Compare msg.payload numbers
I have 2 function nodes which gives output as -
f1 node output : msg.payload.number - 123
f2 node output : msg.payload.number - 456
if f1==f2 then popup=employeeid.
This should show a popup with employeeid in worldmap
Could anyone please help how I can achieve this
Which are you struggling with comparing the two numbers or generating the world map entry?
Also show us your flow - I suspect the two values are in separate messages but I cannot tell from your description.
Here is my flow :
https://docs.google.com/document/d/1i5PCGMtCn08LK3MErH-CczySyK42Pllj2d3G3ersmWs/edit?usp=sharing
So I want to compare the output of text input node and the output of function node before worldmap node.
function node output : msg.payload.delivery_id --> received from mqtt
text input node output : msg.payload (which is also a delivery id) --> manually entered
I want to compare these 2 and if they are equal I want to add a popup in worldmap..
