Counter Resets randomly
Hi there, I have a problem with a function node (or node-red generally?). I have built a counter that writes the value to a variable and sends it to a database. This worked fine until a system update (Linux Debian) in May. Since then I have the problem that the counter resets after about 86 - 87s and starts from 0. I have updated Node-Red to 3.1.1. and also updated Node.JS. There has been no improvement. I have replaced the input (sensor via MQTT) with an Inject Node and the error is still present.
Node-Red Version V3.1.1
Node.JS Version 20.10.0
[{"id":"619db2f9830dc47b","type":"tab","label":"Testbereich","disabled":false,"info":"","env":[]},{"id":"97bba11763229d69","type":"inject","z":"619db2f9830dc47b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":"1","topic":"","payload":"1","payloadType":"num","x":170,"y":140,"wires":[["d38c745f87e7e686"]]},{"id":"d38c745f87e7e686","type":"switch","z":"619db2f9830dc47b","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":220,"wires":[["3c7fdb3f63de5e72"],[]]},{"id":"3c7fdb3f63de5e72","type":"function","z":"619db2f9830dc47b","name":"CounterMa20x","func":"//Definiere Variablen und ziehe gespeicherten Wert\n// wenn kein Wert vorhanden dann Wert = 0\nvar counterMa20x = flow.get(\"counterMa20x\") || 0\n\n// addiere 1 zum Zählwert\ncounterMa20x ++\n\n//speichere den Zähler Wert in der flow Variable\nflow.set(\"counterMa20x\", counterMa20x)\n\n//ändere msg.payload zum Zählwert\nmsg.payload = counterMa20x\n\n//dividiere durch Anzahl der Impulse\nmsg.payload = msg.payload*0.1425/4;\n//msg.payload = msg.payload*(Math.PI)/4;\n\nmsg.payload = Number(msg.payload.toFixed(2));\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":220,"wires":[["2b9ff46fb78bcccf"]]},{"id":"2b9ff46fb78bcccf","type":"debug","z":"619db2f9830dc47b","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":160,"wires":[]}]
Welcome to the forums @0x80000
Have you checked that Node RED is not restarting after 86 - 87s ?
I can't think of any reason why a flow variable will get wiped, other then Node RED restarting whilst not using the disc as context storage.
I would check logs, to see if there are any restarts of Node RED that would explain the pattern.
EDIT
And are you sure nothing else in your flow is setting/wiping out that flow variable to 0 :thinking:
If you installed using the recommended Debian script then you can run
node-red-log
to monitor the log and watch for restarts.
I've taken your flow and run it. It works fine for me. Counts up to past 10 without any problems.
I'm using a RPi-4B running NR 3.1.0 and Node.js v18.18.2
counter_resets
Thank you all for your Help. I think I solved the problem by reinstalling node-red via the recommended Script. :slight_smile:
