Combine 2 Sensor outputs
Hi all,
…this can‘t be that complicated… :-/
Ich have 2 messages coming via MQTT, one delivers true or false, the other one delivers a number, which I converted via a function-node also into a boolean. Now I want to combine both values, that mean if both values are true, make this, otherwise make make that…
Could someone please point me into the right direction?
Cheers, Georg
See this article in the cookbook for an example of how to join messages into one object.
Once you have both values in one msg you can compare both.
Wow, that was fast…
thanks Steve, I‘ll try that…
…and works perfectly!
Thanks, Steve!
