Convert word to bool to word
I receive a variable as a word, but in that word information is coded as bits.
So after I receive the variable, I need to split up the word into bits, then do stuff, and then reassemble the bits into that word again to send it off.
Example:
I receive 22553
which is 01011000 00011001
I now need to address the individual bits and work with them
result might be: 00010000 01011100
so I send back: 4188
how do I do that in node red??
do it in a function node, where you can write standard javascript.
Has to convert a string to binary in javascript is easy to google for as is binary to dec
the modifications are not done in the function but throughout the flows.
So I need the bits addressable throughout node red, not just in a function
The convert it with a function and pass the result along your flow
This may help
https://www.w3schools.com/js/js_bitwise.asp
You could, in a Function node, split it into an array of values or an object with named properties, one for each bit, then pass that on.
thanks Colin,
Yes, I think object with named properties is what I want...
that means
msg.bits.number1
msg.bits.number16
right?
how do I get those 16 bits back into on dec value at the end of the flow?
A bit of javascript
