":1691966109,\"y\":945},{\"x\":1691966409,\"y\":967},{\"x\":1691966709,\"y\":991},{\"x\":1691967009,\"y\":1016},{\"x\":1691967309,\"y\":1037},{\"x\":1691967609,\"y\":1054},{\"x\":1691967909,\"y\":1076},{\"x\":1691968209,\"y\":1092},{\"x\":1691968509,\"y\":1111},{\"x\":1691968809,\"y\":1133},{\"x\":1691969109,\"y\":1150},{\"x\":1691969409,\"y\":1163},{\"x\":1691969709,\"y\":1180},{\"x\":1691970009,\"y\":1191},{\"x\":1691970309,\"y\":1203},{\"x\":1691970609,\"y\":1211},{\"x\":1691970909,\"y\":1229},{\"x\":1691971209,\"y\":1245},{\"x\":1691971509,\"y\":1255},{\"x\":1691971809,\"y\":1272},{\"x\":1691972109,\"y\":1282},{\"x\":1691972409,\"y\":1290},{\"x\":1691972709,\"y\":1303},{\"x\":1691973009,\"y\":1324},{\"x\":1691973309,\"y\":1340},{\"x\":1691973609,\"y\":1344},{\"x\":1691973909,\"y\":1351},{\"x\":1691974209,\"y\":1355},{\"x\":1691974509,\"y\":1351},{\"x\":1691974809,\"y\":1355},{\"x\":1691975109,\"y\":1365},{\"x\":1691975409,\"y\":1371},{\"x\":1691975709,\"y\":1447},{\"x\":1691976009,\"y\":1602},{\"x\":1691976309,\"y\":1766},{\"x\":1691976609,\"y\":1913},{\"x\":1691976910,\"y\":1916},{\"x\":1691977209,\"y\":1990},{\"x\":1691977509,\"y\":2063},{\"x\":1691977809,\"y\":1988},{\"x\":1691978109,\"y\":1984},{\"x\":1691978409,\"y\":1980},{\"x\":1691978709,\"y\":1984},{\"x\":1691979009,\"y\":2169},{\"x\":1691979309,\"y\":2164},{\"x\":1691979609,\"y\":1985},{\"x\":1691979909,\"y\":1991},{\"x\":1691980209,\"y\":1987},{\"x\":1691980509,\"y\":1990},{\"x\":1691980810,\"y\":2162},{\"x\":1691981109,\"y\":2157},{\"x\":1691981409,\"y\":1989},{\"x\":1691981709,\"y\":1985},{\"x\":1691982009,\"y\":1990},{\"x\":1691982309,\"y\":1995},{\"x\":1691982609,\"y\":2092},{\"x\":1691982909,\"y\":2062},{\"x\":1691983209,\"y\":1988},{\"x\":1691983509,\"y\":1992},{\"x\":1691983809,\"y\":1994},{\"x\":1691984109,\"y\":1988},{\"x\":1691984409,\"y\":1975},{\"x\":1691984710,\"y\":1946},{\"x\":1691985009,\"y\":1897},{\"x\":1691985309,\"y\":1561},{\"x\":1691985609,\"y\":1359},{\"x\":1691985909,\"y\":1158},{\"x\":1691986209,\"y\":1115},{\"x\":1691986509,\"y\":1058},{\"x\":1691986809,\"y\":954},{\"x\":1691987109,\"y\":924},{\"x\":1691987409,\"y\":889},{\"x\":1691987709,\"y\":795},{\"x\":1691988009,\"y\":1134},{\"x\":1691988309,\"y\":1059},{\"x\":1691988609,\"y\":744},{\"x\":1691988909,\"y\":699},{\"x\":1691989210,\"y\":586},{\"x\":1691989509,\"y\":702},{\"x\":1691989809,\"y\":714},{\"x\":1691990109,\"y\":724},{\"x\":1691990409,\"y\":576},{\"x\":1691990709,\"y\":497},{\"x\":1691991008,\"y\":498},{\"x\":1691991309,\"y\":582},{\"x\":1691991610,\"y\":560},{\"x\":1691991909,\"y\":571},{\"x\":1691992209,\"y\":480},{\"x\":1691992509,\"y\":348},{\"x\":1691992809,\"y\":356},{\"x\":1691993109,\"y\":328},{\"x\":1691993409,\"y\":303},{\"x\":1691993709,\"y\":279},{\"x\":1691994009,\"y\":219},{\"x\":1691994309,\"y\":202},{\"x\":1691994609,\"y\":186},{\"x\":1691994909,\"y\":142},{\"x\":1691995209,\"y\":111},{\"x\":1691995510,\"y\":56},{\"x\":1691995809,\"y\":63},{\"x\":1691996109,\"y\":64},{\"x\":1691996409,\"y\":49},{\"x\":1691996709,\"y\":38},{\"x\":1691997009,\"y\":27},{\"x\":1691997309,\"y\":20},{\"x\":1691997609,\"y\":14},{\"x\":1691997909,\"y\":10}]","payloadType":"json","x":330,"y":140,"wires":[["cde96b73cb8efbdc"]]},{"id":"cde96b73cb8efbdc","type":"json","z":"743cc0234f1851f1","name":"","property":"payload","action":"str","pretty":false,"x":350,"y":180,"wires":[["d6367ef327c43a38"]]},{"id":"d6367ef327c43a38","type":"join","z":"743cc0234f1851f1","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":470,"y":200,"wires":[["9bbbe18a5838d62a"]]},{"id":"0b17cef31ea36ac4","type":"json","z":"743cc0234f1851f1","name":"","property":"payload","action":"str","pretty":false,"x":350,"y":220,"wires":[["d6367ef327c43a38"]]},{"id":"9bbbe18a5838d62a","type":"template","z":"743cc0234f1851f1","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"[{\n        \"series\": [\n            \"PAC\"\n        ],\n        \"data\": [\n            {{{payload.pac}}},\n            {{{payload.pac1}}}\n        ],\n        \"labels\": [\n            \"\"\n        ]\n    }\n]","output":"json","x":600,"y":200,"wires":[["a33ca4bba1eb8be4"]]},{"id":"24e8532e.fd99bc","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac1","payload":"[{\"x\":1691785570,\"y\":0},{\"x\":1691785576,\"y\":0},{\"x\":1691785809,\"y\":15},{\"x\":1691786109,\"y\":18},{\"x\":1691786409,\"y\":31},{\"x\":1691786709,\"y\":40},{\"x\":1691787009,\"y\":49},{\"x\":1691787309,\"y\":58},{\"x\":1691787609,\"y\":64},{\"x\":1691787909,\"y\":76},{\"x\":1691788209,\"y\":106},{\"x\":1691788509,\"y\":147},{\"x\":1691788809,\"y\":184},{\"x\":1691789109,\"y\":197},{\"x\":1691789409,\"y\":270},{\"x\":1691789709,\"y\":376},{\"x\":1691790009,\"y\":429},{\"x\":1691790309,\"y\":526},{\"x\":1691790609,\"y\":573},{\"x\":1691790909,\"y\":612},{\"x\":1691791209,\"y\":645},{\"x\":1691791509,\"y\":664},{\"x\":1691791809,\"y\":689},{\"x\":1691792109,\"y\":715},{\"x\":1691792409,\"y\":810},{\"x\":1691792709,\"y\":851},{\"x\":1691793009,\"y\":886},{\"x\":1691793309,\"y\":910},{\"x\":1691793609,\"y\":941},{\"x\":1691793909,\"y\":976},{\"x\":1691794209,\"y\":1006},{\"x\":1691794509,\"y\":1028},{\"x\":1691794809,\"y\":1056},{\"x\":1691795109,\"y\":1079},{\"x\":1691795409,\"y\":1102},{\"x\":1691795709,\"y\":1113},{\"x\":1691796009,\"y\":1133},{\"x\":1691796309,\"y\":1149},{\"x\":1691796609,\"y\":1165},{\"x\":1691796909,\"y\":1176},{\"x\":1691797209,\"y\":1192},{\"x\":1691797509,\"y\":1211},{\"x\":1691797809,\"y\":1221},{\"x\":1691798109,\"y\":1236},{\"x\":1691798409,\"y\":1249},{\"x\":1691798709,\"y\":1265},{\"x\":1691799009,\"y\":1275},{\"x\":1691799309,\"y\":1288},{\"x\":1691799609,\"y\":1293},{\"x\":1691799909,\"y\":1309},{\"x\":1691800208,\"y\":1316},{\"x\":1691800509,\"y\":1330},{\"x\":1691800809,\"y\":1339},{\"x\":1691801109,\"y\":1330},{\"x\":1691801409,\"y\":1347},{\"x\":1691801709,\"y\":1350},{\"x\":1691802009,\"y\":1366},{\"x\":1691802309,\"y\":1363},{\"x\":1691802609,\"y\":1368},{\"x\":1691802909,\"y\":1599},{\"x\":1691803209,\"y\":1754},{\"x\":1691803509,\"y\":1750},{\"x\":1691803809,\"y\":1736},{\"x\":1691804109,\"y\":1779},{\"x\":1691804409,\"y\":1789},{\"x\":1691804709,\"y\":1866},{\"x\":1691805009,\"y\":1997},{\"x\":1691805309,\"y\":1986},{\"x\":1691805609,\"y\":1987},{\"x\":1691805909,\"y\":1981},{\"x\":1691806209,\"y\":1988},{\"x\":1691806509,\"y\":1972},{\"x\":1691806809,\"y\":1986},{\"x\":1691807109,\"y\":1979},{\"x\":1691807409,\"y\":1956},{\"x\":1691807709,\"y\":1958},{\"x\":1691808009,\"y\":1958},{\"x\":1691808309,\"y\":1945},{\"x\":1691808609,\"y\":1945},{\"x\":1691808909,\"y\":1920},{\"x\":1691809209,\"y\":1898},{\"x\":1691809509,\"y\":1900},{\"x\":1691809809,\"y\":1888},{\"x\":1691810109,\"y\":1857},{\"x\":1691810409,\"y\":1847},{\"x\":1691810709,\"y\":1832},{\"x\":1691811009,\"y\":1787},{\"x\":1691811309,\"y\":1782},{\"x\":1691811609,\"y\":1746},{\"x\":1691811909,\"y\":1707},{\"x\":1691812209,\"y\":1673},{\"x\":1691812509,\"y\":1441},{\"x\":1691812810,\"y\":1147},{\"x\":1691813109,\"y\":1009},{\"x\":1691813409,\