Compare negative numbers
i try a simple compare from negative numbers like this:
if (number1 << number2){
result = 1;
if (number1 >> number2){
result = 2;
For example:
if (-300 << -200){
result =1;
if (-300 >> -200){
result=2;
But my result is always result = 2
With positive numbers it works but with negative doesn`t works
I tried to parse the string numbers in float numbers before compare but it doesn`t works too
can somebody give me a simple example for a compare with negative numbers
>> and << are the right and left shift commands
For less than you want <
for less than or equal you want `<=
Thank you
now it works after i found a further mistake
For testing i used inject nodes and i send strings as payload instead of numbers :man_facepalming:
after searching for the mistake i build in a second and lost my mind :expressionless:
