Controlling LEDs on a Wemos D1 Mini (Arduino code) via MQTT
One of my IoT students was asking how to control a set of LEDs on a Wemos D1 Mini, that had been programmed using Arduino code, via MQTT commands from Node-RED.
This is what the breadboard lash-up looks like...
The red LED is connected to D8 (GPIO-15).
The green LED is connected to D7 (GPIO-13)
The yellow LED is connected to D6 (GPIO-12)
This is the very simple test-flow we created in Node-RED.
Screen Shot 05-11-22 at 06.35 PM
[{"id":"bb2bbcc236726f09","type":"tab","label":"Wemos Controller","disabled":false,"info":"","env":[]},{"id":"a88767b42282a67e","type":"inject","z":"bb2bbcc236726f09","name":"redLED = \"on\" ","props":[{"p":"payload.state","v":"on","vt":"str"},{"p":"payload.color","v":"red","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":260,"wires":[["de011f97521ea82a"]]},{"id":"de011f97521ea82a","type":"mqtt out","z":"bb2bbcc236726f09","name":"","topic":"wemos/test","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"b80c36f2.044588","x":450,"y":460,"wires":[]},{"id":"d7aff05bf89bba23","type":"inject","z":"bb2bbcc236726f09","name":"redLED = \"off\" ","props":[{"p":"payload.state","v":"off","vt":"str"},{"p":"payload.color","v":"red","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":300,"wires":[["de011f97521ea82a"]]},{"id":"1ef4446fccad4b63","type":"inject","z":"bb2bbcc236726f09","name":"grnLED = \"on\" ","props":[{"p":"payload.state","v":"on","vt":"str"},{"p":"payload.color","v":"green","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":380,"wires":[["de011f97521ea82a"]]},{"id":"d38f12d896cc2eee","type":"inject","z":"bb2bbcc236726f09","name":"grnED = \"off\" ","props":[{"p":"payload.state","v":"off","vt":"str"},{"p":"payload.color","v":"green","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":420,"wires":[["de011f97521ea82a"]]},{"id":"d03d94b53eaa94d9","type":"inject","z":"bb2bbcc236726f09","name":"yelED = \"on\" ","props":[{"p":"payload.state","v":"on","vt":"str"},{"p":"payload.color","v":"yellow","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":500,"wires":[["de011f97521ea82a"]]},{"id":"e5d4bc03aa7bec28","type":"inject","z":"bb2bbcc236726f09","name":"yelLED = \"off\" ","props":[{"p":"payload.state","v":"off","vt":"str"},{"p":"payload.color","v":"yellow","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":540,"wires":[["de011f97521ea82a"]]},{"id":"087bd5bce959a671","type":"inject","z":"bb2bbcc236726f09","name":"allLEDs = \"on\" ","props":[{"p":"payload.state","v":"on","vt":"str"},{"p":"payload.color","v":"all","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":620,"wires":[["de011f97521ea82a"]]},{"id":"a2773f1bbca9f31c","type":"inject","z":"bb2bbcc236726f09","name":"allLED = \"off\" ","props":[{"p":"payload.state","v":"off","vt":"str"},{"p":"payload.color","v":"all","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":660,"wires":[["de011f97521ea82a"]]},{"id":"b80c36f2.044588","type":"mqtt-broker","name":"Broker_156","broker":"192.168.1.156","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"120","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Basically, a command is sent (from Node-RED) via MQTT to the Wemos with this format...
"color": "red" or "green" or "yellow" or "all"
"state": "on" or "off"
Together we worked out these Arduino files that need to go in the Wemos. You will need to place them in a folder, with the same name as the .ino file, so Arduino can compile them correctly.
Most of the clever stuff is performed in the function...
void callback(char *mqtt_topic, byte *message, unsigned int length)
You will need to enter your WiFi credentials in the 'config.h' file.
You will also need to install these Arduino libraries...
  • PubSubClient
  • ArduinoJson
My student and I hope you find this write-up useful?
Can't download the sketch Dave.
It's a zip file, you might need to accept a security flag before you can download it.
Let me know if you still have problems and I'll upload separate files.
Got it Dave, it was a security problem.
I've put the two files in this directory so it might be easier for people to download.
Arduino files
Small edit to the .ino file to handle the contents of the "color" and "state" commands with any case.
e.g. "color": "red" or "Red" or "RED" or any combination.
That's a great solution for me to show the power of the Photovoltaics system at home.
Green for more power as actually in use or red to save energy of possible.
:+1: Great
Hi Dave, can you authorize me to download the .zip?
I've updated the links on my server - please can you try again.