"y\":1108},{\"x\":1691813709,\"y\":1049},{\"x\":1691814009,\"y\":963},{\"x\":1691814309,\"y\":941},{\"x\":1691814609,\"y\":522},{\"x\":1691814909,\"y\":229},{\"x\":1691815209,\"y\":1214},{\"x\":1691815509,\"y\":1064},{\"x\":1691815809,\"y\":776},{\"x\":1691816109,\"y\":678},{\"x\":1691816409,\"y\":562},{\"x\":1691816708,\"y\":681},{\"x\":1691817009,\"y\":738},{\"x\":1691817309,\"y\":773},{\"x\":1691817609,\"y\":683},{\"x\":1691817909,\"y\":553},{\"x\":1691818209,\"y\":596},{\"x\":1691818510,\"y\":673},{\"x\":1691818809,\"y\":381},{\"x\":1691819109,\"y\":593},{\"x\":1691819409,\"y\":508},{\"x\":1691819709,\"y\":279},{\"x\":1691820009,\"y\":211},{\"x\":1691820309,\"y\":133},{\"x\":1691820609,\"y\":201},{\"x\":1691820909,\"y\":267},{\"x\":1691821209,\"y\":214},{\"x\":1691821509,\"y\":179},{\"x\":1691821809,\"y\":200},{\"x\":1691822109,\"y\":149},{\"x\":1691822409,\"y\":94},{\"x\":1691822709,\"y\":89},{\"x\":1691823009,\"y\":69},{\"x\":1691823309,\"y\":46},{\"x\":1691823609,\"y\":44},{\"x\":1691823909,\"y\":41},{\"x\":1691824209,\"y\":29},{\"x\":1691824509,\"y\":17},{\"x\":1691824809,\"y\":9},{\"x\":1691825109,\"y\":0}]","payloadType":"json","x":330,"y":260,"wires":[["0b17cef31ea36ac4"]]},{"id":"a33ca4bba1eb8be4","type":"ui_chart","z":"743cc0234f1851f1","name":"","group":"e0023fff.6f3a4","order":30,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":true,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":730,"y":200,"wires":[["ec550529f6b2156e"]]},{"id":"ec550529f6b2156e","type":"debug","z":"743cc0234f1851f1","name":"debug 389","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":790,"y":160,"wires":[]},{"id":"525c5f3a8ad8ce1b","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac","payload":"[{\"x\":1691958309,\"y\":11},{\"x\":1691958609,\"y\":18},{\"x\":1691958909,\"y\":30},{\"x\":1691959209,\"y\":40},{\"x\":1691959509,\"y\":51},{\"x\":1691959809,\"y\":63},{\"x\":1691960109,\"y\":72},{\"x\":1691960409,\"y\":81},{\"x\":1691960709,\"y\":96},{\"x\":1691961009,\"y\":129},{\"x\":1691961309,\"y\":169},{\"x\":1691961609,\"y\":202},{\"x\":1691961909,\"y\":275},{\"x\":1691962209,\"y\":359},{\"x\":1691962509,\"y\":415},{\"x\":1691962809,\"y\":464},{\"x\":1691963109,\"y\":548},{\"x\":1691963409,\"y\":607},{\"x\":1691963709,\"y\":648},{\"x\":1691964009,\"y\":646},{\"x\":1691964309,\"y\":673},{\"x\":1691964609,\"y\":701},{\"x\":1691964909,\"y\":805},{\"x\":1691965209,\"y\":861},{\"x\":1691965509,\"y\":895},{\"x\":1691965809,\"y\":918},{\"x\":1691966109,\"y\":945},{\"x\":1691966409,\"y\":967},{\"x\":1691966709,\"y\":991},{\"x\":1691967009,\"y\":1016},{\"x\":1691967309,\"y\":1037},{\"x\":1691967609,\"y\":1054},{\"x\":1691967909,\"y\":1076},{\"x\":1691968209,\"y\":1092},{\"x\":1691968509,\"y\":1111},{\"x\":1691968809,\"y\":1133},{\"x\":1691969109,\"y\":1150},{\"x\":1691969409,\"y\":1163},{\"x\":1691969709,\"y\":1180},{\"x\":1691970009,\"y\":1191},{\"x\":1691970309,\"y\":1203},{\"x\":1691970609,\"y\":1211},{\"x\":1691970909,\"y\":1229},{\"x\":1691971209,\"y\":1245},{\"x\":1691971509,\"y\":1255},{\"x\":1691971809,\"y\":1272},{\"x\":1691972109,\"y\":1282},{\"x\":1691972409,\"y\":1290},{\"x\":1691972709,\"y\":1303},{\"x\":1691973009,\"y\":1324},{\"x\":1691973309,\"y\":1340},{\"x\":1691973609,\"y\":1344},{\"x\":1691973909,\"y\":1351},{\"x\":1691974209,\"y\":1355},{\"x\":1691974509,\"y\":1351},{\"x\":1691974809,\"y\":1355},{\"x\":1691975109,\"y\":1365},{\"x\":1691975409,\"y\":1371},{\"x\":1691975709,\"y\":1447},{\"x\":1691976009,\"y\":1602},{\"x\":1691976309,\"