Microsoft Windows [versão 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Todos os direitos reservados.
C:\Users\aieser.santos>node-red
18 Sep 11:46:47 - [info]
Welcome to Node-RED
18 Sep 11:46:47 - [info] Node-RED version: v1.1.3
18 Sep 11:46:47 - [info] Node.js version: v12.18.3
18 Sep 11:46:47 - [info] Windows_NT 6.1.7601 x64 LE
18 Sep 11:46:50 - [info] Loading palette nodes
18 Sep 11:47:07 - [info] Dashboard version 2.23.2 started at /ui
18 Sep 11:47:07 - [info] Settings file : \Users\aieser.santos\.node-red\setting
s.js
18 Sep 11:47:07 - [info] Context store : 'default' [module=memory]
18 Sep 11:47:07 - [info] User directory : \Users\aieser.santos\.node-red
18 Sep 11:47:07 - [warn] Projects disabled : editorTheme.projects.enabled=false
18 Sep 11:47:07 - [info] Flows file : \Users\aieser.santos\.node-red\flows_A
COM201.json
18 Sep 11:47:07 - [info] Server now running at http://127.0.0.1:1880/
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
18 Sep 11:47:07 - [info] Starting flows
18 Sep 11:47:07 - [info] Started flows
18 Sep 11:47:07 - [info] [mqtt-broker:ESP32CAM_MQTT_01] Connected to broker: mqt
t://192.168.0.102:1883
18 Sep 11:47:18 - [error] [base64:35f80a71.2e27b6] Invalid Base64 string
18 Sep 11:47:18 - [info] [debug:d34326f2.7cada8] /9j/4AAQSkZJRgABAQEAAAAAAAD/2wB
DAAoHCAkIBgoJCAkLCwoMDxkQDw4ODx8WFxIZJCAmJiQgIyIoLToxKCs2KyIjMkQzNjs9QEFAJzBHTEY
/Szo/QD7/2wBDAQsLCw8NDx0QEB0+KSMpPj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4
+Pj4+Pj4+Pj4+Pj4+Pj7/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQ
DBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ
1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaa
nqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQE
BAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2F
xEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmN
kZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycr
S09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCADwAUADASEAAhEBAxEB/9oADAMBAAIRAxEAPwD
ikYL/AACrCybh91fyrVsm19zV0vQrzVW/0a1dwp+YqOlT6t4VfTYfOuF2Y+8pNGhLVjmXjj8zGK3dJs0
