You might also want to look into why the compass is showing an error of 15 degrees. Since it's not variation or deviation there must be something else off, possibly the sensor not mounted correctly in whatever housing it's in.
Might be worth contacting the manufacturer to find out if this is normal behaviour or if there's something wrong with your one.