y\":1766},{\"x\":1691976609,\"y\":1913},{\"x\":1691976910,\"y\":1916},{\"x\":1691977209,\"y\":1990},{\"x\":1691977509,\"y\":2063},{\"x\":1691977809,\"y\":1988},{\"x\":1691978109,\"y\":1984},{\"x\":1691978409,\"y\":1980},{\"x\":1691978709,\"y\":1984},{\"x\":1691979009,\"y\":2169},{\"x\":1691979309,\"y\":2164},{\"x\":1691979609,\"y\":1985},{\"x\":1691979909,\"y\":1991},{\"x\":1691980209,\"y\":1987},{\"x\":1691980509,\"y\":1990},{\"x\":1691980810,\"y\":2162},{\"x\":1691981109,\"y\":2157},{\"x\":1691981409,\"y\":1989},{\"x\":1691981709,\"y\":1985},{\"x\":1691982009,\"y\":1990},{\"x\":1691982309,\"y\":1995},{\"x\":1691982609,\"y\":2092},{\"x\":1691982909,\"y\":2062},{\"x\":1691983209,\"y\":1988},{\"x\":1691983509,\"y\":1992},{\"x\":1691983809,\"y\":1994},{\"x\":1691984109,\"y\":1988},{\"x\":1691984409,\"y\":1975},{\"x\":1691984710,\"y\":1946},{\"x\":1691985009,\"y\":1897},{\"x\":1691985309,\"y\":1561},{\"x\":1691985609,\"y\":1359},{\"x\":1691985909,\"y\":1158},{\"x\":1691986209,\"y\":1115},{\"x\":1691986509,\"y\":1058},{\"x\":1691986809,\"y\":954},{\"x\":1691987109,\"y\":924},{\"x\":1691987409,\"y\":889},{\"x\":1691987709,\"y\":795},{\"x\":1691988009,\"y\":1134},{\"x\":1691988309,\"y\":1059},{\"x\":1691988609,\"y\":744},{\"x\":1691988909,\"y\":699},{\"x\":1691989210,\"y\":586},{\"x\":1691989509,\"y\":702},{\"x\":1691989809,\"y\":714},{\"x\":1691990109,\"y\":724},{\"x\":1691990409,\"y\":576},{\"x\":1691990709,\"y\":497},{\"x\":1691991008,\"y\":498},{\"x\":1691991309,\"y\":582},{\"x\":1691991610,\"y\":560},{\"x\":1691991909,\"y\":571},{\"x\":1691992209,\"y\":480},{\"x\":1691992509,\"y\":348},{\"x\":1691992809,\"y\":356},{\"x\":1691993109,\"y\":328},{\"x\":1691993409,\"y\":303},{\"x\":1691993709,\"y\":279},{\"x\":1691994009,\"y\":219},{\"x\":1691994309,\"y\":202},{\"x\":1691994609,\"y\":186},{\"x\":1691994909,\"y\":142},{\"x\":1691995209,\"y\":111},{\"x\":1691995510,\"y\":56},{\"x\":1691995809,\"y\":63},{\"x\":1691996109,\"y\":64},{\"x\":1691996409,\"y\":49},{\"x\":1691996709,\"y\":38},{\"x\":1691997009,\"y\":27},{\"x\":1691997309,\"y\":20},{\"x\":1691997609,\"y\":14},{\"x\":1691997909,\"y\":10}]","payloadType":"json","x":450,"y":340,"wires":[["fde902ed30a7f991"]]},{"id":"fde902ed30a7f991","type":"join","z":"743cc0234f1851f1","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":510,"y":380,"wires":[["1df60c11a18ed14c"]]},{"id":"7939a618b20816c4","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac1","payload":"[{\"x\":1691785570,\"y\":0},{\"x\":1691785576,\"y\":0},{\"x\":1691785809,\"y\":15},{\"x\":1691786109,\"y\":18},{\"x\":1691786409,\"y\":31},{\"x\":1691786709,\"y\":40},{\"x\":1691787009,\"y\":49},{\"x\":1691787309,\"y\":58},{\"x\":1691787609,\"y\":64},{\"x\":1691787909,\"y\":76},{\"x\":1691788209,\"y\":106},{\"x\":1691788509,\"y\":147},{\"x\":1691788809,\"y\":184},{\"x\":1691789109,\"y\":197},{\"x\":1691789409,\"y\":270},{\"x\":1691789709,\"y\":376},{\"x\":1691790009,\"y\":429},{\"x\":1691790309,\"y\":526},{\"x\":1691790609,\"y\":573},{\"x\":1691790909,\"y\":612},{\"x\":1691791209,\"y\":645},{\"x\":1691791509,\"y\":664},{\"x\":1691791809,\"y\":689},{\"x\":1691792109,\"y\":715},{\"x\":1691792409,\"y\":810},{\"x\":1691792709,\"y\":851},{\"x\":1691793009,\"y\":886},{\"x\":1691793309,\"y\":910},{\"x\":1691793609,\"y\":941},{\"x\":1691793909,\"y\":976},{\"x\":1691794209,\"y\":1006},{\"x\":1691794509,\"y\":1028},{\"x\":1691794809,\"y\":1056},{\"x\":1691795109,\"y\":1079},{\"x\":1691795409,\"y\":1102},{\"x\":1691795709,\"y\":1113},{\"x\":1691796009,\"y\