2+ZJCM9s0FWH6lDCsX3VFaXhbwpHdRLd3cWQeVTNZyl0LUep2kGl2UAx5Ma1O0Nog4RKSQzOuvJ7Rriq
G+IN9xaGPlLkMkX/PNKuxGBv+WaVI+QseVF/zzWjZCf8AlmlUg5RrJF/zySoHEQ/5ZrQLlK7+V/zzWq8
nlf3FoDlMu/EeM7Frm9UVCgO0cGjqDjoYdxEvDbapOFH8NbIzcSAr600gUmMYVFNpALtpdoo0EGBSYFA
w4FHFFgsJgVLageevGaAsbl0IzCAFFYcyjJxU9CLEG0Um3NIo2t4qaGUBqqwI7nwZ4lOlNPi0luEnC52
npWP4q1u91q8aWbEMX/PNa1slqT1MO2jDzDIzXUqwS3zWbLMi6kM91HHnhmA6V6V4fKiFUrKW5olodC+
kQXCAsX/A4rH1LQWjRjaTy59H5q0rhc5idp4JvKnGDVWU4bNRYq5NFPV2GakM1IJ8pzTjLzQIYZ+arvL
TArPLVWaakBnXMvy1iXzfujQgIb2yKaVY3fzeXMNre7VhXMexq0vchorGoqZA3NJimgFopMTCjNKwxtF
MBDmnQkrKDTA1HmylZ0nJqAIqSgNjYqaHrWnUDqWlUaWEGAa564b5qt7GYls375frWzcTbIsCs2aGbaP
u1OPPPevRdBn+7WUtzZbHf2b7oBU5UN1FVHcyZzXi/TY57Lz0X97H6VwRO6OnULjew1GxVmJ6go0baXm
pnkoArtJUTS0CK7yVUlkpDKUz1mSqZpkjXq7YoA6vWdPz8NLcxR8WeyTIFcDccjmqQjLkG01Casxe43H
rS0DCl4oAbmkzSAOaTmmIOaShjLKNlKiaoAjppp3Ea2akjPzVaE2bK3O62x3rOc5PNaMB1v8Afqe5lNQ
UtyCzf/TVNd5ok+GFYz0Zutj0LSbgZ2k8MtaUsqoua0h3MZIxr+bzbVwfSvN3+SaRfeioXDsRbvmqaNs
VkWWVkqYy4piIWm4qu01AEMlxVWSbNAFWWQ4xVzw5p0mra/BapwF/eSMewpsR6Jr9iv8AwhOo2vJxbvg
n8a8Rd90Sv6jNEfhJKMnWoDVkDaKYhcUbCe1Kwx3lmlEdOwBso2UhCeV71IIBj1pjI8FWxjFNdTUiIqb
SS7j6mtTkp9Qepbjc4ph+/VvYViZODTJDnOKBkFu2LxSa7LSJsYzWU9zWnsdxY3W1Eb0rTmvwYqcCWjA
v9R8oHmuVOWdnPenJjiRN96l3VLLH+ftFRveUiSBruoGu/emhEJuTTDNmgdxAc16L8OdN8nSbzU5M/wC
k/Kgz/AtKWgHS+Ihs8O6nJ2+zt/Kvn+zt5b6e1tLaPzJpsKiepxVIm5Hf209ndy2t3A8FxEcOj9qosKs
gbjmjFADxwKdmi9gOk0zw6JIpV1GZoJWwY/L+bFNk8JXi/wCpv7OT2YOtc3t9RGbc6PqVo+2azdv9qH5
xVb7LdY3fY7nb6+Ua3UkwTK7ZU/Mjr9UIpnnqp+9TuA/7VC339n1p/nQFfvCpdmFhmYz6UpEfoKgCbvS
g1sA8OaeDQw6F63VvKJI+lR/Z5GfaMAe5pXENbT25y8f61r6bP5TKkhH1qHqaxZ2+mv50GFdfzq01tPt
/eXK7f9miI2Z11Dbr/tn1Y1mTNEOlAilLKoqpJdKKLDRRkv8ALcIcetQyTylcoRTSEyv9pf8Aip6sz96
YiYIT1qULUlmno2lnU7wRORHb/wDLSQg4+lev2xs0iSOOeIRRgBR04peYeRmeM5xdeG5rGymhee8YW6/
OMLnvXlfhSCO3+JFnCH3xWkjsZAh52r1pqS2MpGPrN8dV1a81Jznz5mcdfu/w1kOc1r5CG0lSMXFXdHt
ReapHA20IAZDlsZx2qJ6RC56RZRSR2+6QctRI2OlcjER/aJF+6cUn2uX+8fzqLCsH26X1qNrgP9+ONvq
tSSRt9mb71nb/APfFMKWR/wCXK2/791V2BE1ppzdbC3/75pv2HTe1nCPwo5n3AwDoV6fuRq3+69RNo9/
H96yl/DmvUaHoJHZTf8+0v/fJqzFazYz9nm/74qGMspbnb/qHP1WpAAh+aAH2akA/y1c5EYFXILeL+O3
