Combing elements of array in single variable
Dear All,
I have a variable which I am reading using "OPC UA inject node". Please see pic 1 attached.
The name of variable is "ActPowerTotal" and it is an array of four variables and each variables is represented as:
payload.value.0.value.value[0]
payload.value.0.value.value[1]
payload.value.0.value.value[2]
payload.value.0.value.value[3]
I am able to set message payload of "a1" variable a using "edit change node". Please see pic 2.
I am able to see "2" as it is coming from payload.value.0.value.value[1]
However, I would like combine value of each element in the variable "a1".
Means , if
payload.value.0.value.value[0] =1
payload.value.0.value.value[1] = 2
payload.value.0.value.value[2] = 3
payload.value.0.value.value[3] = 3
Then message payload of "a1" should be 1233
Thank you and with best regards
So that we can see the types of the data, please feed the incoming message into a debug node and expand (by clicking) the relevant bits of the message so that we can see the values you want to combine.
Thanks Colin
Please see the photo attached of the debug window:
Menas all of them are int 16
BR
You said that the data are in an array:
Which does not agree with your screenshot which shows it in Sno. Also please show the complete debug output so we can see the full context. From the screenshot you posted it could be msg.Sno, msg.payload.Sno, etc.
THis variable "a1", I am reading from 'payload.value.0.vlue.value [0] '
As shown below:
With this, I am able to read individual element but I need to combine all elements and show them in "a1"
Show us the data coming into the Change node please. Also, again, please show the full debug output, we cannot see the initial lines which are off the top of your screenshot.
Do you need the values to be in msg.payload.a1 or do you just need the combined value?
I need values as msg.payload.a1
First note that msg.payload.a1 is an object not an array.
To build the combined number, in a Function node you could do something like
const combined = ((msg.payload.a1.0 * 10 + msg.payload.a1.1) * 10 + msg.payload.a1.2) * 10 + msg.payload.a1.3
No doubt something similar can be done in a Change node using JSONata
AH...this is getting nearer. thank
My requirement is read from
. I tried to replace the code you have sent with a1.0 with 'payload.value.0.value.value[0]' but I am getting error
I use this code
const combined = ((msg.payload.value.[1].0 * 10 + ((msg.payload.value.[1].1 * 10 + ((msg.payload.value.[1].2 * 10 + ((msg.payload.value.[1].3 * 10
Please do what I have repeatedly asked, which is to show us what is going into the Change node in a Debug node.
Also there is a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
Apologize:
I hover mouse and here values:
Copy path: payload.a1
Copy Value: 0
Below is screen shot. May be I Am missing some more info ?
What value do you want out from that input?
The variable "a1" should have values from all four elements of the array.
Something like this:
Set msg.payload.a1 = payload.value.0.value.value[0] + payload.value.0.value.value[1] + payload.value.0.value.value[2] + payload.value.0.value.value[3]
assuming following are values of each element:
 payload.value.0.value.value[1] =2
 payload.value.0.value.value[2] =3
 payload.value.0.value.value[3] =4
then msg.payload.a1 should be 1234
You haven't shown that data in the debug output, click on value to expand it and keep clicking till we can see the data of interest.
I understand you are referring to this data? see below:
These are the data coming from payload.value.0.value.value which is an array with four elements. At this moment following are the values:
payload.value.0.value.value[0] =0
 payload.value.0.value.value[1] =0
 payload.value.0.value.value[2] =0
 payload.value.0.value.value[3] =0
then msg.payload.a1 should be 0000 or simply 0.
However, if the values changes as shown below:
payload.value.0.value.value[0] =4
 payload.value.0.value.value[1] =6
 payload.value.0.value.value[2] =7
 payload.value.0.value.value[3] =8
then msg.payload.a1 should be 4678
assuming .0. is actually an array index, try adding a function node with...
msg.payload.a1 = msg.payload.value[0].value.value.join('')
proof:
if the last part is an object with numbered properties then try this instead
msg.payload.a1 = Object.values(msg.payload.value[0].value.value).join('')
image`
Perhaps it's a good idea to use the copy value button to capture the entire msg.payload and paste it here instead of screen captures.
Then folks can stop having to make assumptions about your data.
Once again you have not posted the full context, so we don't know what the 1: object is. If you follow the instructions I posted earlier you can use the Copy Path button on the 0 element and it will give you the path that item. Then you can use that in the formula I posted earlier.
