Hi, please I could not connect to my broker with node red even that i tried it with MQTT spy and it woks normally could pub and sub data but with node red i get not connected i could not do anything without reaching the broker ?? please help me
Welcome to the forum @moussa869
Is that running on the same machine as node red is?
Tell us how you configured mqtt spy.
What OS/hardware are you running node-red on?
How did you install node-red?
Click on one of the MQTT In nodes you are using to test it and Export that node (Ctrl-E) and paste it here. When pasting use the </> button in the forum entry window.
What is the status showing under the MQTT node?
What is OVH?
node red is running in my computer
i just put server URI client ID a user name and password and some topics i use to communicate with the broker hosted in OVH (cloud ) in MQTT spy but whene am in nod red dosnt work
am running node red in windows with laptop i mad some exemple privied in the documentation it works (CSV URI)
"id": "bf2454555afc5dc2",
"type": "mqtt out",
"z": "d741bddf9f6c9c2f",
"topic": "",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "dac71d767023fc83",
"x": 370,
"y": 320,
"id": "dac71d767023fc83",
"type": "mqtt-broker",
"broker": "51.210.241.46",
"port": "1883",
"clientid": "HUTCHINSON",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
Admin edit, corrected the flow format. You did not use the </> button
Did you put the user and password in node-red?
Please try and answer all the questions asked
yes i put the user and password in node-red
i install it normaly with the cmd and all the commande lines after installing Node.js
the status under MQTT node is desconected
Can you show us a screenshot of that?
Please stop node-red then start it again in a command window and copy/paste the full output here. This is the </> button you should use when pasting code, logs etc
Looks like you have reused "HUTCHINSON" as the client ID in another MQTT client.
Try changing this to HUTCHINSON2. Does it still disconnect/connect over and over?
Failing that, you might have a bad topic or option set. So if the above doesn't work, tell us what broker type& version this is connecting to and show us how you have setup the client (broker config) properties in node-red