X6mpZUTWsLBf7rAH0arsunnZxPcf99UJlu5mzaZu+/czr9MVSuNMYL+7nlc+hWgLlFrCZeqn8qiFiW6d
fSi4hDpU38SFai+xSniJN/wDu07iK50+7/wCfSb/viiGEqdrjY3o1NjLYhbrlT9KPLYVI7nTeG9Q2BYD
gMOwrvIW+U+gqWNGD45uQvhiZQF3SOFWvLX+Rvlyp9quO1iWVi5HC1GzluDiqaII/lP8AAKXZF/zyFLV
DDyo8fdo+y7h/qyaOYNS1a6rqNooW1u5kQfwE7hWpD4jvduJoIZj6/drGULiLv9rNt3S2bKP9ls00a1Z
lsN5ifUVhyPoBYS8t5PuyrTvMT1rOxIBlP8S/nS8+lAhuaTNAFjdtpwua9bmuJkv2knuaT7Xt9fwqR2A
ahnjGaRsyrnC0WAiCLuwY1q/bqMcRipaNIm1aY2cpV3YhWpRRSnhQ9aqG2iPrTsSQSacrfdlYfhUDaXI
OVk3fhU2AiexvgpPlmqW2VT9z/wAdoAcZZP41NH2gf88Q/wBaY7CL5MjYeL9aWa0gHQSj6mpuBJZ6dAx
3i6kDDtsFdJYYjhI3Pn1BxUlXsYvip3uPJtklLBTuZZXrm59P3x/Isav3O+rjoS2ZrWcm7iBn/wB2k+x
SH/lxlH4mqbF0EuIPK5SGZP8AepLa2kuOR8qf3jR0BIsG2MA3na2O7CmW8n2qRk3L9KjpcRe/s5gufs8
T1G1gpPMSpWfMxDXs49nD4NRrp3cMKnn6BcmW12c7OfaoZnkKlSD+VJ2EVGhPXmkBmX7ryfnTGS/ar1R
8szH60n9pXw+8Fo5EI639yeoqXybc/wAGa6CSVIY+yVHLbGThRigREmlOv8YqVrF+0gFPmKQwxbe+av2
K7mApNmiOgt0VcBq0NsRXinEZVmhibOazGt2UnbVXEVyzqaYZJe2akAWaYr838qrhpIpd8XBqSrE4u7j
b86Bv+A1AbjD5MKflSsIimud/HlqPpR5ylMMKLAQhYM/fIrQs1WN8rcFlpiuZOsJ5t/LPv3bqziEPWrE
2NI29BVm1gkn6Rtt7mpEXorFIm3Y/OoL28ijzFFEhOPSoXvSGzDnlzw2DToLuOIf8e6k+oraUSDUiuAe
MVIxjk/hrnsMabC1I+bP4GoGtLdf9Wz/jUgPhhG7/AFv6VNLacZHzUcoFQ2PmdQB+FV59JIHyyClZoCn
/AGTcZ+WQU1tPuk6qGquYDbU81oW3A5rdiLO/0qFpWpCtqCyse9OZsjrRYog/irUsh8wpMuJ1emhGI3q
DWi6W2P8AVihDMe/8uMErWMb1hQ0Ir/aNzciplnH92lYZLFMu7lRirDrGwyFFBRUkz/dqlKu48imIrvF
UTR0CIStTwsUjxTEVLljUdukjtxEfqRVNqxBe+x+uKnM/kpzWTGjOu7+RiFTAWqnko5y1aQ0Eys9jGxJ
8zFRfYEx/rT+VVcQC0Zj8sh/OrMfmRfKzbhUuNxkpmGKi8zNRyCHpIoqwl04HFAhPtJ9qikl307jBHFL
LOgHAqXEBQtWFJArUZPE1NfrTYhoqZelIoCMGtSw7VDLR0NrLtFTTXPHWmgZlXbmUYqk1s+OlIBq2/rS
+XinYLkkcZ9KlAkWlYYnmHutJlCeRRYYjRxt2qCa0Aj3UWJM1ouab5EjfdoEyWO12nMnNSk+lDYitcXQ
j+tZlxNNJ34oihMqjfv6VpRmIr8wFNiKtykI+6BUSxRuvP86WohGg2/dJqJ4ZO1VdiI/n7ilHHarAeGq
QMMUhibhSVDRI/cBTSQaXKBd2kUtWWTQ/eq7PEvbmmBX8upFSpKHbau20gWpYy+s9OaQnvQVYgYmpo7j
5cNRcB6MrVKI0NVcRMoRak3R46UDIW8s1BIq9qBEQXFPkHmRbam4MzzbAGncKOKVxFeQ96pSSFuFpIRV
a1kbmq8sEorVMkr4kXtTt7elMCKTd6UwMw7GmA4ytSC4PemIDNntRuosSJkVEXpFEfmYpPtOKW5NhfP3
U7fVAb1KFrM0Jo4qt4+Wi4yOm5xSGANOBpATLJiplmoAf5tG4GkUTpVhaRRJTTVAMoyT0pCJ0iPenSKF