":1133},{\"x\":1691796309,\"y\":1149},{\"x\":1691796609,\"y\":1165},{\"x\":1691796909,\"y\":1176},{\"x\":1691797209,\"y\":1192},{\"x\":1691797509,\"y\":1211},{\"x\":1691797809,\"y\":1221},{\"x\":1691798109,\"y\":1236},{\"x\":1691798409,\"y\":1249},{\"x\":1691798709,\"y\":1265},{\"x\":1691799009,\"y\":1275},{\"x\":1691799309,\"y\":1288},{\"x\":1691799609,\"y\":1293},{\"x\":1691799909,\"y\":1309},{\"x\":1691800208,\"y\":1316},{\"x\":1691800509,\"y\":1330},{\"x\":1691800809,\"y\":1339},{\"x\":1691801109,\"y\":1330},{\"x\":1691801409,\"y\":1347},{\"x\":1691801709,\"y\":1350},{\"x\":1691802009,\"y\":1366},{\"x\":1691802309,\"y\":1363},{\"x\":1691802609,\"y\":1368},{\"x\":1691802909,\"y\":1599},{\"x\":1691803209,\"y\":1754},{\"x\":1691803509,\"y\":1750},{\"x\":1691803809,\"y\":1736},{\"x\":1691804109,\"y\":1779},{\"x\":1691804409,\"y\":1789},{\"x\":1691804709,\"y\":1866},{\"x\":1691805009,\"y\":1997},{\"x\":1691805309,\"y\":1986},{\"x\":1691805609,\"y\":1987},{\"x\":1691805909,\"y\":1981},{\"x\":1691806209,\"y\":1988},{\"x\":1691806509,\"y\":1972},{\"x\":1691806809,\"y\":1986},{\"x\":1691807109,\"y\":1979},{\"x\":1691807409,\"y\":1956},{\"x\":1691807709,\"y\":1958},{\"x\":1691808009,\"y\":1958},{\"x\":1691808309,\"y\":1945},{\"x\":1691808609,\"y\":1945},{\"x\":1691808909,\"y\":1920},{\"x\":1691809209,\"y\":1898},{\"x\":1691809509,\"y\":1900},{\"x\":1691809809,\"y\":1888},{\"x\":1691810109,\"y\":1857},{\"x\":1691810409,\"y\":1847},{\"x\":1691810709,\"y\":1832},{\"x\":1691811009,\"y\":1787},{\"x\":1691811309,\"y\":1782},{\"x\":1691811609,\"y\":1746},{\"x\":1691811909,\"y\":1707},{\"x\":1691812209,\"y\":1673},{\"x\":1691812509,\"y\":1441},{\"x\":1691812810,\"y\":1147},{\"x\":1691813109,\"y\":1009},{\"x\":1691813409,\"y\":1108},{\"x\":1691813709,\"y\":1049},{\"x\":1691814009,\"y\":963},{\"x\":1691814309,\"y\":941},{\"x\":1691814609,\"y\":522},{\"x\":1691814909,\"y\":229},{\"x\":1691815209,\"y\":1214},{\"x\":1691815509,\"y\":1064},{\"x\":1691815809,\"y\":776},{\"x\":1691816109,\"y\":678},{\"x\":1691816409,\"y\":562},{\"x\":1691816708,\"y\":681},{\"x\":1691817009,\"y\":738},{\"x\":1691817309,\"y\":773},{\"x\":1691817609,\"y\":683},{\"x\":1691817909,\"y\":553},{\"x\":1691818209,\"y\":596},{\"x\":1691818510,\"y\":673},{\"x\":1691818809,\"y\":381},{\"x\":1691819109,\"y\":593},{\"x\":1691819409,\"y\":508},{\"x\":1691819709,\"y\":279},{\"x\":1691820009,\"y\":211},{\"x\":1691820309,\"y\":133},{\"x\":1691820609,\"y\":201},{\"x\":1691820909,\"y\":267},{\"x\":1691821209,\"y\":214},{\"x\":1691821509,\"y\":179},{\"x\":1691821809,\"y\":200},{\"x\":1691822109,\"y\":149},{\"x\":1691822409,\"y\":94},{\"x\":1691822709,\"y\":89},{\"x\":1691823009,\"y\":69},{\"x\":1691823309,\"y\":46},{\"x\":1691823609,\"y\":44},{\"x\":1691823909,\"y\":41},{\"x\":1691824209,\"y\":29},{\"x\":1691824509,\"y\":17},{\"x\":1691824809,\"y\":9},{\"x\":1691825109,\"y\":0}]","payloadType":"json","x":450,"y":440,"wires":[["fde902ed30a7f991"]]},{"id":"1df60c11a18ed14c","type":"change","z":"743cc0234f1851f1","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\t        \"series\": [\t            \"PAC\",\"PAC1\"\t        ],\t        \"data\": [\t            [$$.payload.pac ~> |$|{\"x\":$.x*1000}|],\t            [$$.payload.pac1 ~> |$|{\"x\":$.x*1000}|]\t        ],\t        \"labels\": [\t            \"\"\t        ]\t    }\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":400,"wires":[["f415325c92449d79"]]},{"id":"f415325c92449d79","type":"ui_chart","z":"743cc0234f1851f1","name":"","group":"e0023fff.6f3a4","order":30,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":true,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":830,"y":400,"wires":[[]]},{"id":"e0023fff.6f3a4","type":"ui_group","name":"Web","tab":"3a6d7b89.06bd5c","order":1,"disp":false,"width":"8","collapse":false,"className":""},{"id":"3a6d7b89.06bd5c","type":"ui_tab","name":"PV","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Hi E1cid
