Como Compartir solo mi dahsboar a internet, fuera de una red local?
Hola comunidad!!
Queria consultar como puedo hacer que alguien al otro lado del mundo vea mi dashboard con los datos publicados a traves de internet?
Fuera de una red local..
Hello community!!
I wanted to ask how I can make someone on the other side of the world see my dashboard with the data published over the internet?
Outside a local network..
Hi, welcome to the community. It is best to publish in English to be honest as that is what most people speak here.
Yes, you absolutely can. However, it can be somewhat dangerous without suitable precautions. Check out the security FAQ and related threads.
In my view, the easiest and most secure approach is to use one of the cloud-based solutions such as Cloudflare Zero Trust (CFZT). Using that, you create a secure link from your local installation to the Cloudflare secure services. External users connect to Cloudflare and it takes care of the secure connection.
CFZT has a generous free tier.
You should be able to find threads in the forum with information that will help you get going.
There are other approaches too depending on your actual needs.
Hello and welcome to the Forum.
Tailscale is another offering worth looking at. Very easy to set-up and use.
It has a FREE forever tier.
Tailscale and CFZT are two very different approaches to the issue.
Tailscale is a VPN solution, it creates a private network extended over the Internet. CFZT is largely a cloud application proxy solution though it can also be used to set up private networking too I think.
The approach you choose largely depends on your requirements. Whether you want external people to have access to a private, encrypted network or whether you want to take a more web-based approach.
