const hexchars = ['0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'];
let val = msg.payload;
let answer = "";
let size = 2;
while (size--) {
answer = hexchars[val & 0xF] + answer;
val = val >> 4;
msg.payload = "0x" + answer;
i see Apologies again
damn you did that pretty fast
Would it be to much to ask you to explain how your code works, if so ill go do the research myself I don't mind was just wondering
Upfront info to keep in mind / refer back to...
&is a Bitwise AND& 0xFmeans AND the value with 0xf (or decimal 15 or binary0000 1111)>>is a Sign-propagating right shift>> 4means shift the bits in a number 4 to right - effectively dropping the right most digit & moving other digits in the number to the right
Example of &
201in binary is1100 10010xFin binary is0000 11111100 1001AND0000 1111==0000 1001==9
The routine...
--- val & 0xF gets the 4 bits at the right most side of the value. e.g. 201 & 0xF --> 9 (see above info)
hexchars[val & 0xF] equals 9
--- then the 9th index in hexchars is the character "9" - that is appended to answer
val = val >> 4;
--- then we shift val 4 bits right val = val >> 4; to drop the first digit (as it is now processed) e.g. 201 >> 4 == 12
NEXT LOOP...
--- Now that val is 12, we do val & 0xF which == 12
--- 12 == 0000 1100
--- & 0xF 0000 1111
--- becomes 0000 1100 (i.e. stays at 12)
The 12th index in hexchars is "C" - that is appended to answer
The loop is finished so msg.payload gets set to answer and returned.
Thank you so so much. You helped me so much. And thank you to everyone else that helped. Thank you all and enjoy your day and/or night further
Apologies to come back but with your code @Steve-Mcl i noticed that with your size variable if the answer is anything bigger than 2 it only gives the last 2 values would there be a way to set the size to fit the answers length. i assume you wouldn't be able to do something like answer.length since the answer is being determined. If u use msg.payload.length it'll only set it to 1 since there's only 1 value inside of it
I don't follow what you're asking.
The solution is designed to handle 1 byte. If you want to send it 16 bit numbers, set size to 4.
You could have course to this dynamically by testing the value of msg.payload.
E.g...
If msg.payload > 255, set size to 4
If msg.payload > 65535, set size to 8
I see I see awesome thank you! sorry to bother
