I imported BigInter.js to the functionGlobalContext of node-red, however when I use var maximumByte = BigInt("FF", 16); (for bigInt the function is not known) it gives the following error SyntaxError: Cannot convert FF to a BigInt How can this be solved?
I think you might be using the wrong syntax - try these other methods