Thank you so much for the quick response, that is awesome and it has highlighted a flaw in my thinking, the y data is the important info and by suppling 2 different time stamps for each in my request, it sets the graphs side by side instead of on the same time line, is there a way to use the time stamps from just one array across both sets of y data as if they were plotted at the same time, so the 2 graphs are on top of each other.
Yes possible, but makes a complicated expression.
You will need to make sure both inputs are the same length, as this may throw errors in to chart plotting.
[{"id":"110758382d03e9e8","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac","payload":"[{\"x\":1691958309,\"y\":11},{\"x\":1691958609,\"y\":18},{\"x\":1691958909,\"y\":30},{\"x\":1691959209,\"y\":40},{\"x\":1691959509,\"y\":51},{\"x\":1691959809,\"y\":63},{\"x\":1691960109,\"y\":72},{\"x\":1691960409,\"y\":81},{\"x\":1691960709,\"y\":96},{\"x\":1691961009,\"y\":129},{\"x\":1691961309,\"y\":169},{\"x\":1691961609,\"y\":202},{\"x\":1691961909,\"y\":275},{\"x\":1691962209,\"y\":359},{\"x\":1691962509,\"y\":415},{\"x\":1691962809,\"y\":464},{\"x\":1691963109,\"y\":548},{\"x\":1691963409,\"y\":607},{\"x\":1691963709,\"y\":648},{\"x\":1691964009,\"y\":646},{\"x\":1691964309,\"y\":673},{\"x\":1691964609,\"y\":701},{\"x\":1691964909,\"y\":805},{\"x\":1691965209,\"y\":861},{\"x\":1691965509,\"y\":895},{\"x\":1691965809,\"y\":918},{\"x\":1691966109,\"y\":945},{\"x\":1691966409,\"y\":967},{\"x\":1691966709,\"y\":991},{\"x\":1691967009,\"y\":1016},{\"x\":1691967309,\"y\":1037},{\"x\":1691967609,\"y\":1054},{\"x\":1691967909,\"y\":1076},{\"x\":1691968209,\"y\":1092},{\"x\":1691968509,\"y\":1111},{\"x\":1691968809,\"y\":1133},{\"x\":1691969109,\"y\":1150},{\"x\":1691969409,\"y\":1163},{\"x\":1691969709,\"y\":1180},{\"x\":1691970009,\"y\":1191},{\"x\":1691970309,\"y\":1203},{\"x\":1691970609,\"y\":1211},{\"x\":1691970909,\"y\":1229},{\"x\":1691971209,\"y\":1245},{\"x\":1691971509,\"y\":1255},{\"x\":1691971809,\"y\":1272},{\"x\":1691972109,\"y\":1282},{\"x\":1691972409,\"y\":1290},{\"x\":1691972709,\"y\":1303},{\"x\":1691973009,\"y\":1324},{\"x\":1691973309,\"y\":1340},{\"x\":1691973609,\"y\":1344},{\"x\":1691973909,\"y\":1351},{\"x\":1691974209,\"y\":1355},{\"x\":1691974509,\"y\":1351},{\"x\":1691974809,\"y\":1355},{\"x\":1691975109,\"y\":1365},{\"x\":1691975409,\"y\":1371},{\"x\":1691975709,\"y\":1447},{\"x\":1691976009,\"y\":1602},{\"x\":1691976309,\"y\":1766},{\"x\":1691976609,\"y\":1913},{\"x\":1691976910,\"y\":1916},{\"x\":1691977209,\"y\":1990},{\"x\":1691977509,\"y\":2063},{\"x\":1691977809,\"y\":1988},{\"x\":1691978109,\"y\":1984},{\"x\":1691978409,\"y\":1980},{\"x\":1691978709,\"y\":1984},{\"x\":1691979009,\"y\":2169},{\"x\":1691979309,\"y\":2164},{\"x\":1691979609,\"y\":1985},{\"x\":1691979909,\"y\":1991},{\"x\":1691980209,\"y\":1987},{\"x\":1691980509,\"y\":1990},{\"x\":1691980810,\"y\":2162},{\"x\":1691981109,\"y\":2157},{\"x\":1691981409,\"y\":1989},{\"x\":1691981709,\"y\":1985},{\"x\":1691982009,\"y\":1990},{\"x\":1691982309,\"y\":1995},{\"x\":1691982609