I've spent the last couple of days adding recipes to the Cookbook.
All of the placeholder recipes we had in the list now exist, plus a couple more along the way.
I've also created a Node-RED Project that contains all of the recipes: https://github.com/node-red/cookbook-flows that you can clone into your local Node-RED. Admittedly its more there for us maintain the cookbook, but I'm sure it'll be of use to some of you.
As you can see, we're focussed on covering the most common patterns before getting too advanced. My hope is, as questions get asked here on 'how can I do XYZ?' we're able to point at particular recipes rather than provide the same answers again and again. We should also use the insight of what gets asked regularly to consider what recipes we should have.
If you have any suggestions for common patterns we should cover, then please do let us know. Comment here, or come join the #docs channel on slack. For example, I plan to add one on joining separate streams of messages into one as that comes up a lot on here.
And whilst it's focussed on the core nodes, I'm sure we'll expand to have some Dashboard recipes at some point.