WoEUJPmqrJ8lMkzp5s8Cqyt5ZyRVkkwvFqNrhXosSPjQNQbXNFxjhbgVFPEmKFqBSMFQNBWlgI/LpCBT
sITFRstSBEY6iMNKwhyxYqXbigDs1s19KsJYLUNmhZSyX0pJLQClzAUZYMVWaNqoCPY1TpCxoAsC2PpS
/Z2FIZG0bCm/NQBZgNX42pMosZGKhkpACJu61bjjC0FAz46VBI3HNQIoyyYrNnZpKuKIZVSE+Z81S3EQ
8rirZJkMpzUXzDpVCLMdwV7VOl8KloRKbkMODVd3zREYzdTSRWoETDNQlKoVxNtNKZqRDClQ7aBiEEVG
Sc01qQehrJVhZxWJsP+01G1xmpsA3hqaYRTFcj8oVPFgUmMvR7KkZEIqRlWSBTRHZj0pjRKLEVILI1HM
MPs2KTy/WquMeBig5NIBPLqpODQgM2SNyai8ph1FaIgay1BJuIxigRX8ij7P7UXERyRD0qo64NNAIKkB
qiQzTGqgGU1qYDKac0XGRlqSkIQ03ZVCOw3EUvmmsTUUS09TTQFmOpqUiLEbiqrGQGkBLHPIKsi5Peix
Y5ZeatQzUmMvRNVgNWbKApmomgNFwGGPFMGM0AS4FQyRCgCuYRUZtl9KCSrcQqFrMkXmrQiMLT9lADGi
zVOa0ouKxUeDbURVqtMTEKtTCGrS6ECq2aspF61LYhWtxUTQVHMNlZ4sVDtxVcxI00oqriudfTcVJsMP
FOVqALMbVZTJoAspDmn/ZRUXAjNsKjaGlcBojq1EuKLgXYzUwas2UixG+BSSXCihFFOafNVPNOa0SESC
Y1FLcEU7CKxvKb9t96OUkgmutwqg7807Ejd9P84UcoXHCUU1zkVNrDuU5RUG2qELik2ikMNoFSqVFK4r
CM4qF3FSIpysKqOapCGVLHVMDrqMUzQQpmlWE0AWI48VaTihgWUkAp/nVmIaZM0w1IDacpoAmR6sq4xU
FjZJsVTeUk1rFAA5pcYrQY3NVpzQBnytiqzS1VjMjM1M8zNBIbqTNMCRal7VDAjdagZakZGaaWxSAjaW
ozcUDGNP6VAzmmokkDsaiLGq5RArVKr0coI7QVIqZoNCYJUmBQAwkCm+ZSAXfT13UhE4Bp1QA0ioycUD
ASYqQT0WKEMuaQcmtEBOtIxpgR1BLQBQmFU3FUQyuwplUIWjNIBQ+2pxNSZIvmUwsDWdhkZqMrSAhdar
stUgI9tNIq0K5EVqMrVCE20baYjukFTBsVibDvMppegBvWl2UxEqJVhFrNsZOBS4qBkMlVWpoRHUioa2
KJglOxigYtJmgQ3NRvQBSlqqwqiCFlqErTJG4pDQOw2koAQk0m40iQ3mk8ypAazZqE0DGUw1YiJqaaBC
YpKYrHahqdnNZGwoFSpGTQBYWGneXSuIb0p4apYx3mUnnVNhjDJTM1aQxVFTLViHUmaAG5ppoAYTUbGg
RXeoGFMRCwqE0wI6YaBDaSgApMUCGGmGgBhptAiM0w0wGUygAptFhnceXUixk1kUWY4KuJBUsZL5VNZK
m4Fd1xVZmpgQM9R+ZVgOD08NTAkDU8SUwDzKb5lACeZSb6YDS9MLUgGE1C1MRC1RNTERUygBtJQAlFIQ
01G1AEZplMCM1GaYDaaaYhppKTA9H8qpUjrEssIBU64qGMk4qKQipAozvWdK9aICsWpAa0ESA08NQMdu
pd1ACbqTdTAM0m6gQm6jNADCaYaAImqI0CIzTKYDaSgBKKQhhNRk0CIjTDQMYajNMQym5pgJRTBHqhWm
1zFibqXzcUhjDce9QyXPvRYCnNPVKSWtESR5p4qxj807NIY7NLmgQ3NGaBi5pKYhKBSAKYaYERFRmmIY
aYRSAZTaAEopARtURpkkZphNAyMmoyaYDKSgQtKKBHqJNQuaxRZVeXFQm4oGRPcVAZqoCJpM1HVIQ4U/
NMYuadmkA7NGaYCUtADqQ0hBRTGOphoERmozQBGaYaAGGmUCEopARNURpgRmojTAjNRk0wGUmaZIoNTL
UgelsaryPWKLKEzVQkfmqsNEXmUu6qsAop1UIWlpDFp4oAkxRikIaaTNMY7NFAhaKBi02mIjNRGkBGTU
