Combine similar payloads then split
Hi all, I am trying to combine two streams of data. One feed has some of the attributes I need, and the other has the rest. Each stream has many nodes but most of the nodes can be singled out in each stream by their MAC address. I have attempted to combine the attributes of each one. I finally have both streams into one message payload separated further into payloads part 1 and part 2. I cant seem to combine like parts 1 and 2. Any suggestions?
Thanks again :slight_smile:
My Flow
[{"id":"e21cc72a.85b078","type":"http request","z":"a61db8ad.cd7c68","name":"","method":"GET","ret":"obj","paytoqs":false,"url":"https://10.254.1.19/api/v1/location","tls":"8b3830a0.cd07c","persist":false,"proxy":"","authType":"basic","x":150,"y":120,"wires":[["f58ab2a8.69306"]]},{"id":"f58ab2a8.69306","type":"change","z":"a61db8ad.cd7c68","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Location_result","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":120,"wires":[["5c1752eb.aa83dc"]]},{"id":"3eddda3d.6710e6","type":"inject","z":"a61db8ad.cd7c68","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":320,"wires":[["3708805d.dcb4e","e21cc72a.85b078"]]},{"id":"5c1752eb.aa83dc","type":"split","z":"a61db8ad.cd7c68","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":true,"addname":"","x":490,"y":120,"wires":[["923aa877.bbff28"]]},{"id":"3708805d.dcb4e","type":"http request","z":"a61db8ad.cd7c68","name":"","method":"GET","ret":"obj","paytoqs":false,"url":"https://10.254.1.19/api/v1/station","tls":"8b3830a0.cd07c","persist":false,"proxy":"","authType":"basic","x":150,"y":40,"wires":[["7dbb06e9.5ef5c8"]]},{"id":"923aa877.bbff28","type":"change","z":"a61db8ad.cd7c68","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.msg","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":120,"wires":[["9a49840a.3b0428"]]},{"id":"7dbb06e9.5ef5c8","type":"change","z":"a61db8ad.cd7c68","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Station_result","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":40,"wires":[["dc1eb92d.7e16f8"]]},{"id":"9a49840a.3b0428","type":"function","z":"a61db8ad.cd7c68","name":"","func":"var payload=msg.payload;\nmsg.payload = { \n        \"mac_address\": payload.sta_eth_mac.addr,\n        \"association\": payload.associated,\n        \"x\": payload.sta_location_x,\n        \"y\": payload.sta_location_y,\n        \"alg\": payload.loc_algorithm,\n        \"error_level\": payload.error_level,\n        \"floor_id\": payload.floor_id }\nreturn msg;","outputs":1,"noerr":0,"x":710,"y":180,"wires":[["f8659fb8.cd32c"]]},{"id":"dc1eb92d.7e16f8","type":"split","z":"a61db8ad.cd7c68","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":490,"y":40,"wires":[["1cddd653.f9b0ea"]]},{"id":"f8659fb8.cd32c","type":"function","z":"a61db8ad.cd7c68","name":"","func":"var payload=msg.payload;\nmsg.topic = msg.payload.mac_address+\"_2\";\nreturn msg;","outputs":1,"noerr":0,"x":950,"y":120,"wires":[["991853c5.d60aa"]]},{"id":"1cddd653.f9b0ea","type":"change","z":"a61db8ad.cd7c68","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.msg","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":40,"wires":[["209bbafa.5e6d76"]]},{"id":"991853c5.d60aa","type":"join","z":"a61db8ad.cd7c68","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"5","count":"200","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1100,"y":280,"wires":[["3e3215c3.4a614a"]]},{"id":"209bbafa.5e6d76","type":"function","z":"a61db8ad.cd7c68","name":"","func":"var payload=msg.payload;\nmsg.payload = { \"Username\": payload.username,\n        \"role\": payload.role,\n        \"type\": payload.device_type,\n        \"mac_address\": payload.sta_eth_mac.addr,\n        \"ip_address\": payload.sta_ip_address.addr,\n        \"access_point\": payload.ap_name,\n        \"bssid\": payload.bssid.addr}\nreturn msg;","outputs":1,"noerr":0,"x":790,"y":80,"wires":[["9af6712d.ae521"]]},{"id":"9af6712d.ae521","type":"function","z":"a61db8ad.cd7c68","name":"","func":"var payload=msg.payload;\nmsg.topic = msg.payload.mac_address+\"_1\";\nreturn msg;","outputs":1,"noerr":0,"x":1000,"y":40,"wires":[["991853c5.d60aa"]]},{"id":"3e3215c3.4a614a","type":"debug","z":"a61db8ad.cd7c68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1070,"y":360,"wires":[]},{"id":"8b3830a0.cd07c","type":"tls-config","z":"","name":"","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false}]
what returns
Was two long to past into code. so I attached.. and you have to see the beginning and end to see there is two payloads for each mac.. "mac"_1 and "mac"_2. Attached an image as well to see.
return.json (4.4 KB)
I'd love to get them into individual messages with the attributes from "mac"_1 and "mac"_2.
Also, if I am doing this totally wrong, just let me know. Learning as I go.
I can't test your flow at the moment, but have you combined the streams using the Join node in key/value mode as described in this post from the cookbook. That is an effective way of doing it with minimum effort.
Join is what I am attempting to use. If I have SAME message topics come in, only one of the sets of attributes is added. If I make the topics coming from the two incoming flows "mac"_1 and "mac"_2, at least I have all the data from both flows in the final payload. But then I am not sure how to get the data from payloads "mac"_1 and "mac"_2 into one message for each set of message topics.
so far my flows call api, split it into individual messages, formatted how I wanted, then applied the topic "mac"_1 and "mac"_2 to each message depending on the stream.
how can I look for topics matching "mac"_1 and "mac"_2 and then combine the payloads. Used the join node in all configurations its seems lolBugged me all night lol
Thank you so much for your assistance.
Could you please provide some test data - the output from the two http request nodes.
I was able to figure it out. Thank you!
