I want compare get where it's a day time or night time. I'm getting sunrise and sunset time from the weather API. I don't how to compare the data using switch node.
Format the sunrise and sunset times to UTC (milliseconds since 1 January 1970) then get the current time (JavaScript Date getTime() Method) and use a switch node or function node to do the comparison
msg.data, msg.sunrise and msg.sunset was getting correct but whenever i run this it giving otherwise output only
You will have two msgs entering the comparing node BUT they will not arrive at the same time. You would need to use a join node before the 'Comparing' node to get them to arrive at the same time.
If you move the 'Set msg.data right after the 'Weather data' node, you could have the current time in the same msg as the sunrise or sunset time.
The join node is not what you want here.
Put all nodes in series and all properties into individual propertys (e.g. inject msg.now = timestamp, msg.sunrise = msg.payload.xxxx, msg.sunset = msg.payload.yyyy `
then your compare can do between msg.sunset and msg.sunrise etc.
If you are simply trying to figure out what point of the day it is, then I recommend node-red-contrib-cron-plus...
Demo flow...
[{"id":"a6d46dff.aca4d","type":"inject","z":"c876e57260edd2ab","name":"describe solar","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"command\":\"describe\",\"location\":\"35.45743499930747 139.63778346776962\",\"expressionType\":\"solar\",\"solarType\":\"selected\",\"solarEvents\":\"sunrise,sunset\",\"timeZone\":\"Europe/London\",\"offset\":60,\"info\":\"Get sunrise/sunset times and status at yokohama intercontinental (35.45743499930747 139.63778346776962)\"}]","payloadType":"json","x":730,"y":1660,"wires":[["4eb68abd.a39914"]]},{"id":"4eb68abd.a39914","type":"cronplus","z":"c876e57260edd2ab","name":"","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output2","defaultLocation":"","defaultLocationType":"default","outputs":2,"options":[],"x":1020,"y":1660,"wires":[[],["2d35c203.e28a0e"]]},{"id":"2d35c203.e28a0e","type":"debug","z":"c876e57260edd2ab","name":"Command result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1220,"y":1660,"wires":[]},{"id":"c4fd78d7.203dd8","type":"comment","z":"c876e57260edd2ab","name":"Simple demo of using the describe command to get solar state","info":"","x":860,"y":1620,"wires":[]},{"id":"a5ef21003ae53641","type":"cronplus","z":"c876e57260edd2ab","name":"","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output2","defaultLocation":"","defaultLocationType":"default","outputs":2,"options":[{"name":"ukne","topic":"uk/ne/solar_events","payloadType":"default","payload":"","expressionType":"solar","expression":"0 * * * * * *","location":"54.9990878447323 -1.4176440238952634","offset":"0","solarType":"selected","solarEvents":"sunrise,sunset"}],"x":960,"y":1780,"wires":[[],["3e7e072d1929f45d"]]},{"id":"3e7e072d1929f45d","type":"debug","z":"c876e57260edd2ab","name":"Command result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1220,"y":1780,"wires":[]},{"id":"fe54c07f1471b999","type":"comment","z":"c876e57260edd2ab","name":"Simple demo asking for status of a fixed solar schedule","info":"","x":840,"y":1740,"wires":[]},{"id":"f1c6f23ee6f27315","type":"inject","z":"c876e57260edd2ab","name":"status of ukne","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"status","payload":"ukne","payloadType":"str","x":730,"y":1780,"wires":[["a5ef21003ae53641"]]}]
