Create a delay to stabilze a switch
Thanks in advance im just new to Node Red.
Its hard to give this a title, but what i have is a 4 switches controlled by heartrate.
but i only want to change the switch once it has been within a range for 5 seconds
In Home Assistant i was able to do this with a delay but when i use a delay in node red i get delays in the function rather than the state.
Maybe something like...
TttuUP50tg
[{"id":"02692201b0297f2b","type":"inject","z":"1683bd9a.5e0a02","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"100","payloadType":"num","x":1290,"y":1200,"wires":[["63351327eee9e2c6"]]},{"id":"06a20cd953d78df7","type":"inject","z":"1683bd9a.5e0a02","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"140","payloadType":"num","x":1290,"y":1280,"wires":[["63351327eee9e2c6"]]},{"id":"29819d5115a9b4e4","type":"inject","z":"1683bd9a.5e0a02","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"180","payloadType":"num","x":1290,"y":1320,"wires":[["63351327eee9e2c6"]]},{"id":"780620e45c6c7191","type":"trigger","z":"1683bd9a.5e0a02","name":"","op1":"","op2":"","op1type":"nul","op2type":"pay","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"reset","bytopic":"all","topic":"topic","outputs":1,"x":1740,"y":1260,"wires":[["12fd30e396a846a6"]]},{"id":"63351327eee9e2c6","type":"switch","z":"1683bd9a.5e0a02","name":"between 120 ~ 160?","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"110","vt":"num","v2":"170","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1500,"y":1260,"wires":[["780620e45c6c7191"],["f8b4e435485bafc6"]]},{"id":"c1618f6dd36d6daf","type":"inject","z":"1683bd9a.5e0a02","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"130","payloadType":"num","x":1290,"y":1240,"wires":[["63351327eee9e2c6"]]},{"id":"f8b4e435485bafc6","type":"change","z":"1683bd9a.5e0a02","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":1320,"wires":[["780620e45c6c7191"]]},{"id":"12fd30e396a846a6","type":"debug","z":"1683bd9a.5e0a02","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1920,"y":1260,"wires":[]}]
thanks for the reply, your answer looks intersting , but i havent a clue on how to introduce it as i have 5 outputs from the switch
The simple way is to replicate the flow four times for your four ranges.
