Context is reset to default when input is 0
Im testing my function with a inject node of topic dim with payload values of 0 and 1.
the code is like:
node.warn("xx context.dimpre:" + context.dim);
context.dim = context.dim || 100.0;
node.warn("xx context.dimpost:" + context.dim);
if (msg.topic === 'dim')
context.dim = msg.payload;
node.warn("xx msg.topic " + msg.topic + " msg.payload:" + msg.payload);
node.warn("xx context.dim:" + context.dim);
When I send >0 everything is as expected, context.dim is persisting the value.
When I send a 0 then it stores the value first:
"xx context.dim:0"
But afterwards when the node gets triggered again from another msg the value changes to its init value:
16.4.2020, 00:05:03node: percent in 2 colorsfunction : (warn)
"xx context.dimpre:0"
"xx context.dimpost:100"
Why is this happening?
Thank you for any hint
because of this line
When you set context.dim to 0, the next time it runs, it gets the 100.0
THE REASON IS... 0 == false
Do this instead...
if(context.dim == "undefined"){
  context.dim = 100.0 //init value ONLY if its undefined
NOTE: accessing context in this manner is depreciated (see the node red documentation on context.get, context.set)
understood, its a short circuit evaluation. Thank you