ZNADKTNACZpM0CImqImgRGaiNMZETUTUCG0ZqmITdUytSA9JkNUpmrAsozPVJmzWiEIKeKYySjNAgpRT
GSquasxx1LAnEVO8moGQPFVdlxTuAzNOzVCFzTqYBUZNAEZNRsaoRCxqMmpAbupuaAEJpM0CImamE0wI
yaiagZCxqMmmIZnmkJ5piCnA0hnpbvVKY1gMozVVrRAhwFPpjFpM0xBViNKQFuKOrscdRIZaSKnGOswK
8kdUZkpoCm4pma1QDxTxVCA1E1AEbGoWNAELGmZoAjJpuaAEzRmkBCxqPNUSIaiY80DImNRGgQ3NJmiw
CZpwNMZ6JI1VnNY2GVZOahIqhi06qEFNpDJo1q7EtJiL0SVcjWsmMsqKcRUAVpRWfNQgM+Wq3et0BKKe
KoQGonpgVmaoiaAI2NRE0AMJpuaYgoJ4pCK7HmmZoAaWqImqAiLUzNADc03NAxacKAPQWaojWQyJhUDU
ANp1UMSkFMC3EKvRCpkIvRCra1iwH5p26pGV5mrOnNNAZ8xqt3reIidBmnmqEMNV5GpgVWaoy1IZGWqM
tTEJmm5oENzQTSAgeot3NMYwmoy1MCImkJoENzSUhhmlBpgf/2Q==9j/4AAQSkZJRgABAQEAAAAAAAD/
2wBDAAoHCAkIBgoJCAkLCwoMDxkQDw4ODx8WFxIZJCAmJiQgIyIoLToxKCs2KyIjMkQzNjs9QEFAJzBH
TEY/Szo/QD7/2wBDAQsLCw8NDx0QEB0+KSMpPj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+Pj4+
Pj4+Pj4+Pj4+Pj4+Pj4+Pj7/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMD
AgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp
KjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOk
paanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQAD
AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFR
B2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZ
WmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfI
ycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCADwAUADASEAAhEBAxEB/9oADAMBAAIRAxEA
PwDikYL/AACrCybh91fyrVsm19zV0vQrzVW/0a1dwp+YqOlT6t4VfTYfOuF2Y+8pNGhLVjmXjj8zGK3d
Js02+ZJCM9s0FWH6lDCsX3VFaXhbwpHdRLd3cWQeVTNZyl0LUep2kGl2UAx5Ma1O0Nog4RKSQzOuvJ7R
riqG+IN9xaGPlLkMkX/PNKuxGBv+WaVI+QseVF/zzWjZCf8AlmlUg5RrJF/zySoHEQ/5ZrQLlK7+V/zz
Wq8nlf3FoDlMu/EeM7Frm9UVCgO0cGjqDjoYdxEvDbapOFH8NbIzcSAr600gUmMYVFNpALtpdoo0EGBS
YFAw4FHFFgsJgVLageevGaAsbl0IzCAFFYcyjJxU9CLEG0Um3NIo2t4qaGUBqqwI7nwZ4lOlNPi0luEn
C52npWP4q1u91q8aWbEMX/PNa1slqT1MO2jDzDIzXUqwS3zWbLMi6kM91HHnhmA6V6V4fKiFUrKW5olo
dC+kQXCAsX/A4rH1LQWjRjaTy59H5q0rhc5idp4JvKnGDVWU4bNRYq5NFPV2GakM1IJ8pzTjLzQIYZ+a
rvLTArPLVWaakBnXMvy1iXzfujQgIb2yKaVY3fzeXMNre7VhXMexq0vchorGoqZA3NJimgFopMTCjNKw
xtFMBDmnQkrKDTA1HmylZ0nJqAIqSgNjYqaHrWnUDqWlUaWEGAa564b5qt7GYls375frWzcTbIsCs2aG
