I have a python exec which outputs a list (2D array) but in Node Red it becomes a string:
How can I get the array in NR?
If the python is simple, re-do it with node-red flows/nodes - thats the best solution IMO.
If you can fix the python to output valid JSON, thats the 2nd best solution.
Failing that, regex + string replacements (good luck)
PS, as always, if you post text data instead of images, someone will likely pop in and show you how.
I will go this way. thanks.