Here is what I do. This flow uses a state machine node from node-red-contrib-persistent-fsm
Upon the state change of each contact sensor it uses a change node to set the window status to true/false. That is fed into a join node, then into a function node. After that the output is run through a state machine which is then sent on to increase or decrease the open window count. There are some extra things in the payload that are passed along to get alexa to announce what window has been opened or closed and to set global variables for each one. Hopefully that helps.
[{"id":"e9f85247edc84d56","type":"group","z":"7a970dd2f2d67388","name":"Example Flow","style":{"stroke":"#000000","label":true,"fill":"#addb7b","color":"#000000"},"nodes":["9651c36a651b560d","9f850cdc54c04a82","8cdf9f495372322b","971e6d57fd26ed62","3e600fef1861556c","8485ccedb3fdc82b","14d60c274541a9e1"],"x":2308,"y":6119,"w":1664,"h":428},{"id":"9651c36a651b560d","type":"group","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","name":"All Windows","style":{"stroke":"#000000","label":true,"fill":"#bfdbef","color":"#000000"},"nodes":["f9701d841c940c0d","be352481d03ca30a","772730774634f996","45283b2c9bea5fa6"],"x":3104,"y":6199,"w":212,"h":322},{"id":"f9701d841c940c0d","type":"function","z":"7a970dd2f2d67388","g":"9651c36a651b560d","name":"Build Array","func":"var DiningRoomWestWindow = msg.payload[\"DiningRoomWestWindow\"];\nvar DiningRoomEastWindow = msg.payload[\"DiningRoomEastWindow\"];\nvar LivingRoomWestWindow = msg.payload[\"LivingRoomWestWindow\"];\nvar LivingRoomEastWindow = msg.payload[\"LivingRoomEastWindow\"];\nvar BedroomWindow = msg.payload[\"BedroomWindow\"];\nvar MasterBathWindow = msg.payload[\"MasterBathWindow\"];\nvar KitchenWindow = msg.payload[\"KitchenWindow\"];\nvar GuestRoomWindow = msg.payload[\"GuestRoomWindow\"];\nvar OfficeWindow = msg.payload[\"OfficeWindow\"];\n\nmsg.payload = [DiningRoomWestWindow,DiningRoomEastWindow,LivingRoomWestWindow,LivingRoomEastWindow,BedroomWindow,MasterBathWindow,KitchenWindow,GuestRoomWindow,OfficeWindow];\n\nreturn msg;\n\n//Array is buit based on order of sensors","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":3210,"y":6320,"wires":[["772730774634f996"]]},{"id":"be352481d03ca30a","type":"join","z":"7a970dd2f2d67388","g":"9651c36a651b560d","name":"Get Values","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":true,"accumulate":true,"timeout":"","count":"9","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":3210,"y":6240,"wires":[["f9701d841c940c0d"]]},{"id":"772730774634f996","type":"change","z":"7a970dd2f2d67388","g":"9651c36a651b560d","name":"Set Payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"$string(payload[0].currentValue) & \" \" & (payload[1].currentValue) & \" \" & (payload[2].currentValue) & \" \" & (payload[3].currentValue) & \" \" & (payload[4].currentValue) & \" \" & (payload[5].currentValue) & \" \" & (payload[6].currentValue) & \" \" & (payload[7].currentValue) & \" \" & (payload[8].currentValue)","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"windows","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3210,"y":6400,"wires":[["45283b2c9bea5fa6"]]},{"id":"45283b2c9bea5fa6","type":"state-machine","z":"7a970dd2f2d67388","g":"9651c36a651b560d","name":"All Windows","triggerProperty":"payload","triggerPropertyType":"msg","stateProperty":"payload","statePropertyType":"msg","initialDelay":"","persistOnReload":false,"outputStateChangeOnly":true,"throwException":false,"states":["Initializing...","all windows closed","all windows open"],"transitions":[{"name":"closed closed closed closed closed closed closed closed closed","from":"Initializing...","to":"all windows closed"},{"name":"open open open open open open open open open","from":"Initializing...","to":"all windows open"},{"name":"Initializing...","from":"*","to":"Initializing..."}],"x":3210,"y":6480,"wires":[["e63b61144a6805f2"]],"icon":"font-awesome/fa-gears"},{"id":"9f850cdc54c04a82","type":"group","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","style":{"stroke":"#000000","label":true,"fill":"#bfdbef","color":"#000000"},"nodes":["f735a3268c649b63","e63b61144a6805f2","cbf1ad3e851d6ace","5d6a699bcb680ca5","f6ef7c59eaaea41c","695f634015dbf90b","3cf473db337992e5","b960bc8aa3886b13"],"x":3394,"y":6259,"w":552,"h":202},{"id":"f735a3268c649b63","type":"rbe","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":3835,"y":6360,"wires":[["b960bc8aa3886b13"]],"l":false},{"id":"e63b61144a6805f2","type":"switch","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"Open/Closed","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"open","vt":"str"},{"t":"cont","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":3490,"y":6360,"wires":[["cbf1ad3e851d6ace","f6ef7c59eaaea41c"],["695f634015dbf90b","5d6a699bcb680ca5"]]},{"id":"cbf1ad3e851d6ace","type":"change","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"RESET","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":3665,"y":6380,"wires":[["695f634015dbf90b"]],"icon":"font-awesome/fa-refresh","l":false},{"id":"5d6a699bcb680ca5","type":"change","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"RESET","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":3665,"y":6340,"wires":[["f6ef7c59eaaea41c"]],"icon":"font-awesome/fa-refresh","l":false},{"id":"f6ef7c59eaaea41c","type":"trigger","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"15 seconds","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"topic","topic":"topic","outputs":1,"x":3665,"y":6300,"wires":[["3cf473db337992e5"]],"icon":"node-red-contrib-bigtimer/timer.png","l":false},{"id":"695f634015dbf90b","type":"trigger","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"15 seconds","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"15","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"topic","topic":"topic","outputs":1,"x":3665,"y":6420,"wires":[["3cf473db337992e5"]],"icon":"node-red-contrib-bigtimer/timer.png","l":false},{"id":"3cf473db337992e5","type":"junction","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","x":3780,"y":6360,"wires":[["f735a3268c649b63"]]},{"id":"b960bc8aa3886b13","type":"link out","z":"7a970dd2f2d67388","g":"9f850cdc54c04a82","name":"OUT - Contact Sensor Status","mode":"link","links":["a129361629c081e1"],"x":3905,"y":6360,"wires":[]},{"id":"8cdf9f495372322b","type":"comment","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","name":"Nodes to create an array","info":"First, everyting is sent to the join node\nSecond, the function node buiilds the array\nThird, I use a change node to get everything \norganized the way I want\nAnd finally I send that to a state machine","x":3210,"y":6160,"wires":[]},{"id":"971e6d57fd26ed62","type":"comment","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","name":"Counter","info":"Here is wehre I use the date to set the counter\nthen the reast of the data is passed along to\nother flows for alexa announcements, setting global\nvariables, etc. ","x":3660,"y":6220,"wires":[]},{"id":"3e600fef1861556c","type":"comment","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","name":"Contact sensor nodes","info":"These no-op nodes are stand ins for my \nhubitat contact sensor nodes and don't actually\ndo anything. \n\nImagine nine seperate nodes (one for each window)\nthat all connect to their own change node. Then all \nof them funnel into the join node.","x":2740,"y":6220,"wires":[]},{"id":"8485ccedb3fdc82b","type":"junction","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","x":3080,"y":6240,"wires":[["be352481d03ca30a"]]},{"id":"14d60c274541a9e1","type":"group","z":"7a970dd2f2d67388","g":"e9f85247edc84d56","style":{"stroke":"#000000","label":true,"fill":"#bfdbef","color":"#000000"},"nodes":["21059a69aecac317","6d5b434365411267","3374d2edad9333d4","f44172b6997788ea"],"x":2334,"y":6259,"w":712,"h":182},{"id":"21059a69aecac317","type":"change","z":"7a970dd2f2d67388","g":"14d60c274541a9e1","name":"Bedroom Window Contact State","rules":[{"t":"set","p":"topic","pt":"msg","to":"BedroomWindow","tot":"str"},{"t":"change","p":"payload.value","pt":"msg","from":"open","fromt":"str","to":"true","tot":"bool"},{"t":"change","p":"payload.value","pt":"msg","from":"closed","fromt":"str","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2890,"y":6300,"wires":[["8485ccedb3fdc82b"]]},{"id":"6d5b434365411267","type":"no-op","z":"7a970dd2f2d67388","g":"14d60c274541a9e1","name":"Bedroom Contact Sensor Node (no-op)","x":2520,"y":6300,"wires":[["21059a69aecac317"]]},{"id":"3374d2edad9333d4","type":"change","z":"7a970dd2f2d67388","g":"14d60c274541a9e1","name":"Kitchen Window Contact State","rules":[{"t":"set","p":"topic","pt":"msg","to":"KitchenWindow","tot":"str"},{"t":"set","p":"statusReport.windows.kitchenWindow","pt":"global","to":"payload.value","tot":"msg"},{"t":"set","p":"payload.status","pt":"msg","to":"$string & \"Kitchen Window \" & (payload.currentValue)\t","tot":"jsonata"},{"t":"change","p":"payload.value","pt":"msg","from":"open","fromt":"str","to":"true","tot":"bool"},{"t":"change","p":"payload.value","pt":"msg","from":"closed","fromt":"str","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2890,"y":6400,"wires":[["8485ccedb3fdc82b"]]},{"id":"f44172b6997788ea","type":"no-op","z":"7a970dd2f2d67388","g":"14d60c274541a9e1","name":"Kitchen Contact Sensor Node (no-op)","x":2530,"y":6400,"wires":[["3374d2edad9333d4"]]}]