baPu1OPPPevRdBn+7WUtzZbHf2b7oBU5UN1FVHcyZzXi/TY57Lz0X97H6VwRO6OnULjew1GxVmJ6go0b
aXmpnkoArtJUTS0CK7yVUlkpDKUz1mSqZpkjXq7YoA6vWdPz8NLcxR8WeyTIFcDccjmqQjLkG01Casxe
43HrS0DCl4oAbmkzSAOaTmmIOaShjLKNlKiaoAjppp3Ea2akjPzVaE2bK3O62x3rOc5PNaMB1v8Afqe5
lNQUtyCzf/TVNd5ok+GFYz0Zutj0LSbgZ2k8MtaUsqoua0h3MZIxr+bzbVwfSvN3+SaRfeioXDsRbvmq
aNsVkWWVkqYy4piIWm4qu01AEMlxVWSbNAFWWQ4xVzw5p0mra/BapwF/eSMewpsR6Jr9iv8AwhOo2vJx
bvgn8a8Rd90Sv6jNEfhJKMnWoDVkDaKYhcUbCe1Kwx3lmlEdOwBso2UhCeV71IIBj1pjI8FWxjFNdTUi
IqbSS7j6mtTkp9Qepbjc4ph+/VvYViZODTJDnOKBkFu2LxSa7LSJsYzWU9zWnsdxY3W1Eb0rTmvwYqcC
WjAv9R8oHmuVOWdnPenJjiRN96l3VLLH+ftFRveUiSBruoGu/emhEJuTTDNmgdxAc16L8OdN8nSbzU5M
/wCk/Kgz/AtKWgHS+Ihs8O6nJ2+zt/Kvn+zt5b6e1tLaPzJpsKiepxVIm5Hf209ndy2t3A8FxEcOj9qo
sKsgbjmjFADxwKdmi9gOk0zw6JIpV1GZoJWwY/L+bFNk8JXi/wCpv7OT2YOtc3t9RGbc6PqVo+2azdv9
qH5xVb7LdY3fY7nb6+Ua3UkwTK7ZU/Mjr9UIpnnqp+9TuA/7VC339n1p/nQFfvCpdmFhmYz6UpEfoKgC
bvSg1sA8OaeDQw6F63VvKJI+lR/Z5GfaMAe5pXENbT25y8f61r6bP5TKkhH1qHqaxZ2+mv50GFdfzq01
tPt/eXK7f9miI2Z11Dbr/tn1Y1mTNEOlAilLKoqpJdKKLDRRkv8ALcIcetQyTylcoRTSEyv9pf8Aip6s
z96YiYIT1qULUlmno2lnU7wRORHb/wDLSQg4+lev2xs0iSOOeIRRgBR04peYeRmeM5xdeG5rGymhee8Y
W6/OMLnvXlfhSCO3+JFnCH3xWkjsZAh52r1pqS2MpGPrN8dV1a81Jznz5mcdfu/w1kOc1r5CG0lSMXFX
dHtReapHA20IAZDlsZx2qJ6RC56RZRSR2+6QctRI2OlcjER/aJF+6cUn2uX+8fzqLCsH26X1qNrgP9+O
NvqtSSRt9mb71nb/APfFMKWR/wCXK2/791V2BE1ppzdbC3/75pv2HTe1nCPwo5n3AwDoV6fuRq3+69RN
o9/H96yl/DmvUaHoJHZTf8+0v/fJqzFazYz9nm/74qGMspbnb/qHP1WpAAh+aAH2akA/y1c5EYFXILeL
+O3X6mpZUTWsLBf7rAH0arsunnZxPcf99UJlu5mzaZu+/czr9MVSuNMYL+7nlc+hWgLlFrCZeqn8qiFi
W6dfSi4hDpU38SFai+xSniJN/wDu07iK50+7/wCfSb/viiGEqdrjY3o1NjLYhbrlT9KPLYVI7nTeG9Q2
BYDgMOwrvIW+U+gqWNGD45uQvhiZQF3SOFWvLX+Rvlyp9quO1iWVi5HC1GzluDiqaII/lP8AAKXZF/zy
FLVDDyo8fdo+y7h/qyaOYNS1a6rqNooW1u5kQfwE7hWpD4jvduJoIZj6/drGULiLv9rNt3S2bKP9ls00
a1ZlsN5ifUVhyPoBYS8t5PuyrTvMT1rOxIBlP8S/nS8+lAhuaTNAFjdtpwua9bmuJkv2knuaT7Xt9fwq
R2AahnjGaRsyrnC0WAiCLuwY1q/bqMcRipaNIm1aY2cpV3YhWpRRSnhQ9aqG2iPrTsSQSacrfdlYfhUD
aXIOVk3fhU2AiexvgpPlmqW2VT9z/wAdoAcZZP41NH2gf88Q/wBaY7CL5MjYeL9aWa0gHQSj6mpuBJZ6
dAx3i6kDDtsFdJYYjhI3Pn1BxUlXsYvip3uPJtklLBTuZZXrm59P3x/Isav3O+rjoS2ZrWcm7iBn/wB2
