6. node-red-mcu
@ralphwetzel recommended me here to use node-red-mcu-plugin.
Similar to Kaluma, this could work only, if somebody would provide a "ready to use" example, how to communicate through the default USB with the "main NR".
I've searched for it for several days, but concluded:
- USB is reserved for debugging + new firmware upload.
- Communicating with the Pico board would be possible through Wifi or Ethernet only (which the USB version of Pico board does not have).
- There is no
MQTT -> to serialorWebserver over serialprotocol built in, Moddable scripts assume a presence of ESP32 or similar chip. - UART is reserved for PINs only.
Also it had to be written for both sides (host + board) laying down the communication protocol from scratch.
Once uploaded the firmware to the board, it would be impossible to dynamically change a "mcu-node" to something else. (For example an IO pin to PWM) from host side.
