Conveyor Belt - people counter - counting
I have setup a pi with a grovepi board. I want to use the ultrasonic sensor to count products. The standard value that comes off it is around 500. When a product passes it drops to around 20.
I want to make a counter that increments with 1 every time the sensor payload drops below 500.
How do I program this?
If value less than 30 add one to counter
That is also possible, but how do I script this?
Use a switch node for the if and you could use node-red-contrib-mycounter to count
Thank you so MUCH!!!
But now I need it to only count the next value if its back above 450. if a product gets stuck it should not keep counting. Any suggestions?
Search for Hysteresis on the node red flows site.
Can we let the swith pick up ?
var gelezen=context.get('gelezen') || 499;
if(msg.payload<450 && gelezen > 450)
context.set("waarde",1);
node.warn("1")
}else{
context.set("waarde",0);
node.warn("0")
context.set('gelezen',msg.payload);
Solution
if(msg.payload<50 && gelezen > 450)
msg.payload = 1
}else{
msg.payload = 0