k+xSH/lxlH4mqbF0EuIPK5SGZP8AepLa2kuOR8qf3jR0BIsG2MA3na2O7CmW8n2qRk3L9KjpcRe/s5gu
fs8T1G1gpPMSpWfMxDXs49nD4NRrp3cMKnn6BcmW12c7OfaoZnkKlSD+VJ2EVGhPXmkBmX7ryfnTGS/a
r1R8szH60n9pXw+8Fo5EI639yeoqXybc/wAGa6CSVIY+yVHLbGThRigREmlOv8YqVrF+0gFPmKQwxbe+
av2K7mApNmiOgt0VcBq0NsRXinEZVmhibOazGt2UnbVXEVyzqaYZJe2akAWaYr838qrhpIpd8XBqSrE4
u7jb86Bv+A1AbjD5MKflSsIimud/HlqPpR5ylMMKLAQhYM/fIrQs1WN8rcFlpiuZOsJ5t/LPv3bqziEP
WrE2NI29BVm1gkn6Rtt7mpEXorFIm3Y/OoL28ijzFFEhOPSoXvSGzDnlzw2DToLuOIf8e6k+oraUSDUi
uAeMVIxjk/hrnsMabC1I+bP4GoGtLdf9Wz/jUgPhhG7/AFv6VNLacZHzUcoFQ2PmdQB+FV59JIHyyClZ
oCn/AGTcZ+WQU1tPuk6qGquYDbU81oW3A5rdiLO/0qFpWpCtqCyse9OZsjrRYog/irUsh8wpMuJ1emhG
I3qDWi6W2P8AVihDMe/8uMErWMb1hQ0Ir/aNzciplnH92lYZLFMu7lRirDrGwyFFBRUkz/dqlKu48imI
rvFUTR0CIStTwsUjxTEVLljUdukjtxEfqRVNqxBe+x+uKnM/kpzWTGjOu7+RiFTAWqnko5y1aQ0Eys9j
GxJ8zFRfYEx/rT+VVcQC0Zj8sh/OrMfmRfKzbhUuNxkpmGKi8zNRyCHpIoqwl04HFAhPtJ9qikl307jB
HFLLOgHAqXEBQtWFJArUZPE1NfrTYhoqZelIoCMGtSw7VDLR0NrLtFTTXPHWmgZlXbmUYqk1s+OlIBq2
/rS+XinYLkkcZ9KlAkWlYYnmHutJlCeRRYYjRxt2qCa0Aj3UWJM1ouab5EjfdoEyWO12nMnNSk+lDYit
cXQj+tZlxNNJ34oihMqjfv6VpRmIr8wFNiKtykI+6BUSxRuvP86WohGg2/dJqJ4ZO1VdiI/n7ilHHarA
eGqQMMUhibhSVDRI/cBTSQaXKBd2kUtWWTQ/eq7PEvbmmBX8upFSpKHbau20gWpYy+s9OaQnvQVYgYmp
o7j5cNRcB6MrVKI0NVcRMoRak3R46UDIW8s1BIq9qBEQXFPkHmRbam4MzzbAGncKOKVxFeQ96pSSFuFp
IRVa1kbmq8sEorVMkr4kXtTt7elMCKTd6UwMw7GmA4ytSC4PemIDNntRuosSJkVEXpFEfmYpPtOKW5Nh
fP3U7fVAb1KFrM0Jo4qt4+Wi4yOm5xSGANOBpATLJiplmoAf5tG4GkUTpVhaRRJTTVAMoyT0pCJ0iPen
SKFWoEUJPmqrJ8lMkzp5s8Cqyt5ZyRVkkwvFqNrhXosSPjQNQbXNFxjhbgVFPEmKFqBSMFQNBWlgI/Lp
CBTsITFRstSBEY6iMNKwhyxYqXbigDs1s19KsJYLUNmhZSyX0pJLQClzAUZYMVWaNqoCPY1TpCxoAsC2
PpS/Z2FIZG0bCm/NQBZgNX42pMosZGKhkpACJu61bjjC0FAz46VBI3HNQIoyyYrNnZpKuKIZVSE+Z81S
3EQ8rirZJkMpzUXzDpVCLMdwV7VOl8KloRKbkMODVd3zREYzdTSRWoETDNQlKoVxNtNKZqRDClQ7aBiE
EVGSc01qQehrJVhZxWJsP+01G1xmpsA3hqaYRTFcj8oVPFgUmMvR7KkZEIqRlWSBTRHZj0pjRKLEVILI
1HMMPs2KTy/WquMeBig5NIBPLqpODQgM2SNyai8ph1FaIgay1BJuIxigRX8ij7P7UXERyRD0qo64NNAI
KkBqiQzTGqgGU1qYDKac0XGRlqSkIQ03ZVCOw3EUvmmsTUUS09TTQFmOpqUiLEbiqrGQGkBLHPIKsi5P
eixY5ZeatQzUmMvRNVgNWbKApmomgNFwGGPFMGM0AS4FQyRCgCuYRUZtl9KCSrcQqFrMkXmrQiMLT9lA