Hello All,
Now I understand and here is the complete path from object to value--> Value
{"payloadType":"read","value":[{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":0}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.427Z","sourcePicoseconds":115000000,"serverTimestamp":"2024-12-20T10:59:55.427Z","serverPicoseconds":112000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":0,"2":0,"3":0}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.470Z","sourcePicoseconds":314000000,"serverTimestamp":"2024-12-20T10:59:55.470Z","serverPicoseconds":310000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":0}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.510Z","sourcePicoseconds":767000000,"serverTimestamp":"2024-12-20T10:59:55.510Z","serverPicoseconds":763000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":0}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.553Z","sourcePicoseconds":599000000,"serverTimestamp":"2024-12-20T10:59:55.553Z","serverPicoseconds":596000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":0}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.593Z","sourcePicoseconds":636000000,"serverTimestamp":"2024-12-20T10:59:55.593Z","serverPicoseconds":633000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":-1,"1":-1}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.633Z","sourcePicoseconds":634000000,"serverTimestamp":"2024-12-20T10:59:55.633Z","serverPicoseconds":630000000},{"value":{"dataType":"Int16","arrayType":"Scalar","value":5000},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.679Z","sourcePicoseconds":438000000,"serverTimestamp":"2024-12-20T10:59:55.679Z","serverPicoseconds":434000000},{"value":{"dataType":"Int16","arrayType":"Scalar","value":32767},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.717Z","sourcePicoseconds":369000000,"serverTimestamp":"2024-12-20T10:59:55.717Z","serverPicoseconds":365000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":32767,"1":-1}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.757Z","sourcePicoseconds":184000000,"serverTimestamp":"2024-12-20T10:59:55.757Z","serverPicoseconds":180000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":2312}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.797Z","sourcePicoseconds":774000000,"serverTimestamp":"2024-12-20T10:59:55.797Z","serverPicoseconds":770000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":2313}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.839Z","sourcePicoseconds":573000000,"serverTimestamp":"2024-12-20T10:59:55.839Z","serverPicoseconds":569000000},{"value":{"dataType":"Int16","arrayType":"Array","value":{"0":0,"1":2313}},"statusCode":{"value":0},"sourceTimestamp":"2024-12-20T10:59:55.879Z","sourcePicoseconds":747000000,"serverTimestamp":"2024-12-20T10:59:55.879Z","serverPicoseconds":744000000}],"nodetype":"read","injectType":"read","addressSpaceItems":[{"name":"ActPowerTotal","nodeId":"ns=0;i=50276","datatypeName":""},{"name":"ActiveImport","nodeId":"ns=0;i=50270","datatypeName":""},{"name":"CurrentL1","nodeId":"ns=0;i=50306","datatypeName":""},{"name":"CurrentL2","nodeId":"ns=0;i=50312","datatypeName":""},{"name":"CurrentL3","nodeId":"ns=0;i=50318","datatypeName":""},{"name":"CurrentN","nodeId":"ns=0;i=50324","datatypeName":""},{"name":"Frequency","nodeId":"ns=0;i=50330","datatypeName":""},{"name":"PhAnglePower","nodeId":"ns=0;i=50336","datatypeName":""},{"name":"RctpowetTotal","nodeId":"ns=0;i=50282","datatypeName":""},{"name":"VoltageL1N","nodeId":"ns=0;i=50288","datatypeName":""},{"name":"VoltageL2N","nodeId":"ns=0;i=50294","datatypeName":""},{"name":"VoltageL3N","nodeId":"ns=0;i=50300","datatypeName":""}],"manualInject":true,"readtype":"VariableValue","attributeId":13,"justValue":true,"sourcetimestamp":"Fri, 20 Dec 2024 10:59:55 GMT","a1":0,"a2":0,"a3":0,"a4":5000,"a5":32767,"a6":2313}
payload.value[10].value.value