,\"y\":2092},{\"x\":1691982909,\"y\":2062},{\"x\":1691983209,\"y\":1988},{\"x\":1691983509,\"y\":1992},{\"x\":1691983809,\"y\":1994},{\"x\":1691984109,\"y\":1988},{\"x\":1691984409,\"y\":1975},{\"x\":1691984710,\"y\":1946},{\"x\":1691985009,\"y\":1897},{\"x\":1691985309,\"y\":1561},{\"x\":1691985609,\"y\":1359},{\"x\":1691985909,\"y\":1158},{\"x\":1691986209,\"y\":1115},{\"x\":1691986509,\"y\":1058},{\"x\":1691986809,\"y\":954},{\"x\":1691987109,\"y\":924},{\"x\":1691987409,\"y\":889},{\"x\":1691987709,\"y\":795},{\"x\":1691988009,\"y\":1134},{\"x\":1691988309,\"y\":1059},{\"x\":1691988609,\"y\":744},{\"x\":1691988909,\"y\":699},{\"x\":1691989210,\"y\":586},{\"x\":1691989509,\"y\":702},{\"x\":1691989809,\"y\":714},{\"x\":1691990109,\"y\":724},{\"x\":1691990409,\"y\":576},{\"x\":1691990709,\"y\":497},{\"x\":1691991008,\"y\":498},{\"x\":1691991309,\"y\":582},{\"x\":1691991610,\"y\":560},{\"x\":1691991909,\"y\":571},{\"x\":1691992209,\"y\":480},{\"x\":1691992509,\"y\":348},{\"x\":1691992809,\"y\":356},{\"x\":1691993109,\"y\":328},{\"x\":1691993409,\"y\":303},{\"x\":1691993709,\"y\":279},{\"x\":1691994009,\"y\":219},{\"x\":1691994309,\"y\":202},{\"x\":1691994609,\"y\":186},{\"x\":1691994909,\"y\":142},{\"x\":1691995209,\"y\":111},{\"x\":1691995510,\"y\":56},{\"x\":1691995809,\"y\":63},{\"x\":1691996109,\"y\":64},{\"x\":1691996409,\"y\":49},{\"x\":1691996709,\"y\":38},{\"x\":1691997009,\"y\":27},{\"x\":1691997309,\"y\":20},{\"x\":1691997609,\"y\":14},{\"x\":1691997909,\"y\":10}]","payloadType":"json","x":270,"y":180,"wires":[["b38f48524d6b8c96"]]},{"id":"b38f48524d6b8c96","type":"join","z":"743cc0234f1851f1","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"num","reduceFixup":"","x":390,"y":200,"wires":[["f61c924096121509"]]},{"id":"183e8f089e72edf2","type":"inject","z":"743cc0234f1851f1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pac1","payload":"[{\"x\":1691785570,\"y\":0},{\"x\":1691785576,\"y\":0},{\"x\":1691785809,\"y\":15},{\"x\":1691786109,\"y\":18},{\"x\":1691786409,\"y\":31},{\"x\":1691786709,\"y\":40},{\"x\":1691787009,\"y\":49},{\"x\":1691787309,\"y\":58},{\"x\":1691787609,\"y\":64},{\"x\":1691787909,\"y\":76},{\"x\":1691788209,\"y\":106},{\"x\":1691788509,\"y\":147},{\"x\":1691788809,\"y\":184},{\"x\":1691789109,\"y\":197},{\"x\":1691789409,\"y\":270},{\"x\":1691789709,\"y\":376},{\"x\":1691790009,\"y\":429},{\"x\":1691790309,\"y\":526},{\"x\":1691790609,\"y\":573},{\"x\":1691790909,\"y\":612},{\"x\":1691791209,\"y\":645},{\"x\":1691791509,\"y\":664},{\"x\":1691791809,\"y\":689},{\"x\":1691792109,\"y\":715},{\"x\":1691792409,\"y\":810},{\"x\":1691792709,\"y\":851},{\"x\":1691793009,\"y\":886},{\"x\":1691793309,\"y\":910},{\"x\":1691793609,\"y\":941},{\"x\":1691793909,\"y\":976},{\"x\":1691794209,\"y\":1006},{\"x\":1691794509,\"y\":1028},{\"x\":1691794809,\"y\":1056},{\"x\":1691795109,\"y\":1079},{\"x\":1691795409,\"y\":1102},{\"x\":1691795709,\"y\":1113},{\"x\":1691796009,\"y\":1133},{\"x\":1691796309,\"y\":1149},{\"x\":1691796609,\"y\":1165},{\"x\":1691796909,\"y\":1176},{\"x\":1691797209,\"y\":1192},{\"x\":1691797509,\"y\":1211},{\"x\":1691797809,\"y\":1221},{\"x\":1691798109,\"y\":1236},{\"x\":1691798409,\"y\":1249},{\"x\":1691798709,\"y\":1265},{\"x\":1691799009,\"y\":1275},{\"x\":1691799309,\"y\":1288},{\"x\":1691799609,\"y\":1293},{\"x\":1691799909,\"y\":1309},{\"x\":1691800208,\"y\":1316},{\"x\":1691800509,\"y\":1330},{\"x\":1691800809,\"y\":1339},{\"x\":1691801109,\"y\":1330},{\"x\":1691801409,\"y\":1347},{\"x\":1691801709