DGizVOa0ouKxUeDbURVqtMTEKtTCGrS6ECq2aspF61LYhWtxUTQVHMNlZ4sVDtxVcxI00oqriudfTcVJ
sMPFOVqALMbVZTJoAspDmn/ZRUXAjNsKjaGlcBojq1EuKLgXYzUwas2UixG+BSSXCihFFOafNVPNOa0S
ESCY1FLcEU7CKxvKb9t96OUkgmutwqg7807Ejd9P84UcoXHCUU1zkVNrDuU5RUG2qELik2ikMNoFSqVF
K4rCM4qF3FSIpysKqOapCGVLHVMDrqMUzQQpmlWE0AWI48VaTihgWUkAp/nVmIaZM0w1IDacpoAmR6sq
4xUFjZJsVTeUk1rFAA5pcYrQY3NVpzQBnytiqzS1VjMjM1M8zNBIbqTNMCRal7VDAjdagZakZGaaWxSA
jaWozcUDGNP6VAzmmokkDsaiLGq5RArVKr0coI7QVIqZoNCYJUmBQAwkCm+ZSAXfT13UhE4Bp1QA0ioy
cUDASYqQT0WKEMuaQcmtEBOtIxpgR1BLQBQmFU3FUQyuwplUIWjNIBQ+2pxNSZIvmUwsDWdhkZqMrSAh
darstUgI9tNIq0K5EVqMrVCE20baYjukFTBsVibDvMppegBvWl2UxEqJVhFrNsZOBS4qBkMlVWpoRHUi
oa2KJglOxigYtJmgQ3NRvQBSlqqwqiCFlqErTJG4pDQOw2koAQk0m40iQ3mk8ypAazZqE0DGUw1YiJqa
aBCYpKYrHahqdnNZGwoFSpGTQBYWGneXSuIb0p4apYx3mUnnVNhjDJTM1aQxVFTLViHUmaAG5ppoAYTU
bGgRXeoGFMRCwqE0wI6YaBDaSgApMUCGGmGgBhptAiM0w0wGUygAptFhnceXUixk1kUWY4KuJBUsZL5V
NZKm4Fd1xVZmpgQM9R+ZVgOD08NTAkDU8SUwDzKb5lACeZSb6YDS9MLUgGE1C1MRC1RNTERUygBtJQAl
FIQ01G1AEZplMCM1GaYDaaaYhppKTA9H8qpUjrEssIBU64qGMk4qKQipAozvWdK9aICsWpAa0ESA08NQ
Mdupd1ACbqTdTAM0m6gQm6jNADCaYaAImqI0CIzTKYDaSgBKKQhhNRk0CIjTDQMYajNMQym5pgJRTBHq
hWm1zFibqXzcUhjDce9QyXPvRYCnNPVKSWtESR5p4qxj807NIY7NLmgQ3NGaBi5pKYhKBSAKYaYERFRm
mIYaYRSAZTaAEopARtURpkkZphNAyMmoyaYDKSgQtKKBHqJNQuaxRZVeXFQm4oGRPcVAZqoCJpM1HVIQ
4U/NMYuadmkA7NGaYCUtADqQ0hBRTGOphoERmozQBGaYaAGGmUCEopARNURpgRmojTAjNRk0wGUmaZIo
NTLUgelsaryPWKLKEzVQkfmqsNEXmUu6qsAop1UIWlpDFp4oAkxRikIaaTNMY7NFAhaKBi02mIjNRGkB
GTUZNADKTNACZpM0CImqImgRGaiNMZETUTUCG0ZqmITdUytSA9JkNUpmrAsozPVJmzWiEIKeKYySjNAg
pRTGSquasxx1LAnEVO8moGQPFVdlxTuAzNOzVCFzTqYBUZNAEZNRsaoRCxqMmpAbupuaAEJpM0CImamE
0wIyaiagZCxqMmmIZnmkJ5piCnA0hnpbvVKY1gMozVVrRAhwFPpjFpM0xBViNKQFuKOrscdRIZaSKnGO
swK8kdUZkpoCm4pma1QDxTxVCA1E1AEbGoWNAELGmZoAjJpuaAEzRmkBCxqPNUSIaiY80DImNRGgQ3NJ
miwCZpwNMZ6JI1VnNY2GVZOahIqhi06qEFNpDJo1q7EtJiL0SVcjWsmMsqKcRUAVpRWfNQgM+Wq3et0B
KKeKoQGonpgVmaoiaAI2NRE0AMJpuaYgoJ4pCK7HmmZoAaWqImqAiLUzNADc03NAxacKAPQWaojWQyJh
UDUANp1UMSkFMC3EKvRCpkIvRCra1iwH5p26pGV5mrOnNNAZ8xqt3reIidBmnmqEMNV5GpgVWaoy1IZG
WqMtTEJmm5oENzQTSAgeot3NMYwmoy1MCImkJoENzSUhhmlBpgf/2Q==
