Control roller blinds using the google home assistant
I want to control a motor that only has + - so i need to change polarity but i dont know how to do that whit out making a short circiut. This is my wiring diagram down bellow.
My second problem is that i dont have any stops its just a simple 7 volts motor so i want a timer to control the time the motor rolls upp and down without anything braking.
Anything will help, Thanks
ps if someone knows if its posible to make the programming loke like Ladder i would be thankfulll
You can do the polarity reverse using a double pole double throw relay R1 and r2.
The on for set period then off can be done using a trigger node set to use msg.delay, you then feed in the delay time you wish.
e.g.
[{"id":"aa8c482.93734b8","type":"http in","z":"aaa6c9eb.cd5608","name":"","url":"/download","method":"get","upload":false,"swaggerDoc":"","x":120,"y":780,"wires":[["d969ba04.e24028"]]},{"id":"d19cc7d8.646328","type":"http response","z":"aaa6c9eb.cd5608","name":"","statusCode":"","headers":{},"x":910,"y":780,"wires":[]},{"id":"d969ba04.e24028","type":"function","z":"aaa6c9eb.cd5608","name":"Get the file name","func":"msg.filename = msg.req.query.filename;\nmsg.contentdisposition = \"attachment; filename=\\\"\" + msg.req.query.filename.replace(/^.*(\\\\|\\/|\\:)/, '') + \"\\\"\";\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":780,"wires":[["e92381c3.c4cd2"]],"outputLabels":["Folder selected"]},{"id":"e92381c3.c4cd2","type":"file in","z":"aaa6c9eb.cd5608","name":"","filename":"filename","format":"","chunk":false,"sendError":false,"encoding":"none","x":560,"y":780,"wires":[["99ff4953.d0d5c8"]]},{"id":"99ff4953.d0d5c8","type":"change","z":"aaa6c9eb.cd5608","name":"Set Headers","rules":[{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers.content-type","pt":"msg","to":"text/csv","tot":"str"},{"t":"set","p":"headers.Content-Disposition","pt":"msg","to":"contentdisposition","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":780,"wires":[["d19cc7d8.646328"]]},{"id":"8dd5fe2ad1c1362e","type":"ui_etable","z":"aaa6c9eb.cd5608","payload":"[{\"title\":\"Type\",\"field\":\"icon\",\"formatter\":\"html\",\"width\":80},{\"title\":\"Name\",\"field\":\"fname\"},{\"title\":\"Size\",\"field\":\"stat.size\",\"sorter\":\"number\",\"width\":70,\"sorterParams\":{\"thousandSeparator\":\",\",\"decimalSeparator\":\".\",\"alignEmptyValues\":\"top\"}},{\"title\":\"Created\",\"field\":\"stat.created\",\"formatter\":\"datetime\",\"width\":200,\"formatterParams\":{\"outputFormat\":\"yyyy.MM.DD HH:mm:ss\",\"invalidPlaceholder\":\"(invalid date)\",\"timezone\":\"system\"}},{\"title\":\"Changed\",\"field\":\"stat.changed\",\"formatter\":\"datetime\",\"width\":200,\"formatterParams\":{\"outputFormat\":\"yyyy.MM.DD HH:mm:ss\",\"invalidPlaceholder\":\"(invalid date)\",\"timezone\":\"system\"}}]","payloadType":"json","options":"{\"movableColumns\":true,\"resizableColumns\":true,\"selectable\":1,\"responsiveLayout\":\"collapse\",\"autoResize\":true,\"layout\":\"fitColumns\",\"pagination\":\"local\",\"height\":\"100%\"}","group":"7c3d1ffe5de85af4","name":"File Browser","order":4,"width":"18","height":"10","columns":[],"outputs":1,"cts":false,"x":790,"y":160,"wires":[["9f0139c9d4cf303c","2fd8e45dcc9f2743","cf09d98db7656238","ab85eb9606fc412a"]]},{"id":"52a7d9cf9e103e93","type":"inject","z":"aaa6c9eb.cd5608","name":"Init","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"change","payload":"filebrowser_default_folder","payloadType":"global","x":90,"y":120,"wires":[["5e18896e060736a2"]]},{"id":"5e18896e060736a2","type":"function","z":"aaa6c9eb.cd5608","name":"Folder handling","func":"let folder = context.get(\"folder\");\nif (folder===undefined) {\n    folder=\"/\";\n    context.set(\"folder\", folder);\n}\n\nlet hidden = context.get(\"hidden\");\nif (hidden===undefined) {\n    hidden=false;\n    context.set(\"hidden\", hidden);\n}\n\nif (msg.topic===\"up\") {\n    var the_arr = folder.split('/');\n    the_arr.pop();\n    folder=the_arr.join('/'); \n    context.set(\"folder\", folder);\n}\nif (msg.topic===\"change\") {\n    folder=msg.payload;    \n    context.set(\"folder\", folder);\n}\nif (msg.topic===\"hidden\") {\n    hidden=msg.payload;    \n    context.set(\"hidden\", hidden);\n}\n\nmsg.payload = {\"start\":folder, \"hidden\": hidden};\nflow.set(\"folder\", folder);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":160,"wires":[["7940237deb98874d","c9bad6d25a599039"]]},{"id":"1a853077cd0370f3","type":"function","z":"aaa6c9eb.cd5608","name":"Prep Data","func":"function convertDate(local) {\n    let d = new Date(local);\n    d.setTime(d.getTime()+3600*1000);\n    return d.toISOString().slice(0, 19).replace('T', ' ');\n}\n\nfor (var i=0; i<msg.payload.length; i++) {\n   // msg.payload[i].stat.created = convertDate(msg.payload[i].stat.created);\n   // msg.payload[i].stat.changed = convertDate(msg.payload[i].stat.changed);\n   // msg.payload[i].stat.accessed = convertDate(msg.payload[i].stat.accessed);\n   // msg.payload[i].stat.statusChanged = convertDate(msg.payload[i].stat.statusChanged);\n    msg.payload[i].fname = msg.payload[i].name.replace(/^.*(\\\\|\\/|\\:)/, '');\n    if (msg.payload[i].stat.isDirectory) {\n        msg.payload[i].ext = \"folder\";\n        msg.payload[i].icon = \"<i class=\\\"fa fa-folder-o\\\"></i>\";\n    } else {\n        msg.payload[i].ext = msg.payload[i].fname.split('.').pop().toLowerCase();\n        msg.payload[i].downloadlink = \"/download?filename=\"+msg.payload[i].name;\n        switch (msg.payload[i].ext) {\n            case \"csv\":\n            case \"txt\":\n                msg.payload[i].icon = \"<i class=\\\"fa fa-file-text-o\\\"></i>\";\n                break;\n            case \"jpg\":\n            case \"jpeg\":\n            case \"png\":\n            case \"gif\":\n                msg.payload[i].icon = \"<i class=\\\"fa fa-file-image-o\\\"></i>\";\n                break;\n            case \"json\":\n            case \"py\":\n            case \"sh\":\n                msg.payload[i].icon = \"<i class=\\\"fa fa-file-code-o\\\"></i>\";\n                break;\n            default:\n                msg.payload[i].icon = \"<i class=\\\"fa fa-file-o\\\"></i>\";\n        }\n    }\n}\nflow.set(\"currentfolder\",msg.payload);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":160,"wires":[["8dd5fe2ad1c1362e"]]},{"id":"1049939dcaf15797","type":"inject","z":"aaa6c9eb.cd5608","name":"Default folder","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"/home/pi/Documents/ANPR","payloadType":"str","x":120,"y":60,"wires":[["97eb3daaadda1ae8"]]},{"id":"97eb3daaadda1ae8","type":"change","z":"aaa6c9eb.cd5608","name":"Store settings","rules":[{"t":"set","p":"filebrowser_default_folder","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":60,"wires":[[]]},{"id":"4c3c5231e3d633dd","type":"ui_button","z":"aaa6c9eb.cd5608","name":"","group":"7c3d1ffe5de85af4","order":2,"width":"3","height":"1","passthru":false,"label":"Actualiser","tooltip":"","color":"","bgcolor":"","className":"","icon":"refresh","payload":"","payloadType":"str","topic":"refresh","topicType":"str","x":80,"y":200,"wires":[["5e18896e060736a2"]]},{"id":"8ee8106b5f5eda72","type":"ui_button","z":"aaa6c9eb.cd5608","name":"","group":"b9eaf4515438b94a","order":2,"width":"3","height":"1","passthru":false,"label":"Supprimer","tooltip":"","color":"","bgcolor":"","className":"","icon":"delete","payload":"","payloadType":"str","topic":"delete","topicType":"str","x":90,"y":400,"wires":[["ab85eb9606fc412a"]]},{"id":"630956d807bb897f","type":"ui_button","z":"aaa6c9eb.cd5608","name":"","group":"7c3d1ffe5de85af4","order":1,"width":"3","height":"1","passthru":false,"label":"Accueil","tooltip":"","color":"","bgcolor":"","className":"","icon":"home","payload":"filebrowser_default_folder","payloadType":"global","topic":"change","topicType":"str","x":80,"y":160,"wires":[["5e18896e060736a2"]]},{"id":"1ec03f77c131fff2","type":"ui_template","z":"aaa6c9eb.cd5608","group":"b9eaf4515438b94a","name":"File Preview","order":3,"width":"10","height":"10","format":"<div ng-bind-html=\"msg.payload\" height=\"100%\" style=\"height: 100%;\"><br/>\n</div>\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":1230,"y":520,"wires":[[]]},{"id":"9f0139c9d4cf303c","type":"ui_text","z":"aaa6c9eb.cd5608","group":"b9eaf4515438b94a","order":1,"width":"4","height":"1","name":"Filename","label":"","format":"{{msg.payload.fname}}","layout":"row-left","className":"","x":1020,"y":160,"wires":[]},{"id":"2fd8e45dcc9f2743","type":"switch","z":"aaa6c9eb.cd5608","name":"File type","property":"payload.ext","propertyType":"msg","rules":[{"t":"eq","v":"csv","vt":"str"},{"t":"eq","v":"txt","vt":"str"},{"t":"eq","v":"json","vt":"str"},{"t":"eq","v":"sh","vt":"str"},{"t":"eq","v":"py","vt":"str"},{"t":"eq","v":"jpg","vt":"str"},{"t":"eq","v":"jpeg","vt":"str"},{"t":"eq","v":"png","vt":"str"},{"t":"eq","v":"gif","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":10,"x":200,"y":560,"wires":[["f4a765c1f1902e7a"],["f4a765c1f1902e7a"],["f4a765c1f1902e7a"],["f4a765c1f1902e7a"],["f4a765c1f1902e7a"],["d01017c774b3015b"],["d01017c774b3015b"],["d01017c774b3015b"],["d01017c774b3015b"],["94f0866931125570"]]},{"id":"f4a765c1f1902e7a","type":"function","z":"aaa6c9eb.cd5608","name":"Get the file name","func":"if (msg.payload.stat.size<200000) {\n    msg.filename = msg.payload.name;\n    return [msg,null];\n} else {\n    return [null,msg];  \n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":520,"wires":[["1bd0dae8f649fd8a"],["777954f42573efc6"]],"outputLabels":["Folder selected",""]},{"id":"1bd0dae8f649fd8a","type":"file in","z":"aaa6c9eb.cd5608","name":"","filename":"","format":"","chunk":false,"sendError":false,"encoding":"none","x":730,"y":520,"wires":[["87752f132359caad"]]},{"id":"87752f132359caad","type":"function","z":"aaa6c9eb.cd5608","name":"Div text","func":"function HTMLEncode(str) {\n    var i = str.length,\n        aRet = [];\n\n    while (i--) {\n        var iC = str[i].charCodeAt();\n        if (iC < 65 || iC > 127 || (iC > 90 && iC < 97)) {\n            aRet[i] = '&#' + iC + ';';\n        } else {\n            aRet[i] = str[i];\n        }\n    }\n    return aRet.join('');\n}\n\nlet text = \"<div>\";\nlet filecontent = \"\";\nfilecontent += msg.payload;\n\nfilecontent = HTMLEncode(filecontent);\n\n// Convert line feed to <br>\nfilecontent = filecontent.replace(/(?:\\r\\n|\\r|\\n)/g, '<br/>');\n\n\n\ntext += filecontent;\ntext += \"</div>\";\nmsg.payload = text;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":900,"y":520,"wires":[["1ec03f77c131fff2"]]},{"id":"d01017c774b3015b","type":"function","z":"aaa6c9eb.cd5608","name":"Get the file name","func":"if (msg.payload.stat.size < 2000000) {\n    msg.filename = msg.payload.name;\n    return [msg, null];\n} else {\n    return [null, msg];\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":600,"wires":[["36938b3decb00b93"],["777954f42573efc6"]],"outputLabels":["Folder selected",""]},{"id":"36938b3decb00b93","type":"file in","z":"aaa6c9eb.cd5608","name":"","filename":"","format":"","chunk":false,"sendError":false,"encoding":"none","x":740,"y":600,"wires":[["f3a77316a142090b"]]},{"id":"ee1728b79fedf48f","type":"function","z":"aaa6c9eb.cd5608","name":"Div image","func":"let text = \"<img src=\\\"data:image/png;base64,\";\ntext += msg.payload;\ntext += \"\\\" width=\\\"100%\\\"/>\";\nmsg.payload = text;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1040,"y":600,"wires":[["1ec03f77c131fff2"]]},{"id":"f3a77316a142090b","type":"base64","z":"aaa6c9eb.cd5608","name":"","action":"","property":"payload","x":900,"y":600,"wires":[["ee1728b79fedf48f"]]},{"id":"cf09d98db7656238","type":"function","z":"aaa6c9eb.cd5608","name":"Change folder","func":"\nif (msg.payload.stat.isDirectory) {\n\n    msg.topic = \"change\";\n    msg.payload = msg.payload.name;\n\n    return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":240,"wires":[["5e18896e060736a2"]]},{"id":"c9bad6d25a599039","type":"ui_text","z":"aaa6c9eb.cd5608","group":"7c3d1ffe5de85af4","order":3,"width":"9","height":"1","name":"","label":"Folder:","format":"{{msg.payload.start}}","layout":"row-left","className":"","x":480,"y":100,"wires":[]},{"id":"ab85eb9606fc412a","type":"function","z":"aaa6c9eb.cd5608","name":"Handle file actions","func":"switch (msg.topic) {\n    case (\"delete\"):\n        msg.file = context.get(\"lastfile\");\n        if (msg.file!==undefined) {\n            msg.filename = msg.file.name;\n            return [msg,null];\n        }\n        break;\n    case (\"download\"):\n        msg.file = context.get(\"lastfile\");\n        if (msg.file !== undefined) {\n            //msg.template = \"<script>window.location.href = \\\"/download?filename=\"+msg.file.name+\"\\\";</script>\";\n            msg.template = \"<script>window.open('/download?filename=\" + encodeURIComponent(msg.file.name) + \"', '_blank');</script>\";\n            return [null, msg];\n        }\n        break;\n    default:\n        context.set(\"lastfile\", msg.payload);\n}","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":270,"y":400,"wires":[["346d1bfad5842d5e"],["f27d36356901af0b"]]},{"id":"346d1bfad5842d5e","type":"change","z":"aaa6c9eb.cd5608","name":"Set message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Delete confirmation","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"Are you sure you want to delete this file?","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":400,"wires":[["89dc6deaab1808aa"]]},{"id":"89dc6deaab1808aa","type":"ui_toast","z":"aaa6c9eb.cd5608","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"Yes","cancel":"No","raw":false,"className":"","topic":"","name":"Confirmation","x":670,"y":400,"wires":[["32285273e011031e"]]},{"id":"32285273e011031e","type":"switch","z":"aaa6c9eb.cd5608","name":"Yes?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Yes","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":830,"y":400,"wires":[["2ac7af71cd82b7a7"]]},{"id":"2ac7af71cd82b7a7","type":"file","z":"aaa6c9eb.cd5608","name":"Delete file","filename":"filename","appendNewline":true,"createDir":false,"overwriteFile":"delete","encoding":"none","x":980,"y":400,"wires":[["3d10270c932dca69"]]},{"id":"3d10270c932dca69","type":"link out","z":"aaa6c9eb.cd5608","name":"link out 13","links":["1275bed0427c4097"],"x":1095,"y":400,"wires":[]},{"id":"1275bed0427c4097","type":"link in","z":"aaa6c9eb.cd5608","name":"Refresh File List","links":["3d10270c932dca69"],"x":115,"y":240,"wires":[["5e18896e060736a2"]]},{"id":"94f0866931125570","type":"function","z":"aaa6c9eb.cd5608","name":"Div text","func":"msg.payload = \"<div>No preview available</div>\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1040,"y":660,"wires":[["1ec03f77c131fff2"]]},{"id":"f27d36356901af0b","type":"ui_template","z":"aaa6c9eb.cd5608","group":"b9eaf4515438b94a","name":"","order":18,"width":0,"height":0,"format":"","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","className":"","x":500,"y":440,"wires":[[]]},{"id":"9c81f3c971381924","type":"ui_button","z":"aaa6c9eb.cd5608","name":"","group":"b9eaf4515438b94a","order":2,"width":"3","height":"1","passthru":false,"label":"Télécharger","tooltip":"","color":"","bgcolor":"","className":"","icon":"file_download","payload":"","payloadType":"str","topic":"download","topicType":"str","x":90,"y":440,"wires":[["ab85eb9606fc412a"]]},{"id":"777954f42573efc6","type":"function","z":"aaa6c9eb.cd5608","name":"File too big","func":"msg.payload = \"<div>File too large for preview</div>\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":560,"wires":[["1ec03f77c131fff2"]]},{"id":"7940237deb98874d","type":"fs-file-lister","z":"aaa6c9eb.cd5608","name":"Files","start":"/home/pi/Documents/ANPR","pattern":"*.*","folders":"*","hidden":false,"lstype":"both","path":true,"single":true,"depth":0,"stat":true,"showWarnings":false,"x":470,"y":160,"wires":[["1a853077cd0370f3"]]},{"id":"7c3d1ffe5de85af4","type":"ui_group","name":"Explorateur de fichier","tab":"db5ac7bc58fb5462","order":1,"disp":true,"width":"18","collapse":false,"className":""},{"id":"b9eaf4515438b94a","type":"ui_group","name":"Prévisualisation","tab":"db5ac7bc58fb5462","order":2,"disp":true,"width":"10","collapse":false,"className":""},{"id":"db5ac7bc58fb5462","type":"ui_tab","name":"Fichier","icon":"dashboard","disabled":false,"hidden":false}]
How to import a flow
thank you so much