,\"y\":1350},{\"x\":1691802009,\"y\":1366},{\"x\":1691802309,\"y\":1363},{\"x\":1691802609,\"y\":1368},{\"x\":1691802909,\"y\":1599},{\"x\":1691803209,\"y\":1754},{\"x\":1691803509,\"y\":1750},{\"x\":1691803809,\"y\":1736},{\"x\":1691804109,\"y\":1779},{\"x\":1691804409,\"y\":1789},{\"x\":1691804709,\"y\":1866},{\"x\":1691805009,\"y\":1997},{\"x\":1691805309,\"y\":1986},{\"x\":1691805609,\"y\":1987},{\"x\":1691805909,\"y\":1981},{\"x\":1691806209,\"y\":1988},{\"x\":1691806509,\"y\":1972},{\"x\":1691806809,\"y\":1986},{\"x\":1691807109,\"y\":1979},{\"x\":1691807409,\"y\":1956},{\"x\":1691807709,\"y\":1958},{\"x\":1691808009,\"y\":1958},{\"x\":1691808309,\"y\":1945},{\"x\":1691808609,\"y\":1945},{\"x\":1691808909,\"y\":1920},{\"x\":1691809209,\"y\":1898},{\"x\":1691809509,\"y\":1900},{\"x\":1691809809,\"y\":1888},{\"x\":1691810109,\"y\":1857},{\"x\":1691810409,\"y\":1847},{\"x\":1691810709,\"y\":1832},{\"x\":1691811009,\"y\":1787},{\"x\":1691811309,\"y\":1782},{\"x\":1691811609,\"y\":1746},{\"x\":1691811909,\"y\":1707},{\"x\":1691812209,\"y\":1673},{\"x\":1691812509,\"y\":1441},{\"x\":1691812810,\"y\":1147},{\"x\":1691813109,\"y\":1009},{\"x\":1691813409,\"y\":1108},{\"x\":1691813709,\"y\":1049},{\"x\":1691814009,\"y\":963},{\"x\":1691814309,\"y\":941},{\"x\":1691814609,\"y\":522},{\"x\":1691814909,\"y\":229},{\"x\":1691815209,\"y\":1214},{\"x\":1691815509,\"y\":1064},{\"x\":1691815809,\"y\":776},{\"x\":1691816109,\"y\":678},{\"x\":1691816409,\"y\":562},{\"x\":1691816708,\"y\":681},{\"x\":1691817009,\"y\":738},{\"x\":1691817309,\"y\":773},{\"x\":1691817609,\"y\":683},{\"x\":1691817909,\"y\":553},{\"x\":1691818209,\"y\":596},{\"x\":1691818510,\"y\":673},{\"x\":1691818809,\"y\":381},{\"x\":1691819109,\"y\":593},{\"x\":1691819409,\"y\":508},{\"x\":1691819709,\"y\":279},{\"x\":1691820009,\"y\":211},{\"x\":1691820309,\"y\":133},{\"x\":1691820609,\"y\":201},{\"x\":1691820909,\"y\":267},{\"x\":1691821209,\"y\":214},{\"x\":1691821509,\"y\":179},{\"x\":1691821809,\"y\":200},{\"x\":1691822109,\"y\":149},{\"x\":1691822409,\"y\":94},{\"x\":1691822709,\"y\":89},{\"x\":1691823009,\"y\":69},{\"x\":1691823309,\"y\":46},{\"x\":1691823609,\"y\":44},{\"x\":1691823909,\"y\":41},{\"x\":1691824209,\"y\":29},{\"x\":1691824509,\"y\":17},{\"x\":1691824809,\"y\":9},{\"x\":1691825109,\"y\":0}]","payloadType":"json","x":270,"y":220,"wires":[["b38f48524d6b8c96"]]},{"id":"f61c924096121509","type":"change","z":"743cc0234f1851f1","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\t        \"series\": [\t            \"PAC\",\"PAC1\"\t        ],\t        \"data\": [\t            [$$.payload.pac ~> |$|{\"x\":$.x*1000}|],\t            [$$.payload.pac1#$i.{\"x\": $$.payload.pac[$i].x * 1000, \"y\":$.y}]\t        ],\t        \"labels\": [\t            \"\"\t        ]\t    }\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":200,"wires":[["41accc6119e15e98"]]},{"id":"41accc6119e15e98","type":"ui_chart","z":"743cc0234f1851f1","name":"","group":"1e9a096e08619a9d","order":30,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":true,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":730,"y":200,"wires":[[]]},{"id":"1e9a096e08619a9d","type":"ui_group","name":"Web","tab":"3a6d7b89.06bd5c","order":1,"disp":false,"width":"8","collapse":false,"className":""},{"id":"3a6d7b89.06bd5c","type":"ui_tab","name":"PV","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
thank you so much , that is just what i wanted and even when they are different lengths still gives me a comparison
node2
