Msg.payload : undefined
I have Hex-string which i am receiving from a Topic and converting in a function to binary then splitting the bits as to see in the function below and then sending the outputs at 8 different LEDS.
By receiving 0xFF there is no problem all LEDs are being green. but say receiving 0x04 ...i think the function parseInt(msg.payload, 16).toString(2) is producing only "100" after debugging and the other LEDs are becoming undefined value. probably because i am trying to access empty memory. but i have no idea how to solve this... anyone have an idea? how can i build for example a loop which fills only 1 in 8 bit long array for example where the 1 are set and keep 0 where is 0 or undefined or empty?
let output = parseInt(msg.payload, 16).toString(2)
var msg0 = { payload: output[0] };
var msg1 = { payload: output[1] };
var msg2 = { payload: output[2] };
var msg3= { payload: output[3] };
var msg4 = { payload: output[4] };
var msg5 = { payload: output[5] };
var msg6 = { payload: output[6] };
var msg7 = { payload: output[7] };
return [msg0,msg1, msg2, msg3, msg4, msg5, msg6, msg7];
here also my exported stuff:
        "id": "a1989ef9df599a1c",
        "type": "mqtt in",
        "z": "4235621c632ad702",
        "topic": "p2007/slaves/00/in/status",
        "qos": "2",
        "datatype": "auto",
        "broker": "0c31295bc495e7ce",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 790,
        "y": 40,
                "5a6a0d9804aedcce",
                "c372e9d957a298e0"
        "id": "5a6a0d9804aedcce",
        "type": "ui_text",
        "group": "39308d72b1563b23",
        "order": 33,
        "width": "3",
        "height": "1",
        "name": "IN_STATUS_0",
        "label": "00: STATUS",
        "format": "{{msg.payload}}",
        "layout": "row-spread",
        "className": "",
        "x": 1000,
        "y": 40,
        "id": "c372e9d957a298e0",
        "type": "function",
        "name": "function 7",
        "func": "let output = parseInt(msg.payload, 16).toString(2)\n\n\nvar msg0 = { payload: output[0] };\nvar msg1 = { payload: output[1] };\nvar msg2 = { payload: output[2] };\nvar msg3= { payload: output[3] };\nvar msg4 = { payload: output[4] };\nvar msg5 = { payload: output[5] };\nvar msg6 = { payload: output[6] };\nvar msg7 = { payload: output[7] };\n\n\nreturn [msg0,msg1, msg2, msg3, msg4, msg5, msg6, msg7]; ",
        "outputs": 8,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 840,
        "y": 240,
                "a8a3b00c58e721eb"
                "542649152d6f0d2d"
                "ebe8907af4be6534"
                "45e9e9994c8a7630"
                "a33f02070930bc20"
                "a98c48d0c95d9387"
                "f7c54db71fe14909"
                "eb647ad2daba09b7"
        "id": "45e9e9994c8a7630",
        "type": "ui_led",
        "order": 3,
        "group": "9ff13a5ef6d8935c",
        "width": "1",
        "height": "1",
        "label": "",
        "labelPlacement": "left",
        "labelAlignment": "left",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "null",
                "valueType": "str"
        "allowColorForValueInMessage": true,
        "shape": "square",
        "showGlow": true,
        "name": "BIT[4]",
        "x": 1250,
        "y": 240,
        "id": "a98c48d0c95d9387",
        "type": "ui_led",
        "order": 14,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "null",
                "valueType": "str"
        "allowColorForValueInMessage": false,
        "shape": "square",
        "showGlow": true,
        "name": "BIT[2]",
        "x": 1250,
        "y": 320,
        "id": "a33f02070930bc20",
        "type": "ui_led",
        "order": 13,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "null",
                "valueType": "str"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[3]",
        "x": 1250,
        "y": 280,
        "id": "ebe8907af4be6534",
        "type": "ui_led",
        "order": 12,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "false",
                "valueType": "bool"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[5]",
        "x": 1250,
        "y": 200,
        "id": "eb647ad2daba09b7",
        "type": "ui_led",
        "order": 16,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "null",
                "valueType": "str"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[0]",
        "x": 1250,
        "y": 400,
        "id": "f7c54db71fe14909",
        "type": "ui_led",
        "order": 15,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "null",
                "valueType": "str"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[1]",
        "x": 1250,
        "y": 360,
        "id": "542649152d6f0d2d",
        "type": "ui_led",
        "order": 16,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "false",
                "valueType": "bool"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[6]",
        "x": 1250,
        "y": 160,
        "id": "a8a3b00c58e721eb",
        "type": "ui_led",
        "order": 15,
        "width": "1",
        "height": "1",
        "label": "",
        "colorForValue": [
                "color": "#808080",
                "value": "0",
                "valueType": "str"
                "color": "#008000",
                "value": "1",
                "valueType": "str"
                "color": "#808080",
                "value": "false",
                "valueType": "bool"
        "shape": "square",
        "showGlow": true,
        "name": "BIT[7]",
        "x": 1250,
        "y": 120,
        "id": "0c31295bc495e7ce",
        "type": "mqtt-broker",
        "name": "IPC",
        "broker": "10.100.20.54",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "39308d72b1563b23",
        "type": "ui_group",
        "name": "Prozessdaten (INPUT)",
        "tab": "a5b09d62acbae35a",
        "order": 4,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "9ff13a5ef6d8935c",
        "type": "ui_group",
        "name": "00: STATUS:LEDs",
        "order": 9,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "a5b09d62acbae35a",
        "type": "ui_tab",
        "name": "EC-Produkttest",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
try parseInt("0x04", 16).toString(2).padStart(8, "0")
padStart will fill the start up to 8 spaces (if needed) with "0"
Personally, I avoid converting a perfectly good number to a hex string
Try this instead...
const value = msg.payload
const testBit = (v, b) => ((v>>b) % 2 != 0) ? 1 : 0
const msg0 = { payload: testBit(value, 0) };
const msg1 = { payload: testBit(value, 1) };
const msg2 = { payload: testBit(value, 2) };
const msg3 = { payload: testBit(value, 3) };
const msg4 = { payload: testBit(value, 4) };
const msg5 = { payload: testBit(value, 5) };
const msg6 = { payload: testBit(value, 6) };
const msg7 = { payload: testBit(value, 7) };
return [msg0, msg1, msg2, msg3, msg4, msg5, msg6, msg7];
Thanks you for the solution!worked :slight_smile:
this worked aswell! many thanks :slight_smile